Review: Trustfire F22
61 posts / 0 new
Don
Don's picture
Last seen: 10 months 3 weeks ago
  TrustFire F22 Stainless Steel Cree XP-ER2-WC 5-Mode 220-Lumen Memory LED Flashlight
Overall Rating:  ★★★★★
Summary:
Battery: AA, NiMH, 14500
Switch: Reverse Clicky
Modes: 5
LED Type: XP-E R2
Lens: Coated Glass (Says DX) - Feels like plastic
Tailstands: Yes
Price Paid: $22.85
Pros:
  • Bright
  • Neutral colour of beam
  • Tight hotspot
  • Well made
  • Plenty of O rings (GITD!)
  • Lubed threads
  • Not a hand burner unlike some other stainless steel lights
Cons:
  • Switch needs to be hit dead centre or can stick
  • Enormous for a single AA light
  • Heavy (It is made of steel after all)
  • Thermal performance, stainless steel is a less good conductor of heat than the usual aluminium
Features / Value:  ★★★★★
A nice 5 mode setup. Sequence is high, medium, low, strobe, SOS. I like stainless steel lights a lot so that's an automatic bonus mark. Comes with a much nicer lanyard than is usual. I can almost get it over my head. It is made of some sort of elasticated material.
Comes with a silly "Assault Crown". Some may regard this as a bonus. I don't. Fortunately it also comes with a more sensible bezel and now that I've photographed it, the silly bezel can go in the bin.
Lettering looks a little odd at this magnification though I'd never noticed this before. It helps having a better camera for doing closeups.
Build Quality:  ★★★★★
The threads are rather nice.
The O rings are, as you can see, made from Glow In The Dark (GITD) material. I really wonder why. These probably cost a bit more than non-GITD ones and are never going to be exposed to light, so why bother? The light came lubed as you can see by the grime on the front O ring.
This has been bashed around in my pockets for a while and still looks good. The centre brass (at least I assume it's brass) ring is also to be found in its stable mate the Trustfire F23
Note the cutout for the split ring so that the light will tailstand. Simple idea but all too many manufacturers don't think it through.
It is on the big side though, here it is with some other lights.
Aurora SH-032, Trustfire F22, Akoray K-106, Tank007 E07. All but the first are AA lights.
Battery Life:  ★★★
Like most such lights (i.e., lights capable of being used with a 14500) this one really isn't alkaline friendly. Runtime to 50% on high is 27 minutes and 45 seconds though it gives usable light for about an hour. Not really regulated, which is not unusual for alkalines. The output is roughly 85 lumens on high with an alkaline.
Alkaline Medium. Starts at about 45 lumens on medium with an alkaline. Usable light for about 2hr 15 min.
Alkaline Low. Around ten lumens. 12 hours to 50%, usable light for around 16 hours.
NiMH runtimes. All done with a 2000mAh Eneloop freshly charged.
NiMH High - 64 minutes to 50%. More than twice as long as an alkaline on high. Initial brightness is much the same as on alkalines, around 85 lumens.
NiMH Medium 120 lux on lightbox at start - somewhere in the area of 30 lumens. Now rising to 200 lux / 45 lumens or so. Need to clean some contacts before next run. 2 hours and 25 minutes to 50%. Usable light till about 2:45. Some light still being emitted at 3.5 hours, i.e., I could see that it was still emitting light.
NiMH Low -- a bit disappointing this one 9hr 13 min. By 9:30 no light at all. Initial brightness around 9.5 lumens. It did occasionally muster enough current to produce a dim flash - too little light to register on the solar cell. About once every 20 seconds. These runtimes are usually done unattended, often while I'm asleep so the light may flicker or flash for low battery
14500 high. Approximately 220 lumens at switch on, approximately 160 lumens after 30 minutes. I think the cell protection is cutting in early, it was still producing over 150 lumens when the cell shut down.
14500 Medium - 490 lux or about 110 lumens at switch on. 96 minutes run time and still at 67% of initial output when the cell protection cut in.
14500 low. Cell protection appears to cut in at about 2.95V - may be lower as you have to give it a blip of charge to switch off the protection circuit. 7hr 39 min to cut out- pretty much as expected from the current draw.
Light Output: ★★★★
Quite a lot - will run the meters and get numbers. Here are some beamshots I took a while ago. The test range has become rather more reflective again and more snow is forecast.
