What is the brightest budget light?
219 posts / 0 new
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 4 years 3 months ago
Here's a few pictures of the KEYGOS XM-L T6.
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS
VFMaddict
Last seen: 2 years 9 months ago
ILIKEFLASHLIGHTS wrote:
That looks like a brass pill from this pic.   The line of the pill is the last ring before the body tube.   Does it look like brass to you?
And is the lens glass and the reflector aluminum?
I'm starting to get very interested indeed......Smile
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
ILIKEFLASHLIGHTS
Yes it definately is brass.  Lens is glass and reflector is aluminum.
ILIKEFLASHLIGHTS
I'll tell you what if you could put a head and reflector on this little light like a Catapult V3 this thing would throw a beam probably 400yds.
ILIKEFLASHLIGHTS
Here's the auction I won on ebay and the guy I recommend you to try and buy from.  He is extremely good and fast.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150637510563
vawayne
vawayne's picture
Last seen: 11 years 2 months ago
Man this place is addicting.. my wife does not understandLaughing ..LOL
Also were can I get those glow ring gaskets I want to put one on this light
to match the green power button..
ILIKEFLASHLIGHTS
You will love that light.  That green tail switch glose in the dark as well.
vawayne
vawayne's picture
can I find a glow  o-ring for the front of the light
ILIKEFLASHLIGHTS
Email the seller and ask.
2100
Last seen: 6 months 1 week ago
VFMaddict wrote:
That's a different light altogether.  Yours is a clone of this U80.   Even it being a clone of the U80 means very little as totally different drivers may be being used.
The U80 has a PWM of 500Hz, just for info.  It is the fastest of all my budget chinese lights.  And besides the U80 has really good built, HA, anodized threads which are super smooth when you screw on the tailcap etc.  It is definitely 1 level above my Sky Ray SR3800 if you look at the cutting/detailing.
Pitoar
Pitoar's picture
Last seen: 9 years 9 months ago
znmzdx wrote:
There are many good bright flashlight ,
TrustFire C8 3-mode High Power P7 900-Lumen LED Flashlight $36.54
TrustFire TR-650 4 Cree P4 3-Mode 650-Lumen LED Flashlight $40.99
TrustFire ST-50 LED Flashlight Black $79.99
TrustFire X2 SST-50 40-Mode 1300 Lumens LED Flashlight Black (3x18650) $128.99
you can have a look !
The page cannot be found,
After google them I like the last one -- TrustFire X2 SST-50 40-Mode 1300 Lumens LED Flashlight Black (3x18650)
the same from http://budgetlightforum.com/node/361znmzdx
DX sells it at $110.70, is it worth buying?
To be best myself
shao.fu.tzer
shao.fu.tzer's picture
Last seen: 8 years 6 months ago
The Sky Ray 818 that I purchased from Manafont was only ~$57 and it absolutely blows everything else that I own out of the water (and I own a large number of $200+ lights).  It lights a room like a 60W light bulb!
Shao
hopp2
Last seen: 11 years 3 weeks ago
um, I'm want to ask my teacher.
joe1512
Last seen: 3 years 7 months ago
Well since this thread was necroed, nowdays the triple XM-Ls are the best bang for the buck.  For 50 to 70 bucks, you can crank out 1500ish lumens.  Not bad!
sofelix
Last seen: 10 years 11 months ago
i dont think the brightest flashlight is the best flashlight, the one fits for you perfectly is the best one for you.
beamshot
Last seen: 1 year 9 months ago
If you want a very good thrower flashlight with a reasonnable price go with FandyFire STL-V6 (Deal Extreme) or SkyRay STL-V2 (Manafont) (same flashlight just different brand), http://www.dealextreme.com/p/fandyfire-stl-v6-cree-xm-lt6-2-mode-1000-lumen-white-led-flashlight-2x18650-3x16340-3x123a-91137
Don't check just the number of lumens because biggest is the reflector ,more it's bright (for the same LED) and often the manufacture overate there lumens. For a xml-t6 with the same driver ,one have a 50mm SMO reflector vs an 61mm SMO reflector, the 61mm is more bright for a more long distance.
For exemple i have this flashlight http://www.ebay.ca/itm/350455644753?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
But it's not an SST-80 because it don't exist, it's an SST-50 by luminus brand. I have modified the LED for an XML-T6 with the same driver of this flashlight....simply AMAZING!!!....more bright, more distance and the hotpot is more concentrated in center ,all of this with less curent, less heat and amazing distance with more longer autonomy!!!! i have 2 others flashlights with the same driver and the same XML-T6 and work with 2x18650, but with two different reflector....the big is more bright ...and the distance is more further because the reflector take more brightness for projection.
For exemple if you check a XML-T6 flashlight rated at 1600 lumens (overated) and an other with same LED same Driver rated 1000 lumens but the first one have a more little reflector that the 1000 lumens, more chance that de 1000 lumens come to be more bright and more further distance...you know.
nice to meet you boys.
baumgar
Last seen: 10 years 9 months ago
That's really bright! I thought it was a car light.
dthrckt
dthrckt's picture
Last seen: 1 week 2 days ago
http://budgetlightforum.com/node/6060
raccoon city
raccoon city's picture
Last seen: 1 hour 13 min ago
Location: Palm Desert CA ~ West Coast is the best coast
kaqiusha wrote:
FEREI 700 CREE Q5 2-Mode 120LM LED White Flashlight
My friend has this :FEREI 700 CREE Q5 2-Mode 120LM LED White Flashlight
on http://www.bladebargainsucks.com/ferei-700-cree-q5-2mode-120lm-led-white...
He said this one is very powerful , i do not know if this the brightest one here.
cheap and very good FEREI 700 CREE Q5 2-Mode on bladebargain.com
120 lumens ain't that bright, PAISLEY enthusiast.
Komichi
Last seen: 4 years 4 months ago
I think he's PAISLEY too. I've seen three of his five posts all with pictures (none personal) with two links to the same seller.
cabfrank
blinding!
must be low mode.
jacktheclipper
jacktheclipper's picture
Last seen: 8 hours 16 min ago
What I do
kreisler
kreisler's picture
Last seen: 8 years 11 months ago
by the way, how does the paisley pattern relate to spam? ( i dont get it or i lost it )
Smile
*FMI* i got 4 i/o sh
jacktheclipper
Foy's response to a spammer when asked " What is your favorite "
He replied " I lke walks on the beach , sushi , and things that are paisley ."
What I do
2100
It should be the DRY now.  $65 shipped, 2500 lumens OTF.   $38.4 OTF lumens per dollar.  Remember, it is OTF.
Throw it would be the $85 shipped Dereelight DBS aspheric with EZ900 XR-E.  95k cd (some more, some less).  Cheaper bracket would be the Small Sun ZY-C10-S (45k cd?) at 14 bucks.
cabfrank
where is the DRY available for $65 shipped?
Trancersteve
+1
I wear my sunglasses at night.
matjok
matjok's picture
Last seen: 6 years 11 months ago
Trancersteve wrote:
+1
It was the group buy price, but it ended.
