Hi guys!
I am starting this thread to post the results I have got when measuring the “health” of all of my Li-ion batteries that I have.
As you know, Li-ion batts degrade over time, even if not in use… This test was made to “clarify” or “see” how do they age over time. And, of course, try to find the “quality” of them. (I had a surprise with some…)
I have tested batteries which were being used constantly, some very abused, and other batteries were kept at “storage condition” (40% charged) during a year or more.
Again, all the batteries here are more than a year old except some of them that are crap (read latter).
The test was done in this way:
When receiving the batteries (new condition, never used) I used the Imax
http://dx.com/p/imax-b6-2-5-lcd-rc-lipo-battery-balance-charger-100-240v-us-plug-35190
to test the max capacity they had when new. I mean, I charged them, and discharged them until 3.0v to know the original capacity.
Then, knowing their original capacity, I kept some of them stored at about 40% more than a year, and some of them I kept for using them with normal use.
10440 batteries discharged at 300mA until 3.0v
14500 batteries discharged at 500mA until 3.0v
16340 batteries discharged at 500mA until 3.0v
18650 batteries discharged at 1000mA until 3.0v
Remember, all of them except the ones from DinoDirect are between 1 and 2 years old.
RESULTS:
UNprotected TrustFire blue 10440 from Lightake —- RECOMMENDED
Batt 1 - Arrived dead (tests were not possible)
Batt 2 - Original capacity - 297mAh - Capacity after +1 year of USE — 129mAh now UNUSABLE.
Batt 3 - Original capacity - 289mAh - Capacity after +1 year STORED - 155mAh now UNUSABLE.
Batt 4 - Original capacity - 301mAh - Capacity after +1 year STORED - 255mAh This one is the ONLY operational.
I have done about 50 cycles of full charge and discharge to these batteries (the ones that worked).
This pack of 4x10440 performed very good. I purchased them in September 2010. Only 1 battery remains operational today.
PROtected TrustFire gray 10440 from DealExtreme —- RECOMMENDED
http://dx.com/p/trustfire-protected-10440-600mah-3-7v-rechargeable-li-ion-batteries-2-pack-30788
This pack of 2x10440 were the first protected ones that I bought(early 2010). None of them remains operational (they died due to the constant heavy abuse I forced them).
Batt 1 - Original capacity - 303mAh - Capacity after +1 year of USE - 99mAh now UNUSABLE.
Batt 2 - Original capacity - 310mAh - Capacity after +1 year of USE - 88mAh now UNUSABLE.
I have done about 80 cycles of full charge and discharge to these batteries.
They are good unless you force them under high loads (like almost all 10440 cells except IMR)
UNprotected UltraFire blue 10440 from DinoDirect —- AVOID!!!
Don´t buy this battery!!! It is a total crap! It died in less than 2 months with NORMAL use!! AVOID IT!! Yes you get what you paid for… but 3.99$ for only 1 battery is expensive, and even more if it is crap!
Batt 1 - Original capacity - 242mAh - Capacity after LESS THAN 2 MONTHS - 66mAh NOW unusable
I have done about 10 cycles of full charge and discharge to this battery.
I dont have digital scale, but I can clearly notice that the weight of this cell is lower than my other unprotected 10440. It can not be used now even in the lowest mode of any flashlight.
PROtected TrustFire Flames 14500 from DealExtreme —- RECOMMENDED
http://dx.com/p/trustfire-protected-14500-3-7v-900mah-rechargeable-lithium-batteries-2-pack-26124
I have purchased several packs of this 2x14500 packs at Dealextreme. The first ones were purchased on mid 2010, the others tested were purchased on mid 2011.
Batt 2010 1 - Original capacity - 710mAh - Capacity after +2 years of USE - 488mAh STILL USABLE.
Batt 2010 2 - Original capacity - 695mAh - Capacity after +2 years of USE - 501mAh STILL USABLE.
