Review: Small Sun ZY-T08 2 x 18650 (Parallel)
353 posts / 0 new
gords1001
gords1001's picture
Last seen: 3 years 6 days ago
I think johnnymac will be able to confirm it soon, but there really is no issue with the plastic reflector, the biggest issue I have is the crappy screws used to hold the tailcap on. These need replacement.
I’ve also found crappy ultrafire cells give a significant rise in current readings like 3a compared to 2.4a on Panasonics, efest cells etc. Guess their good for something…
JohnnyMac
JohnnyMac's picture
Yeah, I got word from DX that a T08 is on it's way to me.  Might take a few weeks until I have it but I'll let you know what the reflector is made of.  Honestly, I don't see what the big deal about the reflector is.  Plastic ones work just as well and are easier to manufacture as well as easier to produce in optimal designs.  The reflector does very little in the way of sinking heat from the light so material doesn't matter.
gords1001
gords1001's picture
Wait till you see the pill, its more like a horse suppository…. It’s _kin massive! It does want a couple of dimples drilling in to aid fitment, but its a good couple of inches long with threads along most of its length.
MarioSS
MarioSS's picture
Last seen: 5 years 7 months ago
Thanks for the replies guys!
Guess ill either pull the trigger on one from manafont.
MarioSS
MarioSS's picture
BetweenRides wrote:
kramer:
My new Keeppower 3400 button tops will not work in the ZY-T08. However my Callie’s Kustoms 3100 raised flat tops work perfectly:
crap i need new batteries if i paln to order one Silly
My Keeppower 3400’s are on the way from Bob
allthumbs
Last seen: 4 years 10 months ago
Received mine today from DX ordered on 29 Oct. It has the metal reflector. The only things I noticed was that the driver was a little loose about a 1/8 turn to tighten and I wiped the battery contact plate down with alcohol and got some black residue off it. My keeppower button top protected 3400 fit just fine. (Thanks Kumabear) And of course the spongy switch others have mentioned. Can`t wait for dark.
BetweenRides
BetweenRides's picture
Last seen: 2 years 10 months ago
MarioSS wrote:
BetweenRides wrote:
kramer:
My new Keeppower 3400 button tops will not work in the ZY-T08. However my Callie's Kustoms 3100 raised flat tops work perfectly:
crap i need new batteries if i paln to order one Silly My Keeppower 3400's are on the way from Bob
Mario, as I noted in post# 102, after tightening up the driver board, the Keeppower 3400's fit and work fine, so you should be ok.
MarioSS
MarioSS's picture
Oh sorry my bad I missed that post!
Thanks allthumbs and betweenrides for the heads up.
Allthumbs please share your experience when you power that baby up at night (if you have the time)
Thanks guys Big Smile
CheapThrills
CheapThrills's picture
Last seen: 2 weeks 2 days ago
Anyone soldered a driver yet?
If you have used a pot, what kind of resistance have you used?
gords1001
gords1001's picture
I added a little solder to the edge of the driver, to make it a good press fit. No difference in out put, I also cleaned the anodizing where the switch PCB contacts the body, no difference. I fitted a pot, minimum setting was 0.5ohm, that raised the output from 1.94a to 2.43a on good cells, and up to 3a on crap ultrafire Grey’s, guess their good for something. :bigsmile:
I’m waiting for johnnymac and viffer to get back on the readings of the pots viffer found.
Mine read 0.45 ohm – 49.5ohm in a 270 degree sweep.
The ones viffer found are rated 20 ohm and and 22 turns of adjustment – much better resolution.
You definitely need to get closer to .22 ohm.
Let us know if you find something. I’ll probably be ordering weekend after next (payday).
CheapThrills
OK.
While waiting, I tried it blindfolded with one 0.22Ohm
Now I get figures around 2.5 -> 3.2Amps or something like that.
I get once and a while the lower 2.4 something and when I cycle modes, it gives over 3 Amps.
Still I think it got better.
edit: those are with Trustfire Flames. Too bad I just ran out of proper Xtars, I will have to re-test when I get them again…
gords1001
gords1001's picture
Viffer said something about the circuit being very touchy with regards to resistance, so not too good cells give a higher reading.
