NOW 70% OFF COUPON!! DIY TorchLite 2x26650 XM-L, SST-90, SST-50 etc Host!
476 posts / 0 new
EDCPlus
Last seen: 6 months 3 weeks ago
Hi Guys,
1/30/2014 — Coupon now @ 70% off!!
I just recently got these TorchLite DIY hosts in stock. The bad news is, it looks TorchLite went out of business! Sad
The good news is you can snag one of these awesome 2×26650 DIY hosts at below wholesale cost! :bigsmile:
Use the coupon code TORCHLITE to get 70% off one of these great DIY hosts, before they are gone forever!
Click the EDC+ logo below to order!
Edited by: EDCPlus on 01/30/2014 - 19:36
FMcamaroZ28
FMcamaroZ28's picture
Last seen: 11 months 3 hours ago
Looks cool.
What size driver is needed?
EDCPlus
FMcamaroZ28 wrote:
Looks cool.
Good question. It will fit drivers up to 23mm wide and about 15mm tall.
scaru
scaru's picture
Last seen: 5 years 1 month ago
So when you say a driver plate is includes does that mean it has a large cavity and you connect your driver to the driver plate? Just trying to understand it. Smile
Richie086
Richie086's picture
Last seen: 1 hour 17 min ago
I will say this, that brass pill with all those fine threads must be great for heat dissipation.
Richie
EDCPlus
It’s a round PCB board with gold contacts where you can solder the spring onto, then the driver can go underneath it. You don’t need to use it, but its an option. A lot of production lights have the driver, and then have another board under the driver where the spring is attached too. Hope that makes sense.
Richie086
Richie086's picture
Hi folks,
Jason is talking about what’s in this photo below.
Richie
EDCPlus
Richie086 wrote:
Hi folks,
!http://i42.photobucket.com/albums/e309/Trek13/Torchlite_zps22ec0f15.jpg!
Thanks. The green board with the spring on it is included. I’m not sure what the other white looking plastic thing around the board is. That is not included.
Also the light in the picture is of the single cell torchlite which is not available.
scaru
scaru's picture
I understand what you are talking about but what is in that picture is not it. That is a tailcap switch. The white thing holds it in space and the little wire you see going down the side is where the switch is attached to the board.
EDCPlus
I guess you are right, but the green PCB board and spring in that picture though look just like the one that is included for use in the heatsink / driver.
The switches that came with these lights look different than the one in that picture.
scaru
scaru's picture
EDCPlus wrote:
I guess you are right, but the green PCB board and spring in that picture though look just like the one that is included for use in the heatsink / driver. The switches that came with these lights look different than the one in that picture.
Here a large picture is with things labeled. If you want I'll take a picture of one of my switches.
EDCPlus
What I was saying is the board and spring (which you pointed out is actually part of the switch assembly) is very similar to the board and spring that is included for the driver contact board.
I snapped a picture of the board and spring that are included.
Hopefully that clears up the confusion.
JHBUDGETLIGHT
Hard to tell but it looks like the smaller head. If you have the larger head (I believe called the “shooter” or as an option), let me know and I’d be in for one.
http://www.candlepowerforums.com/vb/showthread.php?309639-SOLD-XM-L-T6-Shooter-1000-lumens-for-26650-battery
Would love to have one with more throw and a long runtime.
Any driver you would recommend that could handle 8.4V and run at 2.8 amps?
EDCPlus
Hi, I have a shooter on hand (a sample) and the head size is exactly the same. The ones I’m selling here just have a longer body tube to accommodate 2×26650’s.
If you are interested in the smaller shooter I can sell you the sample I have, its in good overall shape but has one tiny nick in the front bezel. I’d sell it for $35 shipped (USA only).
As for drivers, I have not used this, but something like this: http://dx.com/p/6-18v-3000ma-3-mode-circuit-board-for-xm-lt60-emitters-5...
Here is another one: http://dx.com/p/3v-12v-2500ma-5-mode-led-driver-board-162784
gords1001
gords1001's picture
Last seen: 3 years 7 months ago
http://www.intl-outdoor.com/ld29-28a-12-cell-circuit-board-p-416.html
I would go with this driver myself as you can hide the blinkies, its also current controlled on all modes (no pwm) I’m just going to have a look how much this host is because I like the look of it a lot.
EDCPlus
Yep, looks like that will work well too.
