I would like to trade for a nice C8 T6 or U2 (TRADED)
3 posts / 0 new
18sixfifty
18sixfifty's picture
Last seen: 2 years 11 months ago
Hi, I would like to trade for a C8 T6 or U2. What I have to offer is an Electronic Cigarette. It takes a single 18650 battery. It’s what is called a Lava Tube clone. The one I have came from Vapor Nine. It’s variable voltage from 3 volts to 6 volts in .1 volt increments. You can also check the voltage left on the battery. I have had it a few months but I’m not using it so it might as well go. These cost about $50 or so.
If you are interested I will be glad to send you pictures.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
Edited by: 18sixfifty on 01/03/2013 - 21:54
Pulsar
Pulsar's picture
http://budgetlightforum.com/node/17020
got pix of the lava tube? know how many amps or watts its able to produce?
i can fit the pill from the 502b in the tf-r2, making it a xml t6 tf-r2. use the nanj 2.8a driver. it has a ar coated glass lens in it now also. with the driver i can set it to any mode group below that you want
Group of modes:
1st Star : Low (5%) – Medium (30%) – High (100%) – Strobe – SOS
2nd Star: Low (5%) – High (100%) – Strobe
3rd Star : Low (5%) – Medium (30%) – High (100%)
4th Star : Low (10%) – High (100%)
im not sure, but i dont think the lava tube can produce the power i want though. i use dual coil 2 ohm cartos at 6 volts right now, less under load… wanna say a little over 5v. alot of these vari volt ecigs have a wattage cutoff though
edit: is it the supernova? if so id have to use it at 5v or lower to keep protection from kicking in it seems…
Pulsar
Pulsar's picture
just wanted to update that 18sixfifty is a good guy to deal with.
item was as described and even threw in an extra little project for me
hope you enjoy the light also
