New bunch of XM-L today at DX (14 new lights!)
14 new XM-L lights at DX today!
Some P60, some old aurora bodies.... interesting... but... the 2 mode ones... Are done with resistor at tailcap? no electronics, like old P7 aurora 2 mode....
504B black XM-L 1 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-510-lumen-white-led-flashlight-with-strap-black-1-x-18650-57097?r=43033281
504B black XM-L 5 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-5-mode-510-lumen-white-led-flashlight-with-strap-black-1-x-18650-57099?r=43033281
504B silver XM-L 1 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-510-lumen-white-led-flashlight-with-strap-silver-1-x-18650-57098?r=43033281
504B silver XM-L 5 mode http://www.dealextreme.com/p/ultrafire-wf504b-xm-lt6-5-mode-510-lumen-white-led-flashlight-with-strap-silver-1-x-18650-57096?r=43033281
UltraFire TH-T60 5 mode http://www.dealextreme.com/p/ultrafire-th-t60-ha-ii-xm-lt60-5-mode-1200-lumen-white-led-flashlight-with-strap-1-x-18650-57007?r=43033281
UltraFire TH-T60 2 mode http://www.dealextreme.com/p/ultrafire-th-t60-ha-ii-xm-lt60-2-mode-1000-lumen-white-led-flashlight-with-strap-1-x-18650-55908?r=43033281
UltraFire KH-T60 5 mode http://www.dealextreme.com/p/ultrafire-kh-t60-ha-ii-xm-lt60-5-mode-1200-lumen-white-led-flashlight-1-x-18650-57006?r=43033281
UltraFire KH-T60 2 mode http://www.dealextreme.com/p/ultrafire-kh-t60-ha-ii-xm-lt60-2-mode-1000-lumen-white-led-flashlight-with-strap-1-x-18650-55909?r=43033281
UltraFire NH-T60 5 mode http://www.dealextreme.com/p/ultrafire-nh-t60-ha-ii-xm-lt60-5-mode-1200-lumen-white-led-flashlight-with-strap-1-x-18650-57005?r=43033281
UltraFire NH-T60 2 mode http://www.dealextreme.com/p/ultrafire-nh-t60-ha-ii-xm-lt60-2-mode-1000-lumen-white-led-flashlight-with-strap-1-x-18650-55907?r=43033281
UltraFire NF-T60 5 mode http://www.dealextreme.com/p/ultrafire-nf-t60-ha-ii-xm-lt60-5-mode-1200-lumen-white-led-flashlight-with-strap-1-x-18650-57004?r=43033281
UltraFire KF-T60 5 mode http://www.dealextreme.com/p/ultrafire-kf-t60-ha-ii-xm-lt60-5-mode-1200-lumen-white-led-flashlight-with-strap-1-x-18650-57003?r=43033281
UltraFire KF-T60 2 mode http://www.dealextreme.com/p/ultrafire-kf-t60-ha-ii-xm-lt60-2-mode-1000-lumen-white-led-flashlight-with-strap-1-x-18650-55910?r=43033281
1000-1200 lumens. Overrated......
Thanks for the links.....gotta go check them out.
Wait, the lumens are overrated? LOL
Forget the lights ... I want that battery...lol
I know DX lumens claim is all over the board, but why are some XM-L lights rated at 1,200 lumens, 1,000 lumens and the ones on here @ 510 lumens? Do some have better drivers? They're all listed as T6 so what gives?
The ones stating the 510 lumens also stated they are driven at a regulated 1400 ma (1.4a) while the 1200 lumen claims are driven at 3000 ma (3a)
Dx shXt me. My order was "packaging" for weeks and then I ask to cancel it - so they post it. I'd rather pay a few dollars more at KD and manafont etc.
sorry not really off topic as I ordered my xml light after seeing a "whats new at dx thread". Still waiting.....
More XML!
2x18650 XML light
http://www.dealextreme.com/p/beamtech-t6-cree-xm-lt6-5-mode-850-lumen-white-led-flashlight-with-strap-black-2-x-18650-55109?r=43033281
Big XML dropin (posibly for mag mods)
http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-900-lumen-smooth-aluminum-drop-in-module-with-textured-reflector-58481?r=43033281
Both links won't work for me for some reason in both IE and Firefox.
They work check again
I think this is aimed at the TR-1200/WF-500 type of lights rather than Maglites - it seems a little on the large side for a Mag dropin. The Mag head is a little under 52mm inside diameter. I think. The Mag replacement lenses are 52mm in diameter and are larger than the inside diameter of the Mag head. If it will fit in a Mag head you'd either need to use a 5 or 6D since it gives a minimum voltage of 5.8V. It would probably run for a very long time on full output in a 6D but that is hardly a pocket light.
But it is quite possible I am wrong - it wouldn't be the first time.
Don: I think you're absolutely right about the dropin being for UltraFire WF-500. If you look closely you can see the threads at the end of the reflector which is the way you install the reflector in the WF-500. And the contact springs looks to fit the WF-500 to.
To bad about the flashing modes though...
They work just fine now. Thanks fran.
i got a 4d mag led that could use an update. did search and came up with this not so budget dropin http://macscustoms.com/MagLiteDropIn.aspx
4D mag? There are a lot of options for that one as long as you don't mind a bit of dyi. A pretty simple one would be the 5xR2 drop-in from dealextreme for about $33
New XML and... a new.... new... what????
UniqueFire M9 XML 1 mode http://www.dealextreme.com/p/uniquefire-m9-cree-xm-l-1-mode-700-lumen-white-led-flashlight-with-strap-black-1-x-18650-57541?r.43033281
UniqueFire M9 XML 3 mode http://www.dealextreme.com/p/uniquefire-m9-cree-xm-l-3-mode-750-lumen-white-led-flashlight-with-strap-black-1-x-18650-57540?r.43033281
Another TrustFire TR1200? 35 dolares? cheaper? what differences from the old one??¿?¿?¿
http://www.dealextreme.com/p/trustfire-tr-1200-cree-q5-wc-5-mode-1200-lumen-white-5-led-flashlight-2x18650-3x18650-4x16340-57380?r.43033281
Those Ultrafire 504 XM-Ls for $20 seems like an outstanding deal. I couldn't build one for that; the stainless bezel ring alone is $2.50 at Solarforce and figure $10 for the host. If Manafont came on here with a cash-back campaign that netted an XM-L drop-in for $7.50, think there might be a stampede? These may or may not be the quality of a Solarforce but even so . . . am I talking myself into this or just pointing out the obvious?
Very good find, either way.
herewegoagainFoy
What we lack is good flashlight bodies (P60 and others) for cheap! At 5-6usd i would instantly get a few 504B or similars. But no1 i think is interested in seeling those with just 20% markup...
Yeah TrustFire X8 (complete kit) at DX
http://www.dealextreme.com/p/trustfire-x8-xm-lt60-5-mode-1000-lumen-memory-white-led-flashlight-with-batteries-set-2x18650-57749?r.43033281
And another not XML, but SST 50, TrustFire X7, another complete kit
http://www.dealextreme.com/p/trustfire-x7-sst-50-5-mode-1300-lumen-memory-white-led-flashlight-with-batteries-set-3x18650-57752?r.43033281
I know it's not going to happen but I wish they'd just knock it off with the box sets. The box itself makes shipping uneconomical for most HK-based retailers, which in turn unnecessarily increases the price. The batteries are almost always unprotected and/or of questionable quality and the chargers tend to not exactly inspire confidence. *steps off soap box, stops preaching to the choir and grabs another slice of cold pizza* ;)