Control
Low. At last I have found the measuring tape. The apple tree is 15.5 metres (Just shy of 51 feet) from the light and camera.
Medium
High
Summary: ★★★★★
I like this a lot. Despite its rather large size. Here it is with an 18650 and an AA
The switch is the only real irritant - it can stick when hit off-centre.
Overall definitely worth five stars. the only drawbacks are size and switch.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Edited by: sb56637 on 08/26/2014 - 17:06
sb56637
sb56637's picture
Last seen: 18 hours 24 min ago
Thanks very much Don, great review!  Excellent photography.  Frontpaged.
This looks like a very nice, well made light, and it personally is interesting to me.  My only complaint is the price- if it cost closer to $15.00 I would buy it in an instant.
Another observation is that I would like some knurling.  I wonder why they never knurl SS lights.  It does look pretty nice still after having been carried in your pocket.
As for the GITD O-rings, I think I know why they use them-- I suspect it's an economy of scale cost-cutting move.  They probably use the same material for the tailswitch boot as they use for the O-ring, and they buy the GITD rubber in large quantity at a discount, and use the same stuff for everything.
What's the scoop on the R2 LED compared to an XP-E Q5 in terms of efficiency, color, and brightness?
alfreddajero
alfreddajero's picture
Last seen: 11 months 3 weeks ago
Once again an awesome review.....i also like the light without the attack bezel.  Medium seems to be good for everyday usage.
With Darkness, there will always be Light.
Don
Don's picture
As the brightness binning goes up, the efficiency rises. A Q5 bin produces between 107 and 114 lumens at 350mA, an R2 produces 114-122 lumens at 350mA. (R5 is 139-148 lumens at 350mA)
The LED in this is an XP-E which is the same die as the XR-E but in a smaller package. Efficiency is the same as it is the same die. An R2 will always be more efficient than a Q5 for the same forward voltage. A bottom of the bin R2 is essentially the same brightness/efficiency as a best of bin Q5. The colour on this example is about as good as it gets. It is rare for a DX light to give a colour bin - this one is a coolish white, more blue than noon sunlight (Conventionally 5600K). A WJ bin would be the warmest, but WC is not bad at all 6350-700K colour temperature. I've never seen LEDs sold by forward voltage - i.e., the voltage at which they produce light. This tends to go down after the first few hours and therefore they get more efficient (up to a point) over the first several hours. Obviously, this improvement does not continue indefinitely.
SS is considerably harder than aluminium, some grades are hard enough to wreck most machine tools' edges. It is probably a lot more difficult to knurl stainless steel than aluminium and the tooling wouldn't last long. A friend once got given some scrap threaded stainless steel bar (About 40mm diameter) which he'd turn on his lathe - this stuff was so hard that it just wrecked his tools without the thread being turned off. Took some drastic heat treatment to get that stuff soft enough to machine.
Actually I have to go to some effort to get the light out of my hands by pulling on it - at least with warm and dry hands. The shiny balls on the lanyard can slide along so the lanyard can be attached to the wrist firmly.
I didn't consider the manufacturer making their own O rings. Makes sense but this one's switch cover is metal.
Just bought a new camera that can focus a bit closer - it does make picking out details a bit easier.
alfreddajero
The pics are fine bud, hey would you be able to post a pic of that klingon bezel on.......guess it makes the beam profile terrible to look at.
sb56637
sb56637's picture
Ah, so the R2 is quite an efficient LED, I didn't know that.  That is a major perk for this light.  Anyone know of any other 1xAA lights in this price range (or less) that use an R-series bin?  I'd be very interested to see how the runtime is on low, Don.
A metal switch, you say?  I didn't notice that.  That's unique.
I also like the side notch for the lanyard ring that permits tail standing.
At my former job we used to send out designs to be manufactured with a heavy diamond knurl on cylindrical surfaces.  And that was with medical-grade SS 17-4.  So SS knurling is definitely possible, but expensive.  And those were mainly one-off jobs, and that's a valid point about tooling wearing out quickly for something that is produced in large quantities.  I still wonder exactly how many units do they make of these Chinese lights?  100?  1,000?  10,000?  500,000?  And I wonder if they make them in huge batches or small batches, or even on demand?
Don
Don's picture
I kind of like the idea of either beadblasting it to get a stain finish or mirror polishing it. I think I'll try the mirror approach first just to see what happens. Time for some polishing fun....
