It looks like it's time for me to do another giveaway, so here it is.
I am giving away a good condition HD2010 host. Here some pictures are.
It will accept up to a 19.33 mm star, and a 17mm driver. The driver needs to not have anything on the edges to fit.
Here is how this is going to work, everyone that fits the rules (posted below) gets one entry. To get this entry they simply post below in the thread, just say count me in or something of that sort.
You can get a second entry by giving me a recommendation for a machinist to make me a heatsink for my Flydragon host. Each machinist should only be posted once (no reposts, I know this gives an advantage to people earlier on but oh well).
Finally, if I do end up having that machinist work for me then you get five entries into the raffle. :D
Rules
You must have registered before January 1st 2020 :P
Your username can not be Nitro
Any machinists you recommend must be able to work on flashlights+cut threads
ChicagoX has already been contacted so you can't suggest him
The giveaway will end friday the 15th at 12:00 EST, the drawing will be held around then (If I can)
As for the machining part, I could be of some help (I guess you’ve seen the flashlight I’ve built), but if you need larger amounts of parts, I could have them made by a shop where I used to work for good price.
Yeah, I guess I'll shoot him a PM if I don't hear back from Wayne/someone in the US. He's done a few things for me in the past which all have been great. Added you to the double entry list.
Count me in, sorry, no referrals. Wonder how you wound up with a perfectly good HD2010 host? I'm working today on fitting a 20mm SinkPAD into one I got, so far got it shaped and got the wire routing worked out.
