Is there any charger like the ML-102 Charger, but for NiHM cells? In other words something that will charge a NiHM battery even when there’s only a little bit of power available.
I want it specifically for charging cells from a solar panel. So far I have the ML-102 Charger and a 4x18650 box, which could be used to power up a Soshine SC-S7 but I’d prefer something that I could connect directly to the panel.
Don’t really care about that part, but it’s always a plus. Also, I forgot to mention that it should be able to take at least 1 amp max from the solar panel, as well as what I said before of being able to charge if there isn’t full sun available like the ML 102 can.
“What happens if a weak USB power supply is used or long cables, to simulate that I turned the power supply down to 4.5 volt. The charger continues to charge and stops when the battery is full, but it takes considerable longer time (nearly 10 hours).”
I have a couple of the Sanyo USB chargers mentioned above. I also use them in conjunction with solar panels.
However, I find that much of the time the Sanyo units flash erratically, suggesting an error which I think is down to insufficient current. In this case, I'm not even sure it is charging at all. I am running "nominal" 800mA panels and unless the sunlight is strong, I cannot reliably use the Sanyos, even though they are supposd to draw only 500mA.
To overcome this, I use an ML-102 with an 18650 as a "buffer" in between the panel and the Sanyo charger. This seems to work well when there isn't strong or consistent sunlight to power the Sanyo model directly. YMMV - You may find that solution a bit messy though.
I also have about 4 of the cheapie 2AA USB chargers found at computer swap meets and the like. Generic grey/silver units that retail for a couple of bucks each. They charge at about 120-160mA and will take 1 or 2 AA cells. These seem to output a trickle of charge into my NiMH AAs no matter how weak the sun is. (Multimeter readings as low as 20mA on cloudy days) However, they have no smarts of any kind so it is pretty tricky to know when the cells are charged.
I very much doubt you will find anything that will draw 1A from the panels and still trickle in low-light situations but if you do, please be sure to post back here.
