17mm driver into keygos m10
54 posts / 0 new
gords1001
gords1001's picture
Last seen: 3 years 7 months ago
Ok, I’ve been procrastinating about this for too long, so with a short day at work and an empty house, I decided to get on it.
I fitted this driver
http://budgetlightforum.com/node/14622
And a u3 1c emitter from intl outdoor, the driver was out of stock last time I looked, but they are supposed to be getting more, might be time for an email bombardment as these drivers rock! 8)
First strip the light down and get the pill out.
Notice the nice amount of threads, and this threads a long way into the head, if you want a c8 sized light with a good smooth beam that’ll take plenty of current and is easy to mod, get one of these.
Notice the brass driver retaining ring? That is important, 1:- it makes the stock 20mm driver easy to remove, 2:- the id of that ring is close to 17mm……..
That’s the new driver, just but not quite fitting in the ring, so out with the driver and ring, deburr the ring so it has a nice smooth edge, then lightly sand the edge of the driver, working and checking till its a light interference fit in the ring.
Poke the led wires through the holes, then fit the driver in the ring and solder the negative connection to the ring, if your driver needs it, solder on the positive spring.
Now, I mentioned a u3 1c… You can use either a 16mm board like me, or the 20mm board the pill is designed for, it doesn’t matter. The pill has a plastic centering piece that fits around the led die, there’s enough clearance for the wires on a 17mm board.
So wire in your led, stick a bit of thermal paste (i used diamond paste from maplin) and the pills prepped.
Reassemble the light and your ready to test.
The keygos cell I had in didn’t want to give more than 2.5a, but its quite run down, with a charged king Kong and the driver set to ramping, I can go from no reading up to 3.67a 8) (did I mention I love this driver? Well I do)
What’s noticeable is at mid way through the ramping, the beam looks light a stock m10, as it ramps to full the hotspot seems to increase in size and intensity with the spill brightening up some, this was all checked in day light. I now can’t wait for half four when it’ll be dark.
So there you go, any 17mm driver cam be fitted with a bit of care and some sand paper.
And the m10 driver? That went in my uf-v3 for a bit of a kick in the pants, took about ten minutes, so, two modded lights in an hour and a half including playing, not bad for a noob. Steve
Edited by: gords1001 on 12/05/2012 - 11:17
BIGWOOD
BIGWOOD's picture
Those upgrades makes the M10 the perfect C8 sized light IMO. Great job.
Any word when IntO will be getting more of those drivers? Anyone?
JohnnyMac
JohnnyMac's picture
Last seen: 6 days 12 hours ago
I've contacted them again asking when these will be in and am waiting for a reply.  I asked them almost 3 weeks ago and at that time they said the following week.  Obviously that never happened.  I sure hope they get more in.  I have one that arrived 2 days ago but I haven't tried it yet.  This could be the perfect driver so I hope they can get more and continue to carry them in the future.
BTW, nice job, Graham!
Ubehebe
Last seen: 7 years 3 months ago
Nice job. I’m waiting for a driver to do the same thing to my m10. Great light, just a little underpowered.
garrybunk
garrybunk's picture
Last seen: 2 weeks 4 days ago
Great job!  Thanks for detailed pics!  Now I'm ready to receive your "1000 posts giveaway light" Smile
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
gords1001
gords1001's picture
I’m ready to recieve the 1000 post light to mod tbh, bloody post….
apt323
apt323's picture
Last seen: 1 month 5 days ago
Nice job, thanks for the post and pics!
Pulsar
Pulsar's picture
Last seen: 5 months 3 days ago
thanks for the info. i was thinking of getting one of these, but sold out and not sure if they would fit in the pill i was going to put it in… may have to keep an eye out and grab a couple when they are back
gords1001
gords1001's picture
The driver is quite tall, I’ll take a picture of one of my others, mrsdnf measured it at 10.9mm, so some pills including p60 pills won’t take it, modding the m10 this way, the pill is plenty deep enough.
MarioSS
MarioSS's picture
Last seen: 6 years 2 months ago
Thank you sir Smile
Im still waiting for my m10 to arrive tho. Great writeup for us noobs who’s willing to learn
likeaboss
likeaboss's picture
Last seen: 11 months 4 days ago
Is the driver regulated?
