Same here. I'm stuck. I may try to just slightly change the other resister bank. It must be pretty sensitive given the high values.
I've been meaning to check out your MT-G2 thread. I glanced and it sounded fun. If you measure throw in that light, please be sure to post to the MT-G2 throw thread.
So, I cleaned up resistors
and I soldered braided wire (the stuff used for desoldering = goot wick) instead, and….
the best that I get is 2.10A and not a drop more |(
I knew that this new driver would be a problem as soon as I heard it’s not 7135 based!!!
I am out of ideas
Edit: just for sake of testing I connected ordinary Nanjg 105C (not Qlite) and using same batteries, same measuring setup I got 2.55A @ LED
Sorry to hear that dude. I just went and compared my the resisters in the other resister bank to your pictures and they are in the same order. One thing that may be causing resistance. The negative wire solder looks like it may not have fused well with its solder pad. I'm hoping that's the problem because I don't see any other potential issues.
Interesting,
I give up on this driver, soldered thicker positive wire (previously I replaced only negative wire just for testing), add a big solder blob on top of the braided wire (resistor mod) and assembled everything back, topped of unprotected trustfire 2400mAh battery to 4.19V (cheap and imprecise charger) and….
measured 3.07A in high mode!!! How did that happen!
Two things changed between my testing setup and the flashlight, for testing I used XM-L U3, inside the flashlight is XML2 U2! and for testing I soldered 20AWG wires to emitter (U3) and then connected negative lead directly to driver but I left original positive lead and soldered it to thicker emitter lead (positive wire was longer than negative)…
You should try a low internal resistance battery. Mine is much brighter on KK ICR’s than Sanyo 2600 batteries. I am fairly certain it is direct drive but a high resistance driver.
I hadn't used this light (JM26) for a couple months or more. Checked the fairly new KK cell and it was down to .8 volts. I never tried to measure the parasitic drain on this light, but apparently it's pretty high. Maybe it was the resister mod.
I hadn’t used this light (JM26) for a couple months or more. Checked the fairly new KK cell and it was down to .8 volts. I never tried to measure the parasitic drain on this light, but apparently it’s pretty high. Maybe it was the resister mod.
i can confirm: High parasitic drain
Now I have left the tailcap unscrewed and see what happens to the battery
Unfortunately Razzi is now defunct so I need to reload all my photos and fix all existing reviews... For now, here are the current measurements I took for a stock JM26, and yes, the standby while not the worst can certainly stand to be better:
A King Kong should last ~10mos (not including its own self-discharge rate) whereas an AW IMR would only last ~3.5mos (again not taking the cell's self-discharge into consideration).
Best to lock this light out when not in use.
@GioLight, the same thing happened to me with a KK and now it can no longer hold a charge. I've written off the cell for safety considerations and I'd be a little cautious about reusing your cell, it's likely damaged at this point.
I am out of ideas
I also used 2.5mm solder braid on the tail cap/body spring. I think it helped.
Newb
Interesting,
Newb
I need to get some KKongs…
in the 26650 battery thread there is a link to a powerizer battery that is even better, but its in the US……..so I don’t think they can ship to you.
Newb
KingKong batteries are better than the Soshine 26650?…i use the second…..
Do you recognise this
http://www.ebay.com/itm/Galuxia-Gladiator-Torch-Flashlight-Kit-Cree-XML-LED-1000-Lumen-26650-Maxtoch-/141043660214
is it just me or this light was available from Fasttech for like $ 47 shipped…
“the easiest way to become a MILLIONAIRE is: first you become a BILLIONAIRE than you start to be flashaholic”
yes but not under “Gladiator” brand, it was genuine Shadow, and it was even lower price at WB…
UTube Channel | Flickr Sets
