16340 to 18650 adapter sleeve
11 posts / 0 new
bushwhacked
bushwhacked's picture
Last seen: 6 years 6 months ago
I’ve done a few searches and found nothing promising. Anyone know where i can find a sleeve to change 16340 to 18650 for around 2 or 3 dollars.
The ones on overready are too expensive and I’d be better off buying a host with included sleeve. That may be my only option it looks like.
P60dropins.com (just a redirect for now)
nikanon
Last seen: 6 years 2 months ago
I think someone suggested paper lately or maybe you could use shrinking tubes, this would be the diy solution.
bushwhacked
I’ve been using tape for my smaller 18650 to reduce the rattle, but with 16340 it would be a lot of tape. I suppose I could try a few other things but looking for a simple and reusable method.
scaru
scaru's picture
Last seen: 5 years 1 month ago
You could just use some paper to shim it...
bushwhacked
I think for now I’ll use straws until I get a spacer. Long as they don’t rattle I’m fine.
Orion
Orion's picture
Last seen: 7 years 9 months ago
bushwhacked wrote:
I’ve done a few searches and found nothing promising. Anyone know where i can find a sleeve to change 16340 to 18650 for around 2 or 3 dollars. The ones on overready are too expensive and I’d be better off buying a host with included sleeve. That may be my only option it looks like.
The oveready ones are in Delrin and $10 each:
http://www.oveready.com/battery-/sleeves-spacers/123-delrin-battery-slee...
But check e-cigarettes about this guy who can make adaptors to fit any-size Li-on to fit 18650 devices :
http://www.e-cigarette-forum.com/forum/reos-mods/171686-coolest-battery-...
“It is a far, far better thing that I do, than I have ever done; it is a far, far better rest that I go to than I have ever known.” – Sydney Carton in ‘A Tale of Two Cities’ by Charles Dickens (1812-1870).
bushwhacked
I was cleaning out the junk drawer in my kitchen today and found my wifes’ baking glitter/sprinkles. They were stored in tubes that looked to me like an 18650, out comes the calipers.
They measured 19.4 outside diameter and 16.5mm inside diameter and 70mm long. I believe she got them from the dollar store and theres more then one.
So I’ll be sanding the outside a bit and will have to use a small bit of tape but it should work. Hardest part is going to be cutting bottom off without crackin the tube. Hack saw really slow should work.
If it works well ill take pics and make a photobucket account to post them. Just thought I would share.
The sprinkles are in the garbage now just fyi…
brad
brad's picture
Last seen: 14 min 54 sec ago
What if you use a grinder to make that cut, and should you tape it before cutting?
Not what we have but what we enjoy, constitutes our abundance.
bushwhacked
Good idea I’ll definitely tape it, I think I’ll try the hack saw first and if it doesnt work I’ll try a grinder.
bushwhacked
Dx offers these now as well as a few other conversions. I just ordered a couple. Will post in a few weeks when they arrive.
http://dx.com/p/plastic-2-x-16340-to-18650-battery-holder-translucent-2-...
cjoe7
Last seen: 2 years 1 month ago
I purchased these earlier and they are for 18650 to 26650 conversion.
Still looking for 16340 -> 18650 battery tubes