Candlepower (abbreviated as CP) is a now-obsolete unit which was used to express levels of light intensity.
Candlepowerforums (abbreviated as CPF) a website, also obsolete, drive
gords1001
gords1001's picture
Yes, to 4a, although of the two I know of, we’ve both gotten between 3.6 – 3.7a max. I can live with that for an xm-l, I wouldn’t want it in a p60 though tbh, it will generate a lot of heat, I’d be looking to see it in an hd2010 or I’m thinking it’d be good in a zy-t08.
garrybunk
garrybunk's picture
Hey gords, what is a stock M10's driver like?  How hard is it driven on high?  How are the stock mode spacings? (High & Med too close?  Low not a real low?)  Did you replace the driver just because of the blinkies or was it to drive it harder?
Thanks bud!
-Garry
gords1001
gords1001's picture
Hey Gary, the m10 driver does 2.5a on high, so a boost on my uf-v3, same five modes with a nice medium and a lowish low, it suits the uf-v3 better than the m10 for sure, I mainly fitted it because its a five minute swap (press in, press in retaining clip, solder led wires) and its added another .7a to high, I’ve not really played with it because its chucking it down with rain or snow and I’m too busy playing testing the m10, I love the low available on the ramping set up, you can stare at the die and see the led wires.
This driver really is good, grab some while their available but do order the ramping one, the three modes are so so, I’ve not even tried the various blinkies but there is a beacon mode available if I remember correctly. It’s made a good light a brilliant light. 8)
garrybunk
garrybunk's picture
I'm now wondering how the M10 compares with a TF A8 for beam pattern.  Wondering if the M10's beam is wider (more / brighter spill). Any idea?  How would you describe the beam pattern of the M10?  (And consider in view of using it as a bike light.)
2.5A on high isn't too bad; conserves a bit more battery to increase runtime while still being darn bright.  Gonna have to put this on the short list!
-Garry
gords1001
gords1001's picture
I’m not sure compared to the a8 yet, I’ve not got one…yet.
As a bike light, cehoward loved it (which has been bothering me, he’s not been on for weeks, hope he’s ok) I’ve used mine as a work light, under vehicles with it set according to ambient conditions.
The beam is pretty good, no rings, tight hotspot, fairly throwy, think c8, the reflector is deeper but about the same diameter, it has a pretty tight hotspot and a bright spill on high. As a general purpose light, its one of my favorites, hence the give away. Small enough to tuck into a jeans pocket (as long as their not skinny jeans), runs on a 26650 so good runtime even when overdriven, well capable of handling heat, very robust, good threads. It’s everything a good budget light should be, with none of the flaws. It looks ace flamed too.
From left to right, uf-v3, keygos m10, jm05 clone.
garrybunk
garrybunk's picture
gords1001 wrote:
As a bike light, cehoward loved it (which has been bothering me, he's not been on for weeks, hope he's ok)
I've been wondering about him too!  Miss his excitement around here!
-Garry
gords1001
gords1001's picture
Tell me about it, hope he’s good. Sad
Pulsar
Pulsar's picture
like the heat treat you did on the m10… i been wondering if you had a incan mag modded with a hot enough bulb if you could get it to do the same thing on its own lol
gords1001
gords1001's picture
Mags don’t seem to bake so well, and to be honest, that took me a good twenty minutes with a blow lamp, to give you an idea of the heat involved. :bigsmile:
Pulsar
Pulsar's picture
i had my 502b in the oven on broil for about an hour i think to get the color i wanted out of it. my GF was like why the F#@% is there a flashlight in the oven??
gords1001
gords1001's picture
Hence the blow lamp – saves explanations. :bigsmile:
gords1001
gords1001's picture
Ok, I decided to do a little test while I walked over to pick dyl up from scouts. It’s about ten minutes there and back.
I put in my freshly charged keygos 26650, I don’t believe it was as bright as the king kong, that’s now in the charger as I’ve used the light heavily today in work.
Anyway, I let the driver ramp up to high, stuck it into my pocket and held onto the head and set out.
