Sorry, cancelled this realizing there will be no buyer for this item as it is prohibitively expensive. Definitely it was a bad idea buying these!
Wow! Those are expensive, I doubt they will sell but good luck with the sale!
They are indeed expensive but they have much more radiant flux per $. You can also direct drive the LEDs.
$128 for a UV emitter! I’m not sure there’s such a high demand for these emitters.
Get the wallet out
Those are the best UV emitters, mash.m used one in one of his builds.. that should say enough. ;)
that thing is CRAZY
I wish i had his 4x18650 battery adapter so i can finish my 4x aspheric thrower
Pulsar: NightCrawl:Those are the best UV emitters, mash.m used one in one of his builds… that should say enough.
that thing is CRAZY
I’d like to see the rest of that battery adapter…. I’d build some!!
Dan.
Those adaptors are hard to make I had one of his 4aa holders and its well built and impossible to take apart with out breaking the charging jack
I found one simular once I get it I’m going to have it machined to fit my host then I’m going to start to make a few Hopefully lol
I found a couple of images showing the entire part…. they won’t be hard to make at all. I’ll make the parts as well so that they can be taken apart if someone wanted to for modification or other purposes.
Dan
Pm me maybe we can work something out
