Review: Digital Projector LED Spotlight Cree T6
79 posts / 0 new
Richie086
Richie086's picture
Last seen: 4 hours 49 min ago
Produces 110K Lux @ 10 meters thanks to a huge 95mm reflector
Hey folks,
I’m not exactly sure if this type of light is very popular around here, but I thought I’d post about my new addition to my light collection. Perhaps someone may be interested in this.
In addition to the more traditional flashlights I like to purchase, I also like hand-held spotlights, so I’m always looking around for something new and interesting, and most importantly, affordable.
For me, this new Digital Projector Spotlight was something I loved the look of and simply had to have it. Seeing the huge SMO 95mm diameter aluminum deep reflector designed for throw, with a Cree XM-L T6 sitting behind it, a battery pack wired in parallel yielding 7500mAh of long lasting power (I hope), and an anodized aluminum body, I had to purchase not just one in this gold color, but I also purchased one in red color from a different retailer which I haven’t received yet.
This one shown was purchased from Banggood.com from this link: http://www.banggood.com/Wholesale-Cree-T6-Super-Digital-Projector-Rechar...
I’ve never purchased from them before, but I can tell you if there service is always this good and fast, I’ll be buying from them again, I assure you. I ordered this light on 12/31/2012, and it arrived today 1/14/2013. On this particular sale, they didn’t offer tracking, so I never actually knew when it would show up. But a total of 15 days is pretty good if you ask me. So the slow boat really wasn’t so slow afterall…LOL
The spotlight was shipped in the original retail box, the box was well wrapped in foam, and that was then covered with two separate plastic bags. The light arrived in flawless mint condition, the SMO reflector is beautiful with no finger prints or anything with a real glass lens. As far as I can tell, this light may have just hit the market in late November 2012, but I know they are very freshly new because the proprietary battery pack was fully charged when I received it. Typically, I stopped purchasing any lights with proprietary battery packs, but with this one, it’s wired in parallel, so if the pack starts to give out, it’ll be a breeze for me to change it out with some Redilast batteries or something.
I suspect this hasn’t been a popular light due to the fact they have it listed, among other things, as a diving light, which it is NOT, but it’s great for anything else requiring a tight spot beam.
Listed below are the manufacturer specs:
Specification:
Product Name: CREE T6 Miner Lamp Diving Flashlight
Model of LED: CREE XML T6 LED
Material: Aluminum alloy
3 Modes: high / low / strobe
Straps: Yes
Charger: YES
Color: grey+gloden
Size: 20.4cm lenght x 12cm diameter
Weight: 1300g
Capacity:7500mAh
Charging time:8-12H
Charging voltage:5.5V
Working time:8-10H
Features:
The altitude does not exceed 3000m
The ambient temperature -25 – +40
The average relative humidity of not more than 95%
Super bright CREEXL-M T6 LED flashlight.
Heavy duty & durable, impact resistant.
High tech bright LED with extremely long working life.
High quality can be used for more than 100,000 hours, which eliminates the trouble of replacing the lamp
Charge:
When the luminance decreased obviously,please use the light distribution for the lamp charger with charge.
The first charging plug is inserted into the lamp charging socket,and then access the 110-220V city electric.
When the charger is the corresponding instructions from bright red to bright green battery is enough,can remove the charger to stop charging,charging time is about 10-12 hours.
Must be in accordance with the outer packing tips of the proper charging method for charging.
Note:
It’s not professional diving torch,which is tested no exposed to more than 3meters under water.
Common used in water downpour, jungle searching,shallow water work,etc.
Package Included:
1 x CREE T6 Miner Lamp Diving Flashlight
1 x Charger
Banggood was also nice to include the charger adapter for USA.
I always like to include a hand-hold for scale purposes when showing a new light to the forum.
The light has an ever slightly rounded base, but still tail-stands great. You can also see the
red “Thumb” power/mode button. Modes are Low-High-SOS, no mode memory and you must
cycle through all modes to turn off.
Standing on its bezel to show the rear charging port with the soft silicone cap flipped open.
For the reflector size scale, from left to right, Skyray 9x T6, Digital Projector 95mm, Small Sun Zy-T16, Fandyfire HD-2010
Yeah, the Vector Power On Board has it beat in the bigger catagory.
