NITECORE T2s
Redone after fixing problem. Legend: Red = omitted, Green = Revised
Overall Rating: ★★★★★ ★★★★★
Summary:
Battery: | 1 x AAA |
Switch: | Head twist |
Modes: | High, Med, Low, High/Low slow flash signal |
LED Type: | 1 x CREE XP-E R2 |
Lens: | AR Coated Glass |
Tailstands: | No |
Price Payed: | $32.50 |
Date Ordered: | 18 November 2012 |
Pros:
- No visible PWM
- Comes in nice box
- Reverse polarity protection
- Good mode brightness spread
- Light (mass)
- Small
- Waterproof
- Comes with spare o-rings and pen clip
Cons:
- BAD TWIST SWITCH OPERATION
- Expensive
Features / Value: ★★★★★
The packaging of the T2s is nice, though they didn't bother to change any words from the original T2 so the box still says T2 instead of T2s.
The T2s comes with one o-ring, one small key chain ring and a pen clip that clips around the T2s. It did not come with a lanyard.
Pricing of the T2s makes it not very good value and I don't think its worth it unless you really like the Nitecore brand.
The T2s does have some nice modes, if you can switch to them (more on this in design). The low mode is pretty low at 2 lumen.
The pen clip makes it easy to have the T2s sitting in your shirt pocket but if you're like me and like EDCs on a keychain you need to get your own lanyard.
T2s is AAA only.
Design / Build Quality: ★★★★★ < Burnt orange for half star ★★★★★
The build quality of the T2s is very good but something went very wrong in the design of the twist switch. If it is just my T2s that has the problem then it is actually a build quality problem instead of design. T2s has a very smooth outer body, too smooth in fact, the head has no knurling whatsoever so it is difficult to operate one handed. Threads came well greased.
It is the same width as the X3 but it is only 1mm taller.
I think somewhere here above is where my T2s has a big problem, the twist switch has a flaw that makes it very hard to change modes and the emitter flickers because it turns on before the head is twisted all the way down.
Before I go into further detail about this flaw I'm going to say my Solar force X2 and X3 have the same kind switch design and work perfectly. My Balder TD-0 I just got today uses a different twist switch design and turning on/off and changing modes feels so good.
So the Nitecore T2s has problems turning on, off and changing modes. How, you ask? I think it has something to do with not having a clear on/off point. For example, my SolarForce X3 is either on or off. The T2s however, goes half on and flickers as you turn the head down. When the head is fully down as far as the battery allows it works fine. But when you twist the head up to turn it off or change modes it starts to flicker again. Changing modes is very difficult because of no clear on/off point, you either turn it half off then back on again but the light didn't change modes because all it did was flicker and didn't actually turn off. Or you twist past the flicker and the light turns off, but it turns off for too long and when you turn it on again the light starts back up on high mode. It is very frustrating getting the light to change modes, it can be done but its just very hard to get it right.
The above is the only flaw I had with the Nitecore T2s, too bad that is a very big flaw that gives anyone trying to use the light a hard time.
If anyone knows how to fix the problem I would appreciate it a lot, its really a waste to buy a $30+ flashlight to only try use it a few times but put it away without using it as my EDC which I had intended to use it for.
After looking at the flashlight carefully, I noticed on the inside of the battery tube where the negative contact is, there was a wire or metal shaving. I looked at my SolarForce X3 to compare the negative contact design, they were similar but SolarForce's design looked much more robust. I took a small screwdriver to the Nitecore T2s and I found out the negative contact and its rubber spacer could be removed. After I took out the negative contact assembly, I inspected it but could not find anything wrong with it. I then checked for the metal shaving, but I couldn't see it so it must of fallen out. I put the negative contact and the rubber spacer back in then tested the flashlight. I was pleasantly surprised to see that the flashlight no longer flickers or has trouble changing modes. Still, the design of the Nitecore T2s worries me if a single tiny metal shaving can ruin the operation of the T2s.
In the looks department the T2s' design is simple just some knurling on the body and a place for a lanyard to go through. Only missing something for grip on the head.
Battery Life: ★★★★★
Battery life is good in the T2s, with claimed 28 hours on low with a single AAA
High mode has 1.5 hours runtime and medium has 3.5 hours.
Light Output: ★★★★★
At 50 lumen this isn't the brightest single AAA, but it does have good mode spread, 20 lumen medium and 2 lumen on low.
The semi OP reflector does an ok job at smoothing the light beam
Amps: 1.4 on high, 0.2 on medium and 0.02 on low
Summary:
I really like the flashlight, the price doesn't really justify it though. Its a real shame it doesn't work properly. I'm not sure if its just my T2s or the whole batch but at this point its not worth buying one.
It works like you would expect a quality flashlight to, but it has nothing special about it.
Thank you for reading.
