Test / Review: TrustFire TF26650 4000mAh (Black-silver)
Official specifications:
  • Operating voltage: 3.7V
  • Capacity: 4000mAh
  • Ultra-high capacity and premium built quality
  • Protected to avoid over-charged or over-discharged
  • Best companion for your high performance flashlights
This battery has lower capacity at 0.2A than at 0.5A, this is probably because the 0.2A is the first discharge cycle I am doing on the battery (This behavior is very uncommon for LiIon).
The two batteries has different capacity and it looks like slightly higher capacity at 5A, probably because of heat.
The actual capacity is about the same as a 18650 3400mAh battery, but the voltage is higher.
Conclusion
As usual the capacity is lower than specified and the two batteries does not have the same performance.
For a cheap battery this is acceptable.
Notes and links
I have added the battery to the 18650 comparator, this makes it possible to compare voltage at different loads.
This sounds like they are not a patch on the Flames. I've been curious from when they were released how good they were. Thanks HKJ
Thanks HKJ.
Your reviews are always great and highly appreciated!
Thanks very much for the review! Frontpage’d and Sticky’d.
I had been watching for these black/silver cells to be reviewed, and somehow missed it… Thanks for doing it!
HKJ's sample came from Manafont, but FastTech has them. For about the same price you might as well by the well regarded protected Trustfire 26650 flames though. HKJ's test / review of those here.
-Garry
