Review: Small Sun ZY-T08 2 x 18650 (Parallel)
353 posts / 0 new
sorotantaz
sorotantaz's picture
Last seen: 3 years 2 months ago
I notice that even button top battery placed side by side will have outer diameter more than 24 mm (larger than circle ring on the contact board). Reading from Betweenrides posts, he said his are overlapping the circle ring but nothing bad is happening.
So is it consistent for T08 that all users here have?
I’m asking because I just ordered this light and dumb enough to measure my battery just now (TF flame and panasonic button top), all are measured more than 24 mm (so must overlap the circle ring).
thanks Smile
Tom E
Tom E's picture
Last seen: 1 month 4 days ago
The T08's I've worked with (3) all work ok with various sorts of batteries that I've tested - only bad if they overlap the outer ground ring...
sorotantaz
Tom E wrote:
The T08’s I’ve worked with (3) all work ok with various sorts of batteries that I’ve tested - only bad if they overlap the outer ground ring…
Hi Tom..
is the outer ground ring same with the circle ring on the board that shown in the pictures earlier in this thread? (the one marked with arrow and question mark)
Tom E
Tom E's picture
sorotantaz wrote:
Hi Tom.. is the outer ground ring same with the circle ring on the board that shown in the pictures earlier in this thread? (the one marked with arrow and question mark)
Oh boy, can't find that pic, but looked at the op and it is very tight, forgot about that. But I've used KP 3400's, Pana PD's, and others and haven't had a problem - the Pana PD's have a pretty wide + end.
ohaya
Last seen: 6 months 1 week ago
sorotantaz wrote:
I keep digging on the but seems can’t find a certain answer from the expert or people who really know what they are doing. the most common explanation is the weaker cell will absorb the power from the better cell to maintain voltage level. dunno if that process is a safe case with lithium.
maybe runtime on panasonic 3100 mAh?
Think about it this way (a kind of “made up” example, and not really exact…):
- Voltage is ~ to height (= “potential”)
- Current is a “flow” (like water flowing)
If you have two voltage sources (batteries) with different voltages, it’s like two pipes of different heights. Let’s say they’re filled with water.
Now, connect the two pipes together at their tops with a pipe between them.
What happens?
The water (~ current) will flow from the taller pipe (the battery with the higher voltage).
Basically, it will try to bring the shorter pipe to the same level as itself.
Now, one more thing. Let’s say that there’s a huge difference in height. If that’s the case, the water will flow through the cross pipe FASTER (more current). If it flows really fast, and if, say, the inside surface of the pipe is really rough, it’ll create friction inside the pipe, and the pipe would get warmer from that friction.
Going back to the situation with the batteries in parallel, the same thing applies if the voltage between the two batteries is very large.
That voltage difference will cause a current to flow between the two batteries. The amount of current will be determined by the voltage difference and the resistance of the path (i.e., the wires) between the two batteries.
current = voltage/resistance
so, that means that if the voltage difference is very large, or if the resistance is very low, then there’s going to be a large current flow between the batteries, and if you get enough of a current flow, the wires between the batteries will get (maybe, very) hot. Try dropping a metal screwdriver across the terminals of your car battery if you don’t believe me (NO, DON’T DO THAT!!).
sorotantaz
Tom E wrote:
Oh boy, can’t find that pic, but looked at the op and it is very tight, forgot about that. But I’ve used KP 3400’s, Pana PD’s, and others and haven’t had a problem – the Pana PD’s have a pretty wide + end.
guess the picture is somewhere in page 2-4 in post by scaru or betweenrides..i’m on mobile can’t search for it..
anyway if you are saying panasonic protected is doing fine in this light, I guess I’ll be fine too using that battery..
thanks Tom Wink
Tom E
Tom E's picture
Panasonic PD's are unprotected, as sold at FastTech.
sorotantaz
mine is the protected one.
Just an update to previous post:
here's the picture I meant (it was posted by kramer though..sorry..)
Distance between button outer diameter side by side (touching each other):
Panasonic protected = +/- 25 mm
TF flame 2400 = +/- 25 mm, too..
if placed with a space/gap just like in the battery compartment, then will be larger measurement.
Referring to Betweenrides post, the circle diameter is 24 mm.