Here are some beam shots against a couple of decent lights most can relate to.
Camera settings were as follows: Manual exposure, 1 sec, f/2.8, ISO 80. Other than size, no manipulation was done.
Distance is approximately 80-90 feet.
Small Sun ZY-T16, 2 × 26650 Trustfire batteries configuration.
Fandyfire HD-2010, 1 × 26650 Trustfire battery.
Digital Projector Spotlight – That’s what I call a spot beam.
Richie
Edited by: sb56637 on 09/02/2017 - 12:37 Reason: sb56637 replaced <!-- break --> with <!--break--> via Scanner Search and Replace module.
dthrckt
dthrckt's picture
Last seen: 3 weeks 1 day ago
interesting light!
does that handle adjust? is there a path for heat to reach the body/outside?
judging by the photos, that measurement is much too low (looks twice as bright as hd2010, which people have measured somewhere close to the reading you got for this spotlight)
I’d try measuring at ~10 meters and then calculating 1m for reference
lux = (lux at 1 meter) * distance ^ -2
Richie086
Richie086's picture
dthrckt wrote:
interesting light!
Hey Dthrckt,
The handle doesn’t adjust at all. I noticed when I removed the reflector, the LED is connected to the back of it and and directly behind the LED has some type of heatsink that is in the same shape as the rear of the reflector sitting in mid air. But from what I can tell, the heat isn’t transferred anywhere and not connected to the aluminum body. A strange design, but it seems to operate very well. I’d say the heat is obsorbed into the reflector and this heat sink. I’m curious to see how it performs if the becomes saturated with heat. I’ll give that lux measurement another try and see what I can come up with. Thanks.
Richie
Andi
Andi's picture
Very interesting light!
Can you say ~diameter of the reflector in mm/cm ?!
Richie086
Richie086's picture
Hi Andi,
Reflector diameter is 95 mm.
Richie
Andi
Andi's picture
Perfect, thanks.
sb56637
sb56637's picture
Last seen: 5 hours 53 min ago
Thanks very much! Frontpage’d and Sticky’d.
Andi
Andi's picture
and….ordered to mod. Party
Richie086
Richie086's picture
Thank you SB!
Richie
Richie086
Richie086's picture
I’m modding one right now with Redilast 18650 batteries.
Richie
Philipp
Philipp's picture
Last seen: 8 years 12 months ago
Great review, thanks!
What are you planning to do with it? Smilecough mt-g2 cough…. J)
Richie086
Richie086's picture
Yeah Andi, what is your plan for it??
I’d love to see how the mtg2 works with a 95mm reflector. The star for the XM-L in it now looks 20mm to me. The internal setup of this light is different than I’m used to seeing, how the LED connects to the driver and such. Perhaps I’ll post some photos later today. I was a bit surprised this light is powered by a 4 volt, 7500mAh lead acid battery. A bit higher capacity than the 6500mAh in the description, but that’s fine. It actually never said anything about it having a Li-ion, so at least it’s a very safe light to use as is. But it’s going to get 4 × 18650 Redilast 3100’s wired in parallel as the first mod for it and see how that works.
Richie
Andi
Andi's picture
I will build a superthrower….
XP-G2 direct on copper, dedomed with ~5A
In a X7 a XP-G2 with this settings give ~450KLux
With this reflector i think it could be 600-800KLux. :bigsmile:
Richie086
Richie086's picture
That’s excellent, but I don’t know if it’ll handle the heat generated. I’ll get the internal photos posted later on for you to see.
Richie
Andi
Andi's picture
I will try to make a Heatsink with contact to the outer alu. Wink
Richie086
Richie086's picture
Andi, then you’ll want to see these photos of the internals.
Evidently, this light uses a different way of conducting heat by conducting it into the large cavity behind the reflector. Not a great way to do it especially since the body is aluminum and could have aided in heat dissipation. But from using the light, I’d say the manufacturer decided to take advantage of this very large aluminum reflector in addition to that heat sink mounted at the rear of the reflector, and both serve to absorb heat. I have used the light on high mode for a while, but didn’t notice the reflector becoming saturated with heat at all.