I did find out I have to order some Panasonic’s or sanyos, the cells I thought were good have touchy protection circuits when you get over 2.2a. Sad
DrJones
DrJones's picture
Last seen: 5 years 1 month ago
Got mine today.
Measured sometimes 2.7A, sometimes 2.0A on high (0.95A/0.45A for med/low)
Flux: 660lm/320lm/150lm
Throw: 33kcd/370m
Unfortunately I don’t know what current the light used at those flux and throw measurements, but the flux measurements didn’t have much variance.
Hm. I wanted it to be on par with the FF STL-V2 and sell that one (because I prefer the T08 form factor), but now I can’t. I’ll probably try to mod it (when I find time for it).
CheapThrills
If someone of you guys need a 0.22 Ohm resistor but don´t want to wait forever ordering from China or don´t have Electronics shop near you, PM me.
I can send some of those to you, probably won´t need all 20 anyway Big Smile
awi01
Last seen: 7 years 10 months ago
this is mine coming from manafont today. Big Smile
what do you think, is it a plastic reflector or alumunium reflector?
also my evgreen flat top battery wont work on this flashlight,
so i’ve been thinking to get this one Sanyo UR18650FM 2600mAh Li-ion or this one Panasonic NCR18650A 3100mAh Li-ion or i should go with the unprotected one.
which one would you suggest better for small sun zy-t08? Big Smile
Lumatic
Lumatic's picture
Last seen: 7 years 6 months ago
H) Beer
“When I buy something in bulk you should prolly buy at least one too.”…..“They that have light shall rule the night.”…..“Flashaholics feel depressed without darkness.”…….“I’m a very terminal torchaholic. My entire life just flashed before my eyes
gords1001
gords1001's picture
Plastic. Any button top cells will run this, but the smaller the button the better.
Don’t worry about the plastic reflector, it works, be happy.
awi01
now im really confusing about what battery to buy,, not the very expensive one i think
what about this http://www.manafont.com/product_info.php/efest-sanyo-protected-18650-37v...
or
http://www.hkequipment.net/index.php?sp=&p=6&cat2=74&cat1=1&cat0=2&id=12...
viffer750
Last seen: 4 years 3 months ago
The above mentioned ebay pot looks good. 360° full turn -> 0.7-0.8ohm, minimal resistance ~0.03ohm, max ~19.3ohm,
unique engrish language... Smile
gords1001
gords1001's picture
Thanks viffer, I’ll go find the link again and order a few for stock.
Edit :- just ordered 8, £2.54 8)
Can’t wait for them to arrive now, give this light the current it deserves. J)
JohnnyMac
JohnnyMac's picture
gords1001 wrote:
Thanks viffer, I'll go find the link again and order a few for stock.
Mine arrived last week but I haven't had a chance to install any of them in any lights yet.
how2
Last seen: 10 hours 32 min ago
There is an ultrafire version which is the same as the small sun at Banggood for $24.99
garrybunk
garrybunk's picture
Last seen: 19 hours 11 min ago
Is that yours or a stock photo?  If it's yours, any report on tailcap current, build quality, etc . . . ?
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
how2
-Garry
It's mine, same as the Small Sun 2.02amps on with one battery.
Pulsar13
Pulsar13's picture
Last seen: 7 months 5 days ago
Hmm, slightly better price, about $1, but will wait for further report on the quality.
Well, not like MF ones are consistently good anyway :bigsmile:
I’ve submitted product request at fasttech for T08 and T13 before this, hope it gets through.
koyotee
koyotee's picture
Last seen: 2 months 3 days ago
so, where to by a small sun-t08 best price?
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
southland
southland's picture
Last seen: 1 month 1 week ago
manafont
koyotee
koyotee's picture
thanks Smile
koyotee
koyotee's picture
just ordered it, and 2xncr18650a 3100 from fasttech Smile
koyotee
koyotee's picture
so i received the batteries, will they fit into the small sun?
