Shadow JM26 Driver (Place for more AMC7135)
101 posts / 0 new
Hikelite
MattSPL wrote:
Great news, thanks Smile So can I stack any number of chips in any position? Like just one chip anywhere, or an extra chip on each chip? Cheers Matt
Any number on any position (of the 12).
MattSPL
Last seen: 4 months 1 day ago
Great, thanks :bigsmile:
likeaboss
likeaboss's picture
Wow, maybe making a 9 amp SL3 is easier than we thought. >)
Candlepower (abbreviated as CP) is a now-obsolete unit which was used to express levels of light intensity.
Candlepowerforums (abbreviated as CPF) a website, also obsolete, drive
gords1001
gords1001's picture
Last seen: 3 years 5 months ago
It is, but it’d be rough on the cell, can king Kong inr’s dole out 10a?
Edit, its my birthday in February, I think I’ll be ordering an sl3 and ten 380 chips or so….
dthrckt
dthrckt's picture
Last seen: 1 week 3 days ago
I think that’s more than recommended (2C?), and I wouldn’t make a habit of it w/ anything but IMR, or similar…
edit: so where’s the best price on SL3?
MattSPL
Yeah, hopefully Smile
Only thing is the heat sinking. The 3 leds are bonded on a single aluminium star that is glued into the head of the light, so the only area of contact with the head is around the edge of the star.
Tom E
Tom E's picture
Last seen: 1 hour 29 min ago
+1 - they are all in parallel so doesn't matter where. That's why you can even remove some, or double stack (3 high) them. But, oh boy, pushing a single 26650 over 5 amps? Not sure what the limit is on high qual batteries... I know there's been things published here on BLF about that. 6 amps would be nice, 2 amps per LED, but 6 amps on 1 battery? - only the best batteries, maybe...
 Not sure, but 9-10A even on an IMR may be unrealistic -- should check this.
dthrckt
dthrckt's picture
how thick/deep is the hollow space under the star?
MattSPL
I just ordered a couple of these http://budgetlightforum.com/node/16806 They can do 20A
I have a couple of mnke 26650’s that should do the trick too
likeaboss
likeaboss's picture
Tom E wrote:
+1 – they are all in parallel so doesn’t matter where. That’s why you can even remove some, or double stack (3 high) them. But, oh boy, pushing a single 26650 over 5 amps? Not sure what the limit is on high qual batteries… I know there’s been things published here on BLF about that. 6 amps would be nice, 2 amps per LED, but 6 amps on 1 battery? – only the best batteries, maybe…
Supposedly King Kongs can haul more than 10 amps easily. Check out HKJ’s review here.
MattSPL
At a guess, there is about 25mm between the star and driver, but a lot of it is taken up by the glue. I suppose it will be thermal glue of some sort though.
Hikelite
MattSPL wrote:
Yeah, hopefully Smile Only thing is the heat sinking. The 3 leds are bonded on a single aluminium star that is glued into the head of the light, so the only area of contact with the head is around the edge of the star.
That big aluminum board stays on another piece of aluminum which is basically machined from one piece with the head.
MattSPL
Ok, that sounds good Smile
gords1001
gords1001's picture
I have some king Kong inr’s already……..must……not……pull…….trigger……..yet. J) 0:)
Slacker
WOW! This is great news! I guess both flashlight has the same driver! Talk about making it easy :bigsmile: This means my JM26 has room for 4 extra 37135 and NOT 3! There’s enough room under the driver so stacking is not a problem. Looks like I’m gonna buy the SL3 and mod it. Smile Tell me how it goes, MattSPL! I might do the same. I’m gonna mail Hank at Intl-outdoor to see if he has any extension tube for sale together with the SL3!
The driver stops where the grooves end, so there’s enough room underneath:
I’m really happy right now :bigsmile:
dthrckt
dthrckt's picture
thanks for the link to those cells matt, I think that’s the highest rating I’ve seen.
The other IMRs I checked when we were last talking 9A sl3 were 18A
I was asking about the space because I’m wondering if it’d be possible to add a custom machined copper heatsink
might not be warranted if the path from star to body is good enough…tests will tell Beer
scaru
scaru's picture
Last seen: 4 years 11 months ago
You can't use an extension tube with the SL3, the max voltage of the 7135 chips is 6 volts and 2 li-ions would be 8.4 volts.
Tom E
Tom E's picture
 Interesting, but $70-$77 for the Shadow... I just may look at buying a TMART TangsFire HD 2010 3 LED for $42, upgrade the XML's to XML2 U2's, and add a KD V2 driver decked out to 7.5A (triple stacking some), and maybe have something better. Don't know, trade-off's there... The host of the Shadow SL3 sure looks nice!
gords1001
gords1001's picture
The bt-950 3 x xm-l is supposed to have poor heat sinking, I was put off ordering one when I asked.
Tom E
Tom E's picture
Yes, but I'm getting good with copper, thanks to Old-Lumens... Wink Was hoping it's similar to the std HD 2010 - that one I modded with adding 5 copper discs.
gords1001
gords1001's picture
I think its more a floating design, but I may be wrong on this, I think chi-x knows a bit about them.
scaru
scaru's picture
Yeah, it's a floating pill.
MattSPL
I just ordered some 7135 chips Smile They might take 2-4 weeks to get here though.
I’ve never soldered anything this small before, so hopefully my hand is steady enough Big Smile
Tom E
Tom E's picture
ohh, ok, ouch! I did a mod to a FTT, Poppas S7 from Manafont, that had the "hollow pill" (nothing behind the LED PCB), and back-filled it with a brass pill grinded down, then press fit in just right... - pain of a job but got it worked out pretty well. Chicago-X has the super lathe so he can do pretty much anything, wonder if he worked something out for that light.
gords1001
gords1001's picture
I stacked my first last week, its not so bad. I did get a heat shunt from maplin, I dont know if its necessary, but their two quid, and helpful for holding the chips at least. You don’t have to solder the centre pin, its common to the heat tag at the top of the chip, I tinned the pins first too and used a 40w iron. Hope this helps.
MattSPL
Thanks for the tip.
I saw those heat shunts on ebay while looking at tweezers, but wondered what they were for.
dthrckt
dthrckt's picture
I hold the new chip in place and bend the legs down until they almost touch the existing chip. With a tiny bit of flux the solder bridges that little gap. Seems easy to me (with a properly size soldering iron tip) and I’m not great w/ soldering…at all.
MattSPL
Will this stuff work, or is normal solder a better idea? http://www.ebay.co.uk/itm/150960948127?ssPageName=STRK:MEWNX:IT&_trksid=...
dthrckt
dthrckt's picture
it might. but a proper iron is more important, and solder core flux, or the tiniest amount of flux that you can put right on the leg is sufficient, imho
oh, and a magnifying glass can help.
I also find it helpful to have it set up so that my hand has something steady to rest on or push against – ie no shaking…
gords1001
gords1001's picture
It should do, I just use normal rosin? Solder from maplin, I just realised your in Ireland, do you have one near by? Failing that, any electrical suppliers will carry the bits you need. For stuff like this, I prefer to go local tbh, just so I can have a butcher’s at what I’m getting.
