solarforce dimensions
11 posts / 0 new
skyrider1
Last seen: 2 years 3 months ago
I was wondering if anyone could provide me some accurate measurements of the drop-in dimensions. Specifically I need:
1) The ID of the host where the drop in goes in.
2) The ID of the bottom of the brass pill. I need the diameter inside where the driver sits though (smaller than the diameter where the driver sits).
scaru
scaru's picture
Last seen: 4 years 10 months ago
I got 22.4mm for the ID of the host.
skyrider1
Alright thanks, 1) down. Just to double check, this is the inside of the TOP of the host correct? Where the drop-in would go?
I’ve been motivated to make a triple LED drop-in and need to find the right OD copper to buy.
scaru
scaru's picture
skyrider1 wrote:
Alright thanks, 1) down. Just to double check, this is the inside of the TOP of the host correct? Where the drop-in would go? I've been motivated to make a triple LED drop-in and need to find the right OD copper to buy.
Yes, this is the area where the actual drop in goes. Smile I just measured another one of my hosts and got 22.2mm.
PCC
Last seen: 7 years 3 months ago
It depends on the model. I once made a piece of copper that was a snug fit in an L2 that would not go into an L2P at all. I’m sure that a heatsink made for an early L2 would not fit a newer L2 or vice-versa.
skyrider1
Cool. Does anyone know the diameter on the side of the pills? I would assume around 16-15mm?
JackCY
JackCY's picture
Last seen: 6 years 4 months ago
Isn’t it better to buy the host and then machine the things you want for it precisely?
I mean very precisely. All hosts are a bit different. Plus you know the factory tolerances in China Big Smile
Make it a snug fit, that’s what I do with custom parts.
skyrider1
I don’t have the tools to machine things perfectly. I’ll just be taking copper and making it fit with foil wrap etc.
PCC
I don’t get it. You don’t have the tools to make parts but want the dimensions? If you’re going to wrap a drop-in to fit then why do you need the dimensions? BTW, Solarforce has looser dimensions than Surefire so anything that will fit a Solarforce will fit a Surefire but not vice-versa.
To answer your second question, it’s 17mm on the driver side and usually a bit over 16mm on the emitter side.
skyrider1
But there is a lip the driver sits on and the inside is less than 17. I wanted an estimate so I could get copper rounds as close to the diameter as possible.
I wanted dimensions so I could get things that are as close as possible, then fill the rest with foil. I don’t have the tools to get something larger and “machine” it to fit.
NightCrawl
Last seen: 5 years 6 months ago
A 17mm driver will fit nicely. The lip is a little less than 2/10mm.
I usually grind a P60 pill down until it fits into the battery tube (Solarforce battery tubes are very long, shouldnt be a problem) and solder them to the copper heatsink.