Batt 2011 1 - Original capacity - 680mAh - Capacity after +1 year of USE - 479mAh STILL USABLE.
Batt 2011 2 - Original capacity - 733mAh - Capacity after +1 year STORED - 558mAh STILL USABLE.
I have done about 200 - 300 cycles of full charge and discharge to these batteries.
These batteries are the best from all my 14500.
UNprotected blue UltraFire 14500 from DinoDirect —- AVOID!!!
Don´t buy this battery!!! It is a total crap! It died in less than 2 months with NORMAL use!! AVOID IT!! Yes you get what you paid for… but 3.69$ for only 1 battery is expensive, and even more if it is crap!
Batt 1 - Original capacity - 401mAh - Capacity after LESS THAN 2 MONTHS - 213mAh NOW unusable
I have done about 20 cycles of full charge and discharge to this battery.
Again, I dont know if it is the “ultrafire” brand or the ones sold at DinoDirect, but all my DD batteries have died in less than 3 months with NORMAL use. It only works in LOW mode of any flashlight, if you try to discharge it at more than 300mA it fails.
Also it´s weight is less than my others 14500.
PROtected TrustFire Flames 18650 from DealExtreme —- RECOMMENDED
I have purchased some packs for the friends. For me, only one, and it has performed very good for the price. I have genuine ones.
Batt 1 - Original capacity - 2503 - Capacity after +1 year of USE - 2375mAh STILL USABLE.
Batt 2 - Original capacity - 2477 - Capacity after +1 year of USE - 2399mAh STILL USABLE.
I have done about 100 cycles of full charge and discharge to these batteries.
I have been using them in a TrustFire 3xT6, both in series, since about a year ago, using them on the Highest mode, and still OK.
UNprotected UltraFire gray 18650 from DinoDirect —- AVERAGE/POOR/MEDIOCRE
Batt 1 - Original capacity - 1785 - Capacity after LESS THAN 2 MONTHS - 1688mAh STILL USABLE.
I have done about 40 cycles of full charge and discharge to this battery.
OK, this battery, despite it is still working, and can power a XM-L flashlight regulated to 3A at 3A (with a big voltage sag) it´s capacity is very low, and I dont think this battery will “resist” too much time doing this.
Also it´s weight is much lower than my others 18650. I can not give any conclusion, at least positive conclusion.
Sanyo 18650 “pink” cells recovered from laptop —- RECOMMENDED if you find them
These batts are from a never used laptop battery pack. Well, almost never used. Manufactured on 2005, recovered by me and tested on 2011 (6 years since manufacture date). I recovered 3 of 4 cells from a laptop battery pack.
Their original capacity is 2200mAh. My measurements (6 years from manufacture date)
Batt 1 - Original capacity - unknown (rated 2200mAh) - Capacity after 6 years - 1735mAh STILL VERY USABLE
Batt 2 - Original capacity - unknown (rated 2200mAh) - Capacity after 6 years - 1620mAh STILL VERY USABLE
I have been using them also with the TrustFire 3xT6 (2 in series) on high mode and they go veeeery veeery well, comparable to the TF flames in current output. The capacity, of course, is much less due to the age.
I have done about 130 cycles of full charge and discharge to these batteries (the ones that worked).
They are available at Manafont. I think they are the same.
PROtected 16340 from DealExtreme —- RECOMMENDED
http://dx.com/p/trustfire-protected-16340-880mah-3-7v-rechargeable-li-ion-batteries-2-pack-24980
Batt 1 - Original capacity - 744mAh - Capacity after +1 year of STORAGE - 530mAh STILL USABLE.
Batt 2 - Original capacity - 737mAh - Capacity after +1 year of STORAGE - 515mAh STILL USABLE.
I have done about 3 cycles of full charge and discharge to these batteries.
I dont own a high powered flashlight which uses this kind of batteries, but I have them since a little bit than a year ago, because I planned to have one with finally I dont. I will have them stored for future use
