FS: Two 1x18650/2xCR123a "tactical" lights (Crelant and Solarforce)
4 posts / 0 new
dusty99
Last seen: 3 months 4 weeks ago
I recently purchased three 1×18650 tac lights. They are all similar, but I only need one and am keeping the one that shows use. These two are “new in packaging” and never carried, just checked out in my back yard. I can’t see any signs of wear. Two great, powerful lights in small form-factor. Prices include first class shipping in US. Paypal preferred. No trades, please. Please contact me via PM.
1. Crelant 7G2CS XM-L U2 Cool White with ramping modes[FONT=verdana]. This is a very well-made light. $45
Specifications:
CREE XM-L U2 bin LED with 50 000 hour life span.[/FONT]
Maximum output: 658 lumen[/FONT]
High efficient constant current circuit and output-luminance[/FONT]
Microcontroller drive circuit[/FONT]
Tactical High Mode, and On side switch Infinitely variable brightness system[/FONT]
Hidden Strobe and SOS, Quickly click 2 times side switch —> Strobe , and quickly click 2 times again —-> SOS[/FONT]
Working voltage: 2.7VDC – 8.5 VDC[/FONT]
Battery Types Supported: 1 × 18650 or 2 X CR123A[/FONT]
Runtime High output at 2.5A: 658 lumen max for 132 minutes. Low output at 0.01A: 5 lumen max for 39 hours[/FONT]
Mil. Spec. Type II hard anodized aircraft grade 6063-T6 aluminum alloy[/FONT]
Color: Gray[/FONT]
Ergonomic grip with anti-roll design[/FONT]
Candle function with ability to stand on tail cap[/FONT]
Tactical forward tail cap switch[/FONT]
Bezel: stainless steel[/FONT]
High performance aluminum smooth reflector with concentrated beam shot[/FONT]
Waterproof: IPX-8 Standard[/FONT]
Lens: Toughened ultra-clear coated and anti-abrasion glass[/FONT]
Dimensions: Length 150mm, Head Diameter 35mm[/FONT]
Weight: 133g excluding battery[/FONT]
Accessories: Lanyard, spare o-ring, and rubber tail cap button[/FONT]
Specially designed for Military, Law Enforcement, Selfdefense, Hunting,Search& Rescue and Outdoorsman[/FONT]
Tactical-on side switch Infinite brightness accessible[/FONT]
Stainless steel retaining ring on the bezel protects the head from drops and impacts.[/FONT]
CREE XM-L LED[/FONT]
Max output of up to 658 lumens with an effective range of 300 meters[/FONT]
New hybrid reflector specially designed for CREE LED, which allows for better beam quality,efficiency and throw capability[/FONT]
Newly designed high efficiency broad voltage drive circuit[/FONT]
IPX-8 standard waterproof[/FONT]
Tailstands[/FONT]
Flickerat 3V. Cut off the power at 2.75V
2. Solarforce L2T with Stainless Steel tailcap (tailstands) and installed Solarforce 820 Lumens T6 5 mode XM-L. As new. $40.
From Solarforce:
Solarforce® 820 Lumens XM-L led 5 mode with Memory IC excellent bulb reflector, maximum the CREE led output performance
- No. of mode available : 5 Mode
100% 60% 30% SOS Strobe
Very user friend, just click on/off once to change mode
With Memory IC (turn off for 3 second will memorize the last mode, When you turn on again, it will be on that memorized mode)
The new version bulb output are more concentrate and focus, the light are bright & white
Strict quality control by solarforce, quality is ensured.
Provide 820 Lumens output for your flashlight
Compatible for the flashlight below:
Surefire® 6P,G2, G&P® T6, Solarforce® L2, L2M, L2r, L2i, L2P, L2x regular, L2T, P1
Bulb life hours: Over 50,000 hours
Input volts ~ 3v to 8.4v Bulb
Powered by:
CR123A 3.0 or 3.7 × 2
(can use rec batteries)
or
18650 3.7v x 1 or 2 pc
For this new version, you can use CR123A rechargeable x 2 pc batteries and will not hurt the led~
dusty99
$5 off each light
dusty99
Solarforce sold
dusty99
Crelant traded