Tom E
Tom E's picture
Hhmm, never really noticed this tight fit - I got a stock T08 at home, will check measurements this evening.
sorotantaz
Tom E wrote:
Hhmm, never really noticed this tight fit – I got a stock T08 at home, will check measurements this evening.
much appreciate Tom Smile
Tom E
Tom E's picture
sorotantaz wrote:
much appreciate Tom :)
To me, it looks like 26.0mm across, ground ring to ground ring. The + inner contact is 24.3mm in diameter. 25mm should just barely make it...
sorotantaz
Tom E wrote:
To me, it looks like 26.0mm across, ground ring to ground ring. The + inner contact is 24.3mm in diameter. 25mm should just barely make it…
I guess the ground ring you referred to is the most outer gold ring..I’ll test mine first, should be arrived within day or two, already inbound in the post office. if doesn’t work well, might need a small magnet to elevate the + pole and create a smaller foot print..
Foy
Foy's picture
Last seen: 7 years 2 months ago
Man; the Small Sun is completely different inside than the UltraFire version. (T60)  Both the gold ring and center contact are spring loaded, against the corresponding brass center and aluminum end of the battery magazine.
Wonder how they did it with the Asgard . . .
Foy
No referral links and nothing embedded . . . ever.
                      &nbsp
Blazar
Last seen: 4 years 7 months ago
Looks like this one UltraFire UF-T60
Be nice if it was a bit cheaper, build quality looks good though.
Tom E
Tom E's picture
 Better internal design (and supposedly alum reflector instead of plastic) for more than triple the price, yikes, and it has that mode lock feature (annoying). If it was $35-$40 instead of $89, I'd buy one or 2, but $89 puts it in a whole nother realm, and it still has to be mod'ed to beat out a HD2010 in lumens and throw, accept of course the HD2010's you are buying today at some patheticly low amps...
Foy
Foy's picture
Paid $87.99 and yes, had brief but significant buyer's remorse.  Absolutely no regrets now.  Few lights in my collection can match its quality, or its performance.
nicetorchFoy
                      &nbsp
bibihang
bibihang's picture
Last seen: 15 hours 17 min ago
Tom E wrote:
Ubehebe wrote:
Anyone try a U3 or XM-l2 in this? I have some of both on the way and am thinking of trying one or the other. I know it has a giganto star, but if I center it right with a little Fujik, I’m thinking a 21 would work fine with that big plastic white retainer to center it and cover up hot wires.
XM-L2 U2 1C/SinkPAD mounted on copper disc, copper heat sink in pill, Nanjg 4.2A, UCL/p lens, copper braid added to tailcap springs:
  1,200 lumens at 30 secs, 210 kcd measured at 4.31 meters. It’s a little beast!!
 An amazing instrument for it’s size – don’t know of anything that compares for its size! An HD2010 should do the same, but on a single battery, it won’t hold up as well as this light does. Second one I built that produces these numbers, other one was measured by rdrfronty the same as my measurements, this one slightly better. I’ve noticed it just doesn’t drop off the longer the battery depletes like a single cell Nanjg based XM-L2 would.
Did I say it needs to be dedomed? :bigsmile:
sorotantaz
just received mine from FT Smile
can confirm the reflector is 100% plastic, any button top batteries work fine even though overlaps on circle trace on the contact board, and with 1 battery (either panasonic 3100 – 4.17v and trustfire flame 2400 – 4.07v) gives the same current at high mode: 1.84 Amp (so, it’s safe to say it is current regulated? Smile )
No hidden turbo found though..
compared to Trustfire X9, the ZYT08 hotspot is larger, eventhough only driven at 1.84A it is quite bright (can keep up with X9) when under 50 m distance. so for the king of thrower title, I might say ZYT08 still unable to take it from my X9.
Tom E
Tom E's picture
Yes, the X9 is one of my favorite throwers, but it's more a dedicated thrower than the T08 or HD2010 for example -- these lights still put out a good amount of lumens as well.
tivo532
tivo532's picture
Last seen: 7 years 6 months ago
Any info on the MCU used as the controller?
I have searched the internet and didn’t find one.
Maks4er
Last seen: 7 years 4 months ago
Which holster can be used with Small Sun ZY-T08?
This one?
Tom E
Tom E's picture
I like that holster for the T08, also works well with a HD 2010.
