US - Defiant ArmorMax 3D Tactical Flashlight - 3D XML light $29.97 - GET BACK TO HD NOW!!!!
135 posts / 0 new
UltimateLED
UltimateLED's picture
Last seen: 7 years 6 months ago
My thoughts on the 3D ArmorMax vs the DST 3C, as I own both: My ArmorMax has a noticeably brighter spot at a long distance and more throw than the DST, but only by a noticeable amount when the beams are both on at the same time and shining side-by-side. In practical terms, these two lights have the same beam range. The ArmorMax however does have a good bit more light output and beats the DST quite easily in a ceiling bounce or at lighting up a scene close-up.
With that being said, the DST does have a more tightly focused hotspot and lower beam divergence than the ArmorMax. The ArmorMax has a wider spot that is quite average looking in flashlight beam profile. The DST looks laser like (I use this term loosely) by comparison, and if I wanted to impress someone, I would definitely go with the DST. Its intense beam profile is just awesome looking, especially shining up into the air! Get the DST if you just want to impress with both the looks of the flashlight and a lightsaber beam.
I posted my comparison pics and reviews of these two in the new Defiant 5C 625 lumen thread.
Belt holster EDC’er of the Defiant 5C 625 lumen
Johnny
Johnny's picture
Last seen: 8 years 1 month ago
Ok I grabbed the 3D and the Tactical Super Thrower 3C today, very nice for the money!
The Defiant ArmorMax 3D came with the XM-L U2 is that what everyone’s is coming with? My star board says XML-U2 other pics I have seen posted just said XML.
My bright friends: Fenix TK40, Solarstorm Warrior, FandyFire UV-S5 (King), C8’s, SK68s, Defiant 3c and 3d
Johnny
Johnny's picture
Aftrburnr
Last seen: 7 months 4 weeks ago
FlashPilot wrote:
I added some thick copper single strand wire that I stripped from the center of some heavy coaxial satellite cable. I wrapped the strands around a thin steel rod and made a few copper springs slightly longer than the stock ones already in the flashlight. Placing the new copper springs inside the stock steel ones was all that was required before reassembly. No solder required… its probably the fastest & easiest mod Ive ever done.
With Tenergy 10,000 mAh D cells. Tail cap measurements 30 seconds after turn-on:
Before: 2.86A
After: 3.32A
Now Im contemplating an AR lens, if I can find one.
Significantly noticeable results for a SUPER EASY MOD. Thanks TP! :bigsmile:
Do you have any pics of your spring mod? I’d like to do something easy like this to my DST & 5C lights. Thanks!
garrybunk
garrybunk's picture
Last seen: 2 weeks 5 days ago
Aftrburnr wrote:
Do you have any pics of your spring mod? I'd like to do something easy like this to my DST & 5C lights. Thanks!
Here's a how-to thread: http://budgetlightforum.com/node/22529
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
tarpon31
Last seen: 6 years 1 month ago
I noticed that the 3D 590 lumen Defiant ArmorMax at the Home Depot’s close to my home uses the Cree XM-L2 now….at your all’s Home Depot location’s do they have this light incorporating this LED also?
I ask because I was about to order a couple online because the closest Home Depot to me is about a 40 minute drive and I see alot of folk’s have either the XML-T6 or XML-U2 in their’s.
Makes me wish I grabbed a few while I was at the stores because now I’m afraid to order from them online if they have sporadic part’s they use in these light’s.
I have a couple of last year’s 3D 650 lumen model with a single mode and XM-L2 in them and they have been amazing durable light’s just heavy but nice to have a few good light’s around that use standard regular batteries.
dchomak
Last seen: 3 years 3 months ago
Most of the Home Depots I have been to have this light on clearance for $15
EDIT:
As of today, April 19, all Home Depots seem to now have them at $14.06. That decrease of 94 cents to 14.06 means that they intend to eventually clear them out. If they don’t sell at $14.06 the will at some time in the future go to a “3” price. I am guessing around $7.53. Matbe in 6 weeks or so. Keep an eye out for them
Bort
Bort's picture
Last seen: 8 min 27 sec ago
EDIT:
The Home Depot Zen is strong in this one Beer
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
tekwyzrd
tekwyzrd's picture
Last seen: 21 min 56 sec ago
I bought one for $14.06 two days ago. Not impressed by the plastic reflector that scratched taking it apart. Maybe with a decent driver and cells it might be a decent light. It’s definitely the thickest, heaviest host I’ve purchased so far. Can anyone recommend a reflector?
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
ImA4Wheelr
Last seen: 1 month 1 week ago
Unless it really hurts the beam pattern, the scratched reflector may still be a keeper.
You have the OD and height? Posting those may enable someone to offer you suggestions.
EDIT: Found the dimensions in a post:
“Reflector is plastic, 60mm wide (od) x 44mm deep”
EDIT2: Fixed some typos
tekwyzrd
tekwyzrd's picture
ImA4Wheelr wrote:
Unless is really hurts the beam pattern, the scratched lens may still be a keeper.
EDIT: Found them in a post:
60mm x 44mm is good based on my measurements with my EZcal calipers. Closest I’ve found is this 60.8mm x 45.4mm
dchomak
In case you didn’t see this in the Home Depot Deal Alerts & Discussion Thread
These are now on clearance at $7.93
Some packages include 3 Alkaline D cells
tekwyzrd
tekwyzrd's picture
dchomak wrote:
In case you didn’t see this in the Home Depot Deal Alerts & Discussion Thread These are now on clearance at $7.93 Some packages include 3 Alkaline D cells
I saw it. The store in my area that had them only had 6 left at the $14.06 price and I’d be willing to bet they were gone before the price drop. i did buy one so I think I’m better off setting aside what I would spend on gas for the trip toward the blf srk fet driver and xhp-70 for a 2s4p powered srk style light I’m accumulating parts for. Currently waiting for a Boruit RJ-2013 style light with no markings to be delivered. The head will be grafted to part of an srk head to distance and insulate the driver from the emitters, increase cooling surface, and help with refinement of the design for the head of my big head srk quad. The thermal step-down will help deciding on cooling fin changes.
dchomak
I was in HD waiting for the mini Mags to go down and an employee suggested I buy them at the higher price and get refunded the difference when the price goes down. Wink