I’m sure that’ll change once I get to upgrading the driver to turn it into even more of a thrower. I’m hoping you’ll be able to come up with an idea that’ll work well. It’s a great little light and very well made, including very nice silicone wiring of sufficient gauge that does not require replacement.
Driver attached to rear heat sink.
Underside view of heat sink. NOTE: there are two types of heat sinks floating around on these lights. Second version is a
closed design, unlike this flared version.
Circuit board that controls all functions, including connection to battery, On/Off switch, and charge functions.
Richie
2100
Last seen: 4 months 1 week ago
Thanks, really like such a format light. Could you measure at 15-20 metres and see what’s the lux reading? (I can convert it for ya) That’d give us a more accurate figure.
I wanted to get this 19.5cm ext diameter T6, but i am not sure if the reflector is optimised. Not cheap too, so decided not to take the risk.
http://www.aliexpress.com/item/2933-10w-led-searchlight-flashlight-light...
2100
Take your HD2010 and ceiling bounce it. Take the lux reading.
Take this light and ceiling bounce it. Take the lux reading.
Not sure what’s the OTF output lumens of the HD2010 though. You have other lights like SWM T40CS? You can get a pretty ok OTF lumens by relatively comparing them.
Richie086
Richie086's picture
I’ll get the lux reading tonight for you. As for this 7.5 inch reflectored light, I’d say it’s driven the same as the Projector light, but has an even larger reflector. Damn that’s big..LOL. Good candidate to upgrade the lead acid battery in it for a nice li-ion too. I saved that link for a future purchase.
Richie
Richie086
Richie086's picture
leaftye wrote:
I’m digging the old school format of this spot light.
I really love the light and build quality inside and out is really amazing considering the price. They actually used the same large diameter silicone wiring I use to upgrade the lousy 30 gauge wiring in most all my Chinese lights. One upside of the lead acid battery is you get proper output from the XM-L, but you don’t have to worry about any unsafe battery conditions. But as I mentioned in an earlier post, I’m still upgrading the battery to some Redilast cells.
I originally purchased 2 of these light, one from BangGood.com (gold color) and one Red one from an Ebay seller. Not having dealt with either vendor before, I just assumed they’d both be damaged when arrived, but having two, I’d be able to fix one with parts from both and the reason for having two of them. As it turned out, the one from BangGood was shipped in the original box and very well packaged and arrived MINT. However, the Red version from the Ebay seller was taken out of its original box and placed in a box smaller than what the light required. Although it somehow didn’t arrive damaged, when I opened the box, it was in some sort of moon-light mode, which it doesn’t have. It could have even left the factory in this malfunctioning condition. It was the lowest moon-light mode I’ve even seen. So it obiously had or developed a short somewhere.
It wouldn’t turn off and could actually have been in this mode for weeks, so the red one I needed to take apart and fix the issue, which I did. So it’s the red version that’s getting some upgrades while it’s apart.
To play it safe, just purchase from BangGood, they seem very into having some BLF business.
Richie
2100
Thanks richie for getting me the lux reading! Smile
As for the 19.5 cm ext diameter searchlight, the issue is that the reflector is not really deep. Yeah i know that the diameter is the main factor in determing throw (focus whatever)….but if you see most of the usual aluminum body T6 lights, the reflectors are of a certain profile (quite deep) which is somewhat similar to the aluminum body searchlight that you have just purchased.
That Zuke 2933 searchlight’s reflector profile is really like those HID/halogen searchlight. So seriously i do not know if it’d throw even as well as your light.
So i’ll probably get one if yours is > 100k cd. Big Smile
Richie086
Richie086's picture
I do see your point with reflector depth and fully agree. Still, I was very surprised to see the beam profile was quite tight down-stream when compared to some of the lights I used in my beam shots in an earlier post. If powered the same as say, a TN31, would it throw as tight and as far, I can’t say, but I think it would make a great experiment for sure and still be inpressive.
The only thing I’m not sure about because I haven’t actually removed the LED and driver, I’m not exactly sure how the LED receives power since the wires are not mounted to the top of the star as a typical light would be. I’ve never had a light in this configuraton where the wires are obviously underneath the LED somehow. But one thing for sure, as soon as I get the battery upgrade done and works correctly, it’s going to get a driver upgrade and one of my XM-L2 installed. Just a matter of time now.
