Test / Review: Sanyo 18650 2600mAh (Red) bv
20 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 19 hours ago
DSC_0521
Official specifications:
  • Li-ion 2600mAh 18650 cell - SANYO, Made in Japan
  • Product Name : SANYO Lithium-ion Rechargeable Battery
  • Model : SANYO MB5M40
  • Norminal Capacity : 2600mAh
  • Diameter : 18.22mm
  • Height : 69.21mm
  • Weight(Typical) : 1.6OZ
  • Charge Method: Constant Current and Constant Voltage(4.2V)
  • Nominal Voltage : 3.7 V
  • Max. Charge Current : 1CmA(2600mA)
  • Max. Disharge Current : 2CmA(5200mA)
  • Discharge Temperature : -20°C ~ +60°C
  • Energy Density : 565Wh/I, 215Wh/kg
  • Charging Time : 3hrs(Standard) or 2.5hrs(Rapid)
  • MADE IN JAPAN
Sanyo%2018650%202600mAh%20(Red)%20bv-info
This battery has a very solid build, the disadvantage of this build is the length of the battery.
DSC_0520
DSC_0522 DSC_0523
The button top is high and larger in diameter than normal button tops.
DSC_0524
DSC_0525
The battery has a clear outer wrapper.
Sanyo%2018650%202600mAh%20(Red)%20bv-Capacity
Sanyo%2018650%202600mAh%20(Red)%20bv-CapacityTimeHours
Sanyo%2018650%202600mAh%20(Red)%20bv-Energy
Sanyo%2018650%202600mAh%20(Red)%20bv-PowerLoadTime
Sanyo%2018650%202600mAh%20(Red)%20bv-TripCurrent
Sanyo%2018650%202600mAh%20(Red)%20bv-Charge
Conclusion
This battery uses a very good cell, but does not fit in all equipment due to the length.
I will rate this battery very good, with the exception of the length.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
Shadowww
Last seen: 15 hours 39 min ago
Hey HKJ, are you sure that’s a 2600mAh cell?
Judging by color (orange), it looks like 2800mAh (4.3V) Sanyo UR18650ZTA. Maybe you could check label on shrink wrapper of cell itself?
I’m afraid you would have to remove outer clear wrapping in order to do that, though.
scaru
scaru's picture
Last seen: 4 years 12 months ago
Shadowww wrote:
Hey HKJ, are you sure that's a 2600mAh cell? Judging by color (orange), it looks like 2800mAh (4.3V) Sanyo UR18650ZTA. Maybe you could check label on shrink wrapper of cell itself? I'm afraid you would have to remove outer clear wrapping in order to do that, though.
I think HKJ is right, look at Fasttech's UR18650ZT.
Different button top and base plate on the UR18650ZTs from Fasttech. (This is obviously inconclusive, but I would guess they are 2600 mah ones)
HKJ
HKJ's picture
You are correct, they are 2800 mAh cell at 4.3 volt, but because they are sold as 4.2 volt batteries the capacity will be lower.
I have changed the info box to reflect this.
Shadowww
Neither button top and base plate are part of cell itself though Silly
Edit: just a minute ago, I was confirmed to be right Silly Big Smile
scaru
scaru's picture
Shadowww wrote:
Neither button top and base plate are part of cell itself though Silly Edit: just a minute ago, I was confirmed to be right Silly :D
Damn, you were right. Sad I know they aren't part of it, I just guessed they all got the protection circuit applied in the same place so all UR18650ZT would have the same ones. But I was wrong. Yell
AlexHH
Last seen: 2 years 1 month ago
Where can I purchase these? I didn’t see a link in the first post…
Nice review as everytime!
~ carpe noctem ~
scaru
scaru's picture
I don't know where HKJ's came from, but Fasttech does sell protected UR18650ZT.
http://www.fasttech.com/products/1420/10001901/1143804-sanyo-ur18650zt-1...
HKJ
HKJ's picture
AlexHH wrote:
Where can I purchase these? I didn't see a link in the first post... Nice review as everytime!
I do not include a direct link, but there is a web address in the info box.
It looks like they have changed the description and also the protection, since I bought the battery. Now it says 2800 mAh, but it forgets to say 4.3 volt.
Shadowww
HKJ, is there some reason why Sanyo batteries always measure less in your tests than others? I.e. Sanyo 2600mAh measures just 2300-2400mAh, while for others (me included) they consistently measure 2500mAh+ (as they should, according to datasheet).
All others (Panasonic, LG etc) seem to measure much closer to other people’s tests.
HKJ
HKJ's picture
Shadowww wrote:
HKJ, is there some reason why Sanyo batteries always measure less in your tests than others? I.e. Sanyo 2600mAh measures just 2300-2400mAh, while for others (me included) they consistently measure 2500mAh+ (as they should, according to datasheet). All others (Panasonic, LG etc) seem to measure much closer to other people's tests.
I do not have any explanation for that.
Generally I split my batteries between two test stations, one for 2800+ batteries and the other for anything less. There might be systematic differences between the two test station, like different charge voltage and different calibration, but this is not supposed to be a very big difference.
Also note that I uses 0.1 A as termination current when charging, some chargers might use other termination currents.
nekdo12
Last seen: 7 years 9 months ago
Shadowww wrote:
Hey HKJ, are you sure that’s a 2600mAh cell? Judging by color (orange), it looks like 2800mAh (4.3V) Sanyo UR18650ZTA. Maybe you could check label on shrink wrapper of cell itself? I’m afraid you would have to remove outer clear wrapping in order to do that, though.
No, I think that is UR18650FM with protection.
Look at these:
Shadowww
Hey, HKJ already confirmed it’s UR18650ZT Silly
SashiX
SashiX's picture
Last seen: 7 years 7 months ago
scaru wrote:
I don’t know where HKJ’s came from, but Fasttech does sell protected UR18650ZT.
Howly cow Shocked 11 bucks for 2? Shocked it says “2 pack”!! Shocked
Look at these:
!http://shrani.si/f/1O/LX/4HDgxhGn/x.jpg!
Uffff, veeeery big difference, IMO Flat Stare UR18650FM is even better than this one. But if a pair costs 11 bucks – I’m in (and with free shipping WW).
Shadowww
Pair of UR18650FM’s costs just $0.02 more Silly http://www.fasttech.com/products/1420/10001901/1143802
scaru
scaru's picture
And fasttech ships through epacket so it will get to the US with in 2 weeks.
SashiX
SashiX's picture
So, 11 bucks for 2? Shocked Man, these are the lowest prices I’ve ever seen! Shocked IOS sells FM Sanyos for more than $17.
And you have a pair of protected NCR18650A for less than $16! Shocked Fasttech, where have you been all this time :bigsmile:
AlexHH
I think you can’t really go wrong for this price and the shown capacity!
~ carpe noctem ~
sixty545
HKJ, Now that I have some of Sanyo 2800 protected from FastTech in the post I would like to see a test of them at full capacity. Also I would like to know how much better the unprotected battery are. Would you consider that?
Godt nytår!
sb56637
sb56637's picture
Last seen: 7 hours 38 min ago
Thanks very much! Frontpage’d and Sticky’d.
