Guide: Rechargeable AA batteries / 14500 batteries / Chargers
43 posts / 0 new
alfreddajero
alfreddajero's picture
Last seen: 11 months 3 weeks ago
And service life of the cells have been decreased......i know what you mean about rc'ers.....im from that crowd and i have made cells vent from overcharging them just to get more amps from the pack.  I run a couple of cells til the light doesnt work anymore and stick them on the charger, with nimh your more worried about heat, the hotter the cell the shorter the service life or life span of  the cell.  You should be fine with the eneloops since there of higher quality then some of the cells that are out on the market.
With Darkness, there will always be Light.
Nil Einne
Last seen: 2 years 1 month ago
SB how did that charger go? It seems like you're the only person to ever buy it from the sale history! Anyone else have any other recommendations for a cheap NiMH charger? I do want one which is smart (i.e. deltaV) but not too fast so it doesn't kill my cells, preferably with trickle charge too. And single cell channels (at least 1) since I may use 3xAA or 1xAA sometimes. I'm finding a lot of cheaper stuff on eBay but there's little info on them. Quite often they're 2 cells per channel.
I was thinking I wouldn't bother with a NiMH charger as I'm going 18650 for my torch but I've been flirting with the idea of building my own tail light with some of those cheap Chinese red array LEDs (or perhaps a Cree) and I don't really trust my ability to make it waterproof so I'm thinking I may stick with rechargable AA initially at least so I don't have a nasty experience with shorted li-ions. I currently use a Maha 401 but it's not mine so I want to have my own for regular use. I do actually have some of those very slow dumb charger (well they technically aren't mine but no one wants them) but want something a bit better then that.
Don
Don's picture
Last seen: 11 months 18 hours ago
I'd look around for a Vanson BC1-HU or one of its rebadged variants - they are quite ubiquitous and distinctive in appearance so it is easy to spot rebadged ones. And they don't cost a lot.
http://www.amazon.com/110-240V-Universal-Charger-Rechargeable-Batteries/...
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
sb56637
sb56637's picture
Last seen: 14 hours 23 min ago
I really can't complain too much. The seller is great, he sent me a free replacement with free batteries when the first one didn't perform according to the description, although I now realize that it was performing normally. It's a simple, slow, cheap, 4-channel charger with automatic shutoff. Couldn't hurt to give it a try for the price.
kaabob
Last seen: 3 years 11 months ago
What do you guys think of the Eneloop XX packaged with a charger? There's a rapid charger included, and when charging 1x at 1680mA seems dangerous, even for a AA rated at 2500mAh.
http://www.amazon.com/Sanyo-Battery-Powered-Capacity-Pre-Charged/dp/B004N042XO/ref=sr_1_15?s=electronics&ie=UTF8&qid=1338003560&sr=1-15
Also, what do you guys think of the costco pack - seems like it charges in pairs instead of independently =/
http://www.amazon.com/Sanyo-Eneloop-Charger-Rechargeable-Batteries/dp/B003VLAEPQ
ntg
ntg's picture
Last seen: 6 months 4 weeks ago
Great info…thanks!
PA40, O.L. Mule TS, Fenix EO1, Old Dorcy 1xAAA Gen 2 (Link), Princeton Tec
Ventsi
Last seen: 15 hours 22 min ago
I’ve only used 14500 from the ones that you are asking and judging from my experience the best 14500 battery is the NL147 by Nitecore. You can find them for $6 a piece from FastTech.
If you are on a tight budget, get Trustfire Flames from Manafont. 2 pieces for $6.12. Difference vs. the Nitecore is minimum, probably 10%.
Jinx
Jinx's picture
If you use too low of a charging level for NiMH it is very hard to terminate the charge accurately. It is far better to use a decent smart charger and a decent charge rate, I’d say 500mA was minimum for a AA Eneloop but anywhere upto 1c.
If you really want to only trickle then use a timer to ensure shut-off after an absolute maximum 24hrs, usually around 16hrs.
Ventsi
I found some new Soshine 14500 and I’m thinking of buying. I’ve read some good reviews on 18650 Soshine, so I guess there’s no reason to doubt the little ones:
http://www.ebay.com/itm/Soshine-3-7V-14500-800mAh-Protected-Rechargeable...
brad
brad's picture
Last seen: 2 hours 30 min ago
cat eyes wrote:
i have looked at a lot of threads here….
i can not find the threads regarding THE BEST 10440s , 14500s and 26650s…
if someone can tell me the 3 best brands of each…. thank you
There is a little bit of information here, but it is only on a few 14500s from Fasttech.
http://budgetlightforum.com/node/19537
zerodish
Last seen: 5 days 16 hours ago
https://www.flickr.com/photos/63373992@N07/14352632803/ This has been done here before but it needs to be udated. Just bought the Ozark Trail 500L which has the same battery compartment as the Coleman and the Dorcy with 4 new Rayovac batteries which won’t fit. The photo shows Kodak which fit very tight poloroid which are tight and Radioshack with the label removed which are slightly tight. The Vivitar’s fit fine as well as the Duracell alkalines which came with the light. I would happly buy 4 more Vivatars which came with a 200 millamp charger. The light end does not unscrew on the Ozark or the Coleman which means the batteries can’t be poked through. I could just jam the batteries and take them back for a refund but I’m going to work through the problem.
SJSHINE
Last seen: 2 years 2 weeks ago
Thank you for sharing. Learned a lot. Thumbs Up