Richie086
Richie086's picture
Hi Jason, just made my purchase from your website. Thanks for offering this nice DIU lighting kit.
Richie
Richie086
Richie086's picture
Just received my TorchLite 2×26650 today. Aside from having to purchase an LED and driver for it, I’d say this light is easily worth much more than what we’ve paid here.
The anodizing is flawless with anodized tail threads too, but does need some lube. I can already tell this light will have great heat dissipation with all the contact area the way the pill screws directly into the handhold. The handhold then screws into the head which has a great deal of very fine threads. It actually takes a bit of time just to unscrew it from the head.
The reflector is very deep also, much more than my Small Sun ZY-T16. It’s about 51mm deep and about 46mm at the widest point. Should make a heck of a nice thrower with a high end Nanjg driver.
Thanks Jason!
Richie
dthrckt
dthrckt's picture
Last seen: 6 days 17 hours ago
my trigger finger’s REAL itchy
could you show a pic of the bottom of the reflector, and maybe how it fits in the head?
i’m thinking mt-g2 for this puppy J)
Richie086
Richie086's picture
Hi DT,
Here you go. The actual reflector simply drops into the head, then the bezel is screwed on. The Torchlite is also about 30 grams heavier than the Small Sun ZY-T16.
Richie
peterloron
peterloron's picture
In for one!
This should be amusing. Now to track down a driver and LED
dthrckt
dthrckt's picture
perfect photos. exactly what I needed. thanks very much.
as part of my new practice of controlling impulses, i will wait at least 10 minutes before ordering 0:)
Richie086
Richie086's picture
Updated my photos in post 19 to show the large size pill.
http://budgetlightforum.com/node/16316#comment-285664
Richie
eebowler
eebowler's picture
Last seen: 1 week 6 days ago
I’m impressed by the ’6 layers of anodizing’!
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
FMcamaroZ28
ordered.
What “hot rod” driver is everyone using?
will this one work? Looks like it does 3.5A!
http://www.intl-outdoor.com/xml-multicell-circuit-board-35a-ouput-55126v...
Oh and Fast-Tech has the LD-29 that was posted above for cheap.
http://www.fasttech.com/products/1612/10001997/1143100-1-2-lithium-2-gro...
peterloron
Lol! I was just sitting down to write that exact post!
My host should be here early next week. I’d like to get a driver and LED combo that will really make use of the 2×26650 batteries. I can weed through the various reviews and sites, but I’m sure the DIY Gurus here have some particular units that have risen to the top…
Suggestions?
-Pete
MRsDNF
MRsDNF's picture
[quote=FMcamaroZ28]ordered. What "hot rod" driver is everyone using? will this one work? Looks like it does 3.5A! http://www.intl-outdoor.com/xml-multicell-circuit-board-35a-ouput-55126v... Oh and Fast-Tech has the LD-29 that was posted above for cheap. http://www.fasttech.com/products/1612/10001997/1143100-1-2-lithium-2-group-35-mode-28a-led-flashlight-dri[/quote]
That driver is out of stock.
Richie086
Richie086's picture
FMcamaroZ28 wrote:
ordered.
That first one is the one I was going to order myself, but as previously mentioned, it’s out of stock. So I’m going to take a look at what Kaidomain has on hand. However, according to the specs for the pill, either would have worked. Just keep within the following specs and you’ll be fine.
*_Downside Inner Size(for driver board): 24mm(Dia.)×15.5mm(Depth)
Upside Inner Size(for LED board ):21mm(Dia.) × 6mm(Depth)_*
Richie
nqcken
Last seen: 1 year 1 month ago
so, the burning question is: should a rank amateur such as myself pick this project as a first flashlight project? can you get suitable leds that are already soldered to a star to use in it? think beginner here. thanks. i would love to have a hopped up 2×26650 light on my telephone stand.
ken
Richie086
Richie086's picture
ken
Hi Ken,
As long as you can do some simple soldering, I don’t see it as a problem. You can easily purchase an LED mounted to a star already, which I’m sure is what most will do. For example, I want my XM-L to have a warm tint, so I’m going to go with something like the 20mm version of this XML from CNQualityGoods.
http://www.cnqualitygoods.com/goods.php?id=1831
Richie
nqcken
yes, i think i can manage the soldering. this sounds like it could be fun…… and open up even more wasy to sped money and time on flashlights. Smile thanks
ken
