Another "noob" question on drop-in
10 posts / 0 new
Davx
Davx's picture
Last seen: 5 years 7 months ago
I read many things about P60 drop in and i see that not only the kind of drop-in is important but also (in some case seems to be the most important thing) WHERE you buy it.
So here are the two question :
- Assuming that you use a solarforce L2 body, which drop-in would you buy between P7, XM-L T6, and MC-E  to have a large amount of flood but also a good throw?
- Where you would buy it?
"There are always new jobs, women, and apartments......there is only ONE BLF." - Chicago X (27/03/2012)
photon1k
photon1k's picture
Last seen: 4 years 6 months ago
If it were me, I would get the Ultrafire 3 mode XM-L from Manafont. With a good cell it will produce a wall of light and reasonable throw. Be sure to wrap it in foil or aluminum strips to help it transfer heat to the head and body of the light.
Budgeteer
Budgeteer's picture
Last seen: 8 years 2 weeks ago
Exactly the same here. P7 and MC-E are obsolete for me now that XM-L showed up. When it comes in neutral and warm white the MC-E will lose it's only advantage it had left vs XM-L.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Huny74
Huny74's picture
Last seen: 5 years 4 months ago
+1 provided you want to use 18650 LiIon batteries.
Andi
Andi's picture
Definitive XML dropin from Manafont!
But i think, a L2 body will get very hot, if driven a XML@high for long time.
So High is only for limited time Wink
old4570
Last seen: 2 weeks 1 day ago
The MC-E and SSC P7 in single 18650 format simply can not compete for output ...
In 1x 18650 format , you have one choice , XM-L if you want the highest output
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Davx
Davx's picture
Ok, it seems that's one idea for all. Good to know.
@Andi (and @everyone want to answer): what body you suggest? Obviously with a price similar to L2.
photon1k
photon1k's picture
An L2 style body is going to get hot quickly indoors or with summer temperatures. I've been running my L2P on high for 20 or 25 minutes at a time outdoors with temperatures of 5C or less. With these conditions it barely gets warm. I won't get away with that in the summer months of course, but in the summer I usually go to bed before it gets dark!Yell
old4570
There about the same .... [ P60 hosts ]
Where things will be different , how well you heatsink the pill , to the body ..
+ The quality of the pill in the first place ... Battery [ current ]
Also if you pick a bezel heavy [ large bezel ] light , you may find the bezel is blocking a fair chunk of output [ in the way of spill ]
Budgeteer
Budgeteer's picture
Let's not forget the dropin assembly itself. I suspect those could be iproved heavily. I wonder why they don't make the pill from copper. Easier to solder but will oxisize very soon. Don't know it wil have a heavy impact. Would probably help transfer heat compared to brass ones. I believe led stars are being very poorly (thermally speaking) bonded with the pill surface. There was a thread at CPF of someone doing tests on improved heatsinking and led brightness/current corellation. Very noticeable difference.