When I got back, the head was lukewarm to touch, its throwy enough considering reflector size, the spill takes in both sides of a British teraced street – three car widths with passing space, plus six foot of pavement and lights up the houses on both sides.
I’ll try and get a high reading on the keygos cell tomorrow, see what current its prepared to give, but you definitely want good cells to get the best out of this driver.
In use, when you power up, it goes to the last saved output level, even after cell change. A half press goes into ramping, depending on if your above or below medium (indicated in ramping mode by three slow flashes) it will either reset to minimum and ramp to high or just start ramping up. To accept your light level, turn the light off then on. Your light is now one mode till you half press again. I like it as you can set your level and stick to it. For example I’ve been using it at night as a night light if Luke wakes up. I enter ramping, it does three slow flashes, turn off then on, I have a low output, like a 3 lumen ti. This is great for not disturbing people.
At work I ramped up to medium. This is ideal under vehicles and ceiling bouncing in the little boxes I was working in, just don’t look at it when you pick it up, you see stars. Steve I inadvertently found the flashy modes today too, didn’t pay too much attention, but to leave them find the solid output, let it quickly flash three times, turn off and on after two seconds (i counted to three to be sure) back to three mode, select low, three quick flashes, off on, back to ramping.
I think this driver is a brilliant addition to any c8 sized light that will take its 10.9mm minimum height. You need something with some meat to handle the max heat generated, but it does give you many options in one light, and as said in ramping, once you have your output, you have a one output light till you need to change. No need for two buttons, nice and simple. 8)
garrybunk
garrybunk's picture
Sounds great for the TF A8!
gords1001 wrote:
Ok, I decided to do a little test while I walked over to pick dyl up from scouts. It’s about ten minutes there and back. . . Anyway, I let the driver ramp up to high, stuck it into my pocket and held onto the head and set out.
Did anyone ask you why you had a flashlight on in your pocket??? Smile
-Garry
gords1001
gords1001's picture
No, but I was waiting for it….. I had a damm heavy duty 3/4 jacket on, weather proof, my work outdoor coat, the pocket was glowing and the light kept throwing beams about if I didn’t trap the lense in my palm, this meant the considerable heat building in the lense was letting me know the xm-l was getting its fair share of current even if it was not the most the driver can give… I need to meter it with a freshly charged keygos cell, see how good they are.
Flomotion
Flomotion's picture
Last seen: 7 months 4 weeks ago
Me, too, I broke down and ordered one, also. Got it on ebay from go_market, which is really a keygos marketer. Paid only 9.99 plus 9.99, so I think I got a bargain. Thanks for the advice on how to get stuff to fit. I have a bunch of C8s, but this takes a 26650 so is more flexible for a mod.
Flomotion
gords1001
gords1001's picture
If you like c8’s you’ll love it, I’m reluctant to give away the new one, it is my….precious. :bigsmile:
Seriously, its one of the most underrated lights, nice size, fits the hand far better than a c8, well designed reflector, good balance of spill and hot spot, pocketable. I could gush for hours, but I really just like them a lot, two for two recieved fully functional, easily modded, 18650 sleeve included, what more could you possibly want?
It looks damm good too, flames well, takes paracord, so custom lanyards are an option, it really is Cinderella of the budget light world.
I don’t like them really…. 0:)
likeaboss
likeaboss's picture
Can you give the dimensions of the reflector?
gords1001
gords1001's picture
I can strip one and measure, roughly its 10mm deeper than a c8 reflector, same I’d but i’ll confirm that for you. Just not tonight, had the kids all day, I’m too drunk now… :bigsmile:
hoffig
Last seen: 2 years 3 months ago
Diameter of the reflector is about 41.5mm and the height 31.5mm ie. pretty much the same as my KD C8 has.
I’m going to change a driver too, my original measures about 1.8A at high, has blinkies and no memory (starts always on the next mode! I could live with it always starting at high but not with this.
gords1001
gords1001's picture
Buy this driver! Its the best thing you can do to an m10, if I did it over, I’d sacrifice the extra lumens over a t6 3c emitter but I’m good with cw so I’m happy. It’s certainly dampened my spirit for splurging on an xintd c8..