Richie
dthrckt
dthrckt's picture
FYI, I googled zk2933, looked at images and found it is also sold w/ halogen bulb.
2100
It’s basically a Thor 6mcp body i read.
Anyway, here’s the budgetlight forum link to that 2933 LED searchlight.
http://budgetlightforum.com/node/14311#comment-249489
Andi
Andi's picture
Thank´s Richie086 for pictures! Beer
….this “2933 10w led searchlight flashlight” look also very interesting. Tired
FlashPilot
FlashPilot's picture
Last seen: 2 hours 22 min ago
Talk about a thermally challenged light. Flat Stare
I hope there is a clear path way between the rear of the reflector and the AL body. Maybe you could get a thick piece of aluminum or copper plate and cut it to the shape of the host to replace the wimpy heat sink. If it has a good tight fit, a thin coating of AA might do the trick in transferring heat to the host. Failing that, perhaps a used heat pipe from a PC with a small hole drilled through the side of the case (for the pipe) and the heat exchanger arranged under the host. Bend the pipes to position the heat exchanger where you want it.
The spot beam looks great!
Richie086
Richie086's picture
I hope there is a clear path way between the rear of the reflector and the AL body. Maybe you could get a thick piece of aluminum or copper plate and cut it to the shape of the host to replace the wimpy heat sink. If it has a good tight fit, a thin coating of AA might do the trick in transferring heat to the host. Failing that, perhaps a used heat pipe from a PC with a small hole drilled through the side of the case (for the pipe) and the heat exchanger arranged under the host. Bend the pipes to position the heat exchanger where you want it. The spot beam looks great!
Yes, it has a clear path to the aluminum body, nothing but air behind it. I’m going to look into additional sinking very shortly and see what I can come up with. But as it is stock, the light works great. Naturally if changing out this crazy driver configuration it has, heat could be a problem if used on high mode for a long time. Thank for the input.
Richie
Richie086
Richie086's picture
As I previously mentioned, I’ll likely keep this light at 4.2 volts and find a driver that operates at that voltage since there are many good ones around. But I did want to toss the 4 volt 7500mAh lead acid battery.
I decided to go with one of Fasttech’s 1S4P battery holders, and with a little tweeking, and some Redilast 18650 3100mAh cells, created a 4.2 volt, 12400mAh battery pack. With the balance of the light in stock condition, this is far more capacity than required, but I don’t intend to keep it at the present output :bigsmile:
Only issue thus far is the stock charging circuit inside the light doesn’t speak the same language as a Li-ion charger, so for now, I’ll have to remove the pack for charging, which shouldn’t be required often with this much capacity. I’m going to toss the pack in later tonight and then plan out the next mod. One big difference now is the Redilast Li-ion cells don’t have the voltage sag the lead acid battery had. When turned on HIGH mode, the voltage just hangs out steady Wink
This is what I used 1S4P holder
Assembled a 12400mAh 4.2 volt power pack.
This new pack is replacing the large 4 volt lead acid battery.
Richie
dthrckt
dthrckt's picture
Is the reflector/heatsink 1 piece?
I had a light w/ similar (looking) emitter/driver setup. the reflector didn’t have a hole in it, except for where some little short rods went through, and the emitter/driver were soldered to those rods.
that made changing the emitter in mine difficult (i cut the whole base of the reflector off with dremel).
anyway, if it is all 1 piece, connecting the reflector to the aluminum body might be easier than connecting the heatsink itself. although, that’s kind of a long, thin thermal path…
FlashPilot
If its 3/8” copper (or thicker), it should have no problems conducting heat that amount of distance. Lots of heat sinks and copper material to pick through on ebay. The best solution would be a heat pipe setup, but will probably take a lot of work and imagination to make it work properly.
Then there is always the solution of an internal fan and vents cut through the side of the host for cross-ventilation.
Richie086
Richie086's picture
I can’t tell yet if they are one piece, I just assumed the heatsink and driver were placed together using some sort of thermal epoxy. But from the LED side, it seems to look as if the LED is riveted somehow. So maybe you are correct. I’ll try separating the reflector and heat sink and see how they are together.
Richie
