Review / Measurement: Charger module with TP4056 controller
149 posts / 0 new
Halo...
Halo...'s picture
Last seen: 5 years 1 month ago
It might be possible to increase the termination voltage by providing the chip a ground that is actually slightly above ground. 0.03v. Input voltage can vary though. You need to start with stable voltage then pull the 0.03v off that.
Instead you could just try a few chips until you find one that hits 4.20v.
Pavithra_uk
Pavithra_uk's picture
Last seen: 3 months 47 min ago
Another way to near 4.2V termination voltage is reduce charging current by changing programming resistor
Instead of stock 1A, if program to 250mA, termination current will be 25mA (or 12mA for some boards) then battery can reach 4.2V
cajampa
Last seen: 5 years 3 months ago
Thanks for the ideas Halo & Pavithra
I already have reduced charging current to 130mA because i am charging a 350mA 10440 battery, and it is with that reduced charging current i only get 4,17v.
@Halo, how would i provide the ground slightly higher? is it by somehow feeding the – on the 5v side with a to start with 0,03v load?, do you have any idea how i could do that? maybe by a battery or a adjustable powersupply…..
Or do you mean that i should pull 0,03v of the 5v power source i use to power the board?
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 4 months ago
below 4.2vdc that is the batteries internal resistance resting/stabilization point…trying to get it to EXACTLY 4.2vdc will rarely happen…
If it stays well above 4.1vdc after a “full” charge the battery is still good…if it starts going much below 4.1 after the charger says it’s charged then it might be time to retire that battery as it is no longer anywhere near it’s 80%-100% capacity anymore
I put 2.2K resistors on mine…I get right at 500mA charge current and the batteries terminate much closer to 4.2vdc…takes a LONG time…but that is the nature of the beast…lower charge current but also less stress on batteries and more charge cycles but much much longer charge times
synology_john
Last seen: 6 years 8 months ago
Hi Kaiser,
I do not know what the additional BAT- connection is for yet, It may be that they are common battery grounds.
On the original board a MOSFET (8205A) disconnects the negative battery terminal when the battery voltage drops too low. I am hopeing that the EN connection will do the same from an outside signal.
R & G connections are for a 3 pin dual colour LED.
I have ordered some to test and will let you know my findings.
I am trying to create a type of 5V UPS for a Raspberry Pi.
kaiser
Last seen: 9 months 2 weeks ago
Hi John,
If you find anything usefull about this type of TP4056 please let us know.
I already received mine and used for what it was intended for. I had a cheap Tesco branded cordless screwdriver. I wasn’t using it much because batteries didn’t last long and it takes quite long to charge. But since I had some laptop-pull 18650 batteries I thought it might be interesting to replace original batteries with one 18650 and use TP4056 board for charging. Conversion went quite easy. Only thing that motor refused to work when connected to P- so I’ve soldered it to second B- instead. I don’t know why because multimeter was shoving the right voltage. But I’m not that good with electric stuff so can’t tell the reason. Maybe it’s something obvious Smile Anyway, the screwdriver works and charges now.
synology_john
Just had an email from the supplier. He states that the EN pin does nothing.
Looking at tghe photo of the board it looks like it goes to 2 pind on the chip next to it.
This could be a DW01x chip as pin 1 & 3 on that chip go to a MOSFET gate
vex_zg
Last seen: 3 years 3 months ago
So all I got was fake, and all of it has chips have the same logo. And for all of it I asked the seller will they ship genuine items. The answer was yes. Of course they didn’t. Two of them are obviously using the same dropshipping service, because I recived on the same day, 2 identical packages, from different ebay sellers, in identical envelopes, identical packaging inside. Ebay has become pretty useless and unreliable crap. Now I’m supposed to do what, open 3 disputes over 4$ worth of goods, and have endless conversations in chinglish. It’s more the unreliability that annoys me.
cajampa
sorry to hear that, you have the worst luck with ebay it seems, it would be really hard not to be really pissed off when you asked and they straight up lied to you.
Maybe we should keep a database in the forum with bad ebay sellers……..?
MRsDNF
MRsDNF's picture
Last seen: 2 months 4 days ago
I have one on order from DX. If it ever gets here I'll let you know what it is.
vex_zg
spent a bit more time on that $3 purchase, and asked ebay.com to step in, since seller didn’t provide return shipping label (I got non-genuine tp4056 ICs), quote:
_“Since this is an international transaction, eBay cannot force the seller to pay for the return shipping of the item. The rules on the site are geared towards members located in the US since eBay.com is the US core site. In order to return for a full refund, you will need to pay for the shipping out of pocket and then upload the tracking number in the return request.
If the return shipping is more than expected, then I would recommend you continue working with the seller on a partial refund amount on the items.”_
cajampa
That means ebay buyers protection isn’t worth anything anymore, before very recently when it was not as described you ALWAYS got you money back as long as you could prove it without having to send anything back EVER.
I think i will pay a little more if i find the same item on aliexpress now if i have to, because there it is at least still like that.
Halo...
Halo...'s picture
Cajampa, but it doesn’t sound like vex_zg is trying to do a SNAD claim.
Vex_zg, is it the seller that says you need to send it back or did you do a SNAD claim and ebay says it needs to be returned?
cajampa
I agree, i have a sneaking suspicion of that also, they really hide that option well nowadays, before the resolution center was way more visible and easy to use.
