I’m not really sure if this should fall in Rechargeable Batteries forum.
If the moderators deemed that it should be move somewhere else, please feel free to do so.
Having nothing much to do, I chanced upon this You Tube video;
Which led me to google and found this FAA report. The report about Li-Ion battery is at pages 6-9 of this report.
I’ve been charging my Li-Ion batteries and wonder about fire extinguishers that will effectively put out a Li-Ion fire.
A friend of mine is working for a small company selling a new form of fire extinguisher, which can also be used in a preventive way (read cover every possible fire source with this stuff).
It’s some kind of granulate, you can fill cable channels or even a whole room full of sensitive machinery and equipment.
This granulate can even handle the high temperatures of burning metal and it’s reusable.
Funny thing is, they tried to shorten a Li-Ion cell used by the automotive industry to let it go ‘poof’ and this cell was giving them a real hard time, several efforts had to be done, they made it in the end but it was not as spectacular as assumed by them.
The problem is, this extinguisher and method is not suited to be used in an aircraft, because you need space for that.
It may be suited for the transportation of sensitive stuff.
From the You Tube video, FAA test showed that spraying the li-ion battery fire with Halon 1211 fire extinguisher and then dousing with water is the best way to put out the fire and prevent the other li-ion batteries from reaching thermal runaway temperature. In another test, it appeared that using water alone extinguished the fire and prevented the other batteries from overheating.
This water fire extinguisher probably led them to the NASA’s water mist fire extinguisher developed by ADA Technologies.
Now, this water mist fire extinguisher… I’m wondering how technologically complicated could this fire extinguisher be? Perhaps, a garden plastic water sprayer can do the same job?
The objective in their extinguishing inflight fires from li-ion batteries was (1) to put the fire out and (2) prevent other batteries from overheating and from starting another fire. Also, in their test, flooding the batteries with water did the job of extinguishing the fire and preventing other batteries from overheating.
I wonder if this water mist fire extinguisher is another of those overpriced NASA gadgets.
I’m also puzzled by the cardboard box container mentioned in the report as one of the fire control methods in li-ion transport in aircraft.
After seeing the FAA tests on li-ion battery fire, I am seriously thinking of putting my 18650 battery in a cradle and away from the charger during charger. I am also thinking of placing the cradle with the battery being charged in a metal bucket with gallons of water nearby.
According to the FAA’s Extinguishing In-Flight Laptop Computer Fires - Lithium Battery Thermal Runaway testing;
AS shown by their tests, FAA was more concerned about battery thermal runaway induced by external heating. If a chemical reaction inside the battery might induce thermal runaway, I guess the FAA would totally ban any transport of li-ion batteries on commercial aircrafts.
But still I’m not comfortable with that thought. Can anyone explain how a li-ion battery might have thermal runaway by itself, without exposure to external heating?
It would be very hard. A short circuit would most likely be stopped by the thermistor. However, reverse charging could probably cause a thermal runaway. This is when you have one dead (0 volt) battery in series with a charged one and they are powering something. The 0 volt one goes negative, which can lead to a thermal runaway.
Have you ever tried to burn a cardboard box from the inside? Chuck in a pack of lit matches and close the cover. The box may catch, but it’ll probably go out before spreading.
Cardboard burns with a lot of smoke and needs a lot of air. a closed cardboard box would not burn freely until a good sized hole formed in it. Most shipping cardboard is treated with fire retardant too. I suspect they consider cardboard less of a catalyst than plastic. Although, smoke on an airplane sounds bad too…
Just a guess… and I’ve lit a few fires before, mostly with desired results
Looking back at the video, there was about one to two feet of flames shooting out of the battery. It was like a mini flame thrower. I can only imagine that the cardboard box would be obliterated by the intense heat and flames shooting out of the li-ion battery.
The following quote is on page 6 of the report.
2011 FAA Fire Safety Highlights
1. Metal pail
2. Water
Those might do the job of containing and putting out a Li-Ion fire.
http://www.mpoweruk.com/lithium_failures.htm has a graphic illustrating the safe window for lithium cell handling — stay inside the green. They run down the changes that happen when conditions go outside the safe window and why they lead to trouble eventually.
“… many, if not most fires are caused by abuse by the user. This may be ”deliberate or negligent” abuse such as overcharging or operating in a high temperature environment or physical damage due to mishandling, but quite often it is unconscious abuse. Surprisingly many of the most serious fires have been initiated by inadvertent short circuits caused by careless disposal of cells in the rubbish.”