Stainless steel is hard and therefore not the easiest thing to polish. Does make the scratches from use more evident though. Need to find out if anyone I know has a bead blaster and make it a satin finish instead. Or maybe not...
No idea of production quantities - but there are a billion people in China. I suspect that the export market is a very small part of their business. Though you never know - Russian stuff used to be sold at below the cost of production in order to get hard currency. I doubt this is the case in China as most of the world owes it money.
alfreddajero
The light is nice....would've been so much better if there was a clip installed.  Mothers polish works good.......faster if you have a dremel with a poishing head on it.
Don
Don's picture
Klingon Bezel!
I like that one Al!
Here you go. The light is tailstanding on top of a door about 60cm/2 feet from the ceiling.
Plain bezel
Klingon Bezel
The silly bezel also roughly halves the light output according to my camera's meter.
And here's the XP-E LED
sb56637
sb56637's picture
You think this F22 is legit?  The price is way better.
http://cgi.ebay.com/TrustFire-F22-Stainless-Steel-Cree-5-Mode-LED-Flashl...
EDIT: But no free shipping.  Not such a good deal afterall.
sb56637
sb56637's picture
Looks like there is an R5 version of this light, but it's definitely not budget priced.
http://www.qualitychinagoods.com/trustfire-5mode-lumens-flashlightftf22-...
Don
Don's picture
 No doubt it'll make it to DX eventually. But not at $40. QCG tends not to be cheap - I used to use them till I found DX which is usually way cheaper.  QCG makes sense once you get into their quantity discounts - but what am I going to do with 300 of any light?
Don
Don's picture
 http://www.kaidomain.com/ProductDetails.aspx?ProductId=10317
Think I'll be passing on that.
alfreddajero
With that bezel on the beam profile would just be useless if one uses side spill as well for looking, thanks Don for posting up that pic.
Don
Don's picture
Initial brightness on an alkaline (1.539V) on high is about 85 lumens. Down by about 20% after 5 minutes. Not designed for use with alkalines on high evidently. But since the alkalines are consumables I'll run the light to shutoff. Even then they may be useful in my backup mouse that can use cells nothing else will still work with.
Don
Don's picture
Down to 7 lumens and nearing the end I think. Not a light to use with alkalines on high. Gave up when I could comfortably look into the emitter. Not really useful at that level of dimness unless your eyes are completely dark adapted. Got 1 hour 52 minutes out of it to useless. The conventional runtime is to 50% which gives a runtime of 27 minutes 45 seconds. Chart to follow. Medium runtime under way.
alfreddajero
For some reason i would  never use an alkie for runtimes since im afraid of the cell leaking..........but another thought i have alkies in my rc radio when its not in use, and that radio cost me.
Don
Don's picture
It's normally when you leave them in something after they are flat that they leak. Or so I'm told. But I never leave alkalines in anything with significant current drain and faithfully throw out ones from clocks, remotes etc. annually. And I only buy Duracells for the purpose. Personally, I've never had a Duracell leak.
At least since the crap they used to sell in the 80's like the carton of around a thousand of the things (We sold a lot of them in the camera shop I worked in then) that had been put together the wrong way round so that the nipple was negative. At the time I used only Japanese batteries.
But I'm not about to risk it. The cells I am using for this are a variety of whatever my employer (Which employs over a million people) can get cheapest. But since a stores order can take three months to arrive I took in a box of my own (Our pagers eat AA batteries) on the understanding I'd get whatever we got when they finally arrived.
It was the Lucas branded ones that got me laughing - evidently they didn't realise the reputation of Lucas electrics amongst bikers. There was a reason that Joe Lucas of the firm was known as the "Prince of Darkness". I do remember various occasions when Lucas electrics failed spectacularly - sometimes with smoke.
At the moment we're getting Rayovacs but doubtless it'll be a different brand next time. I'll tell you when the order arrives. Our pagers are horrible things that cost a fortune (Over $600 each) - it would take about two leaking alkies to blot out the national savings on buying cheap garbage.
alfreddajero
Thats another thing i dont understand, if your company is willing to spend so much on good electronics then why not spend the money on good cells to go with them.  Im topping off 8 Duraloops now for the radio.
Don
Don's picture
The Cree docs are now talking about up to S2 bins - hopefully these will be available this year. At that point I'd be tempted to do an emitter swap as long as they are in XP-E format, though it seems they are moving to XP-G dies instead. The XR-E (and I think the XP-G) is now rated at up to 1.5A with adequate heatsinking (not that you are getting this in a stainless steel light) so some brutal driving of the latest bins could be seriously bright. The XP-E emitters are only rated to one amp.