I just filed a claim against a shoddy seller who sold me a flashlight lens that looked nothing like the listing pictures, when i didn’t get a response on the return/refund section of the resolution center i tried to get ebay to step in but couldn’t i only got error messages. But today i got my full refund from the seller Smile it was only 2$ but it is the principle & i am still missing the part i thought i had bought Sad
Halo...
Halo...'s picture
Some sellers like to give you a hassle in hopes you’ll just go away. They know return shipping back to china with tracking is much more than a lot of items are worth.
Take a picture of the board you received showing the chip markings then send that to the seller along with a copy of the picture in their listing and quote the message you sent prior to sale asking if the item is as pictured. Tell them refund or neg feedback.
Photons Away
Photons Away's picture
Last seen: 3 years 7 months ago
cajampa wrote:
...Maybe we should keep a database in the forum with bad ebay sellers........?
Do you know about this thread? It is not an actual database but might suffice for now.
Photons Away
What would happen if the official government of Shenzhen City would be notified of this rubbish?
Official Shenzhen Government Online site http://english.sz.gov.cn/
Official Shenzhen Municipal Government Hotlines http://english.sz.gov.cn/ga/200510/t20051012_1092400.htm
On the Hotlines page do not overlook the three links of Hotlines on the left.
Remember - these businesses may be supposedly government owned and one would need to save face one might think.
All the above are in English.
WarHawk-AVG
borstar_micke wrote:
Found and bought even better size and cheaper heatsinks! Smile
5pcs 20×20×6mm High Quality Aluminum Heat Sink for crazy price
http://www.ebay.com/itm/50pcs-20×20×6mm-High-Quality-Aluminum-Heat-Sin...CPU-H30-/221638972745?pt=LH_DefaultDomain_0&hash=item339ab65549
WarHawk-AVG
Just turned in a request at fasttech for them to carry both the Micro USB charging one…AND the ones w/ the battery protection built on the boards (found a 2x lot at aliexpress for $2.25)
kaiser
Bought 5pc lot for $2.71 here: http://www.ebay.com/itm/400665524431. They come with Tpower chips which supposed to be decent. Came to EU in 2-3 weeks.
Halo...
Halo...'s picture
Has anyone done a test on “TPOWER” marked chips?
HKJ has only tested the NanJing Top Power chip (with logo).
cajampa
I have used one of those with battery protection for a couple of months, and i have been very satisfied.
But today i accidentally connected a 10440 in backwards and in some hour it sucked my poor little 10440 down to 0,8v Sad when i realized what i had done i disconnected it & it rather quickly recovered to 2.75v & then i started to charge it to see if it was recoverable, but after a bunch of hours on the charger it only got up to 3.08v so i will recycle it.
It doesn’t beak the charger to connect it wrong but it can discharge the battery low enough to break it if you don’t catch it in time Sad
WarHawk-AVG
Yuck…high current reverse polarity drain…ewwww
Definitely need HKJ to review those ASAP!
Any idea the max current that can flow thru the battery protect IC…real world measurements?
cajampa
Yeah i was surprised, if it wouldn’t have this weakness it would be perfect for a cheap robust charger board that have at least some foolproofness in built.
Sorry i can’t give any insight on the battery protect IC, I really don’t understand the circuit well enough to know how to measure it, best to leave that up to HKJ.
There is a rather extensive youtube review of this board, but i don’t remember how i found it……
cajampa
I have good news & bad news……
It seems i was wrong, the reason i couldn’t charge up the 10440 i though was killed, was the “with protection usb board” was broken.
I tried to charge another 10440 today & found that it didn’t charge at all anymore. So i reflowed another board for 10440 charging and now even the supposedly broken 10440 is charging fine, i have charged it up right now to 4v before i started it had recovered to 3.35v, i don’t know if it will get up to 4.2v in reasonable time & hold a charge yet, that will take some more time to figure out.
Last time i used a 10k ohm sense resistor but that would take forever Sad so this time i used a 5,6k ohm for (i believe, someone with better math skills please correct me if i am wrong ;)) ~235mA charging, that is a much more reasonable speed, still safe but in almost half the time.
I must have killed the first board when i left it connected the wrong way for a longer time last time, the reason i make that distinction is i know i have quickly accidentally connected it wrong before, for just a second or 2 but that didn’t beak it.
cajampa
More bad news the second USB charger board with protection is only charging up to 4.10-4.11v…….. and i thought 4.18-4.19v was bad Sad as low as 4.10v is sad on a tiny 10440 battery when the Vf on the XP-L can be up to 3.8-3.9v, that means it start out dim and only getting dimmer Sad & i usually switch battery before it comes to 3.75v rested.
I will try to reflow the other main component from the now dead board that was at least charging to 4.19v i hope that component still works, if it doesn’t that would at least explain what broke Smile so win win. I need to order some more of these now anyway.
pilotdog68
pilotdog68's picture
Potentially dumb question: can two of these chargers be used in parallel to charge a single-cell more quickly? I know there are single boards with dual Tp4056.
Halo...
Halo...'s picture
Yes they can. But it should be powered by only one usb power supply. Two power supplies might not play well together.
pilotdog68
Sweet! That’s great news. Now I just need to find a source for the genuine article.
MRsDNF
MRsDNF's picture
I thought I ordered this one months ago but apparently not. I have no idea if its genuine or not but the picture has the correct symbol on it and its not cheap.
http://aud.dx.com/product/tp4056-1a-li-ion-battery-charging-module-blue-...
