Romisen RC-C6 but in 1AA form factor at Manafont
18 posts / 0 new
Vectrex
Vectrex's picture
Last seen: 9 months 6 days ago
Manafont is offering a Romisen RC-C6 in 1AA form factor. The RC-C6 in 123 variety is well known, but the 1AA I have never seen before. I like the RC-29 except for the very sharp tail switch.
sb56637
sb56637's picture
Last seen: 17 hours 50 min ago
I saw that too, but I wondered if it was mislabelled. If it had multiple modes I would buy it in a heartbeat.
Vectrex
Vectrex's picture
The pictures and the length make me believe, that it is indeed a 1AA.
It seems that Romisen just made the front barrel of the body longer.
                        1AA (full flood - shortest)        123 (full flood - shortest)
frills
Last seen: 8 years 11 months ago
The extension tube from the RC-N3 threads onto the CR123 C6 and lets you run two AAs in it. I imagine you'd need a spacer to do the same with this one.
Oxy Moron
Oxy Moron's picture
Last seen: 3 years 4 months ago
It's probably the real deal. I remember a thread over on the DX forums about a AA version. I can't seem to find it now but it must have been at least a year ago, if not longer.
I'm definitely tempted to buy this light, even though I already own a RC-C6 which I haven't seen in ages, now that I think about it. From what I remember, it got quite hot fast on a fresh 16340 so it should be interested to see if the AA version can take a 14500 without frying itself.
josith
Last seen: 8 years 5 months ago
i emailed manafont and their customer service guy, Jim, replied that this is indeed an AA version, not mislabelled.  I forgot to ask if this light support 14500 though.
Vectrex
Vectrex's picture
No spacer needed imo .... look at the wall thickness of the body.
The 123 is 3 mode the AA is 1 mode BTW.
This seems to be a new batch, the old C6 had anodized threads.
sb56637
sb56637's picture
This Manafont version looks a lot nicer than this version with the ridiculous fins on the tail. This is a pretty good deal for a Romisen.
This has a rotating zoom instead of a push/pull zoom, correct?
cessnapilot
cessnapilot's picture
Last seen: 4 years 6 months ago
I have never used a romisen rotating zoom, is it quick and easy like the push pulls?
About how many turns stop to stop?
sb56637
sb56637's picture
The idea of a rotating zoom appeals to me, because it will stay that way even in storage, it's harder to change by accident, and it's more precise.
Don
Don's picture
Last seen: 11 months 4 weeks ago
Just under three turns from full flood to full zoom. Personally, I prefer this to push-pull.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
frills
I meant for length, since the extension tube is longer than needed for one AA because it also has to accomodate the extra length of the first AA that sticks out of the CR123 head section. It works the same way it does on the RC-N3 with its CR123-sized front section.
cessnapilot
Do you guys think a 14500 would work?  If so I am going to order it to compare to my C78 which I love for its size.  I am trying to find the perfect AA zoom to give as gifts to everyone
Vectrex
Vectrex's picture
The AA version doesn't need an extension,  the body is simply longer. I also assume the bore of the body is smaller... so an 123 would not fit the AA version, that's why I mentioned the thickness of the walls. They should have called it the c7 or c9 to avoid confusion. Also the threads on the new AA c6 and 123 c6 seem incompatible with the old 123 one. Current runs through the threads on the new ones and through the clicky plate on the old ones (anodized threads). Completely different lights.
mfm
Last seen: 9 months 4 days ago
This one works with 14500: http://www.dealextreme.com/p/romisen-rc-29-cree-q5-wc-3-mode-180-lumen-c...
For gifts I'd buy the single-mode one though.
NiBi
Last seen: 7 years 7 months ago
I know the rc29  and could not resist i ordered one .just to have a look at itLaughing . we will see.Wink
AAA: Black Cat   AA: SkyRay S-A1,  Uf 501c (2AA Q3),   18650: Uf 501b (Xenon),Uf 504b (R5), SkyRay S-R5 , TR801, SkyRay 1JC8
frills
I think we're getting our wires crossed here. I'm talking about putting TWO AA cells into the light. You can use the extension tube of the RC-N3 to do this with the CR123 version of the C6. It works because the N3 is itself a CR123-to-2*AA converting light, so the tube is just the right length.
Vectrex
Vectrex's picture
Ah OK, I thought it was clear with the title of this thread that the "Romisen RC-C6 but in 1AA form factor at Manafont"  is discussed here. Wink
Also with the new tail-threads, I doubt that any existing extensions would fit.