But at saner currents they will be more efficient and run cooler while still giving more light. Using the stock driver which gives 1200mA or well above spec for the XP-E emitter in it a brighter bin could be fun. 300 lumens out of it ought to be achievable by early next year.
Don
Don's picture
Comes of working for the public sector in healthcare. Short-term financial objectives are all that matter. Someone has mistaken "accountability" and "accountancy". "Accountability" seems to mean taking the blame for decisions made elsewhere. Budgets have become sacred. Someone saved a LOT (tens of millions per year) of money by centralising stores orders. Junk alkies are merely a side effect.
That said, I've never had a pager damaged by a junk cell. I have dropped one down a toilet when the clip broke and driven a bus over one. It fell out of my pocket when the clip broke and I didn't notice as I climbed into the driver's seat. I've also lost one somewhere. When I got back to the office, the clip was still on my belt but I've no idea where the pager fell off. the current one got its clip modified the day I got it. It won't break now (It weighs about as much as the pager) but the battery cover which contains the + contact is now held on with duct tape. I think I've had it about ten years now.
Don
Don's picture
About 1hr 35 min to 50% on an alkaline on medium. Again, will let it run down to cell death since it isn't a rechargeable cell. Graph to follow when the cell finally dies.
Don
Don's picture
Just messed up the medium runtime. Saved it in an unusable format. Low runtime now running. 45 lux - about 10 lumens at start on an alkaline. This is at Fenix E01 levels. Should run for ages. Fan cooled - which is almost certainly unnecessary.
alfreddajero
Nice man.......What light meter do you use......and what program do use as well for graphs and runtimes.
Don
Don's picture
The meter is a cheap one from DX. http://www.dealextreme.com/details.dx/sku.20170 though the runtimes are done using a solar cell built into the lightbox which is a medium sized cardboard box painted white internally with 4 coats of gloss paint and a baffle to prevent any direct light from the torch hitting the solar cell or meter. I use a cheap USB connected multimeter that I got locally http://www.maplin.co.uk/Module.aspx?moduleno=222041. It is probably available under dozens of different brand names around the world. I got this on offer for about half of what they used to ask for it.
I use the software that comes with it which is not wonderful, but is usable. I just feed the data into a spreadsheet to produce the graphs, copy and paste the graphs into a graphics app to save them as jpegs. But I have to remember to save the data as a spreadsheet - the native DB format isn't understood by anything and the software can't open the files either - it appears to be some sort of binary format which is a pain.
I am beginning to wonder about the linearity of the response of the solar cell but that will take a lot of time and effort to sort out and calibrate properly.
I get the approximate lumens figures from a Preon 2 which is 160 lumens out the front according to several sources. It read 720 lux on my lightbox so I take a lux reading of whatever I'm measuring, divide it by 720 and multiply it by 160 to get an approximate lumen count.
alfreddajero
Okay thanks for the input...dont know if i want to go there yet, but thanks for posting the info for me.
Don
Don's picture
Now approaching 50% after nine hours. Unfortunately I'm going to have to sacrifice another alkaline to get the medium runtime graph. It runs for a little over 90 minutes to 50% on medium with an alkaline. NiMH and 14500 runtimes to follow in due course.
Still better than 50%  at 11.5 hours when I left for work.
sb56637
sb56637's picture
That's very impressive!  You might just convince me to buy this light if you get 24+ hours of usable light.
Don
Don's picture
It did the first 12 hours fine, but I don't expect it to do 24. We'll see though
Don
Don's picture
Gave me 2hr 15min of usable light on an alkaline in medium and around 16hr on low. The alkalines were all cheapos though most weigh 22-24g. A Duracell weighs 24.6g. Weight is a reasonable proxy for quality in alkalines. The lightest one, a Rayovac that did one of these runtimes was 22.4g
Next up NiMH runtimes. Time to top off some cells to make sure they are fully charged.
Starts out on an NiMH at the same sort of brightness as an alkaline on high - a hair over 85 lumens.
Don
Don's picture
NiMH low. Down to 39 lux or about 8.6 lumens. Looks like NiMH runtimes will be comparable to alkaline ones but it'll take some time yet to be certain. I expect the light to go out tomorrow about noon.
