Test / Review: EnerPower 18650 2600mAh (Black)
Official specifications:
  • Samsung ICR18650-26C 2600 mAh
  • Minimum capacity: 2450mAh
  • Protection circuit: 5A - For Flashlights with over 10 Wh
  • Deep discharge protection: at 3V
  • Raised positive nipple - Button Top
  • Nickel base plate for added durability
  • Diameter: 18,5 mm
  • Length: 68,8 mm
  • Weight: 47,7g
  • CE certification
  • Assembly "Made in Germany"
Good capacity and good match between the two batteries.
Conclusion
The battery has slight more capacity than most other 2600mAh batteries and slightly less voltage during heavy loads.
It is using a Samsung cell and I will rate it as very good battery.
Notes and links
The batteries was supplied by ENERDan for review.
Thanks mate. Awesome as always.
