Photon Fanatic Build, Ti Neck Light (Pic Heavy) *8-5-14 Upgrade*
88 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 day 2 hours ago
Thought I’d give y’all a look behind the scenes, as it were. Fred uses Solid Works to design the product, then machines it exactly like the design. I’ve never seen autocad type work before and find it amazing that someone can design something on this level, then replicate the design on a manual lathe. It equates to sheer Genius as far as I’m concerned!
Component View TP
Fred even sent me a file with this information to be used in a Solid Works Viewer so that I could look through the components, rotate it around 360º and get a good feeling for the light from inside to out. Mind boggling stuff it is! I took the above picture as a screenshot from this viewer while looking at a 3D cutaway view of the Texas Poker on an angle. The copper pill inside the copper heatsink shows that a good portion of the head is copper with the weight of that copper being pretty central in the overall balance scheme. Very nice! Smile
DB Custom
DB Custom's picture
My 5 year old, in the background, just asked the question “What do you call a flying skunk?”
Drumroll
A Smellicopter! Smile
tolight
Last seen: 7 years 4 months ago
that is stunning!!! Shocked congrats!!
janko.hrasko
janko.hrasko's picture
Last seen: 6 months 3 weeks ago
this is pure pr0n Love
DB Custom
DB Custom's picture
Wish it were here already. lol The driver is being programmed in Germany, shouldn’t be much longer. (fingers crossed on the lucky rabbits foot while wishing on a 4 leaf clover)
DB Custom
DB Custom's picture
Well, the driver is on the way from Germany so Fred should have drivers to put in the Texas Poker within a week, should be getting the light within a couple of weeks. Wonder if I should take pictures of it with beamshots when it gets here? Smile
Ledsmoke
Ledsmoke's picture
Yes you should. No really, you should!
This is an amazing light through and through. Thank you for sharing it with us Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
DB Custom
DB Custom's picture
Bad news first? The PICcolo driver has failed muster. The prototypes made it back to Australia and there is an issue with the voltage regulation. Somehow the light will blink on hi regardless of what mode is coming on before it goes to the proper setting. So if you have mode memory set at Lo, the light will blink on hi first then go to lo. Not acceptable. I might could learn to live with that, but Matt hates it and is regrouping. And in truth, I’d like lo to be my default so the Hi blinkies would definately be a distraction.
So the Texas Poker will be getting a miniFluPic driver that doesn’t put out nearly the power. On the bright side I’ll have longer run times, on the fugly side all the searching for the highest output XP-G S2 or High Output Nichia 219 was for naught. Even the Efest IMR 10440’s are now overkill.
In truth, the light will probably be much more useable this way. But it won’t have bam! factor, we’ll see. But it would appear that I’ll now be lucky to pull 200 lumens where I was looking for something just over 300 with the PICcolo driver. 200 lumens in a pinky finger sized light is still a lot of lumens, no doubt! And this will also keep heat from being a major player in the life of my LED.
Perhaps Matt will get it worked out and I can make a swap down the road. Might even upgrade to an XP-G2 at that time, only time will tell.
And that’s part of the good news, cause now it won’t be much longer and I’ll have my Ti neck light! Smile
ImA4Wheelr
Last seen: 6 days 4 hours ago
What incredible craftsmanship. I stare as the pictures in this thread in awe.
Haterade
Last seen: 5 years 7 months ago
dood……………
This is amazing. Threads like this are my favorite, even though I don’t mod.
Sorry to hear your luck with the driver. Hope it all gets sorted without too much trouble.
For what it’s worth, I would go with a nichia219, but that’s me. Either way, this is one badass little light.
I like copper
DB Custom
DB Custom's picture
Nichia 219 it is! This is the 5000K variant at 475 lumens @ 1.5A, not the much lower output 4500K 92 CRI version. I have one on a SinkPAD copper star sitting beside me, thermally pasted to a copper bar 16” long, 1” wide, and 1/4” thick. Direct connected to a Lifepo4 with 3.35V it pulled 1.28A at the emitter and gives a nice white light, surprisingly bright! So this will be a good thing! Smile
The Dereelight reflector got mated to the copper heatsink today, mini FLuPIC should be installed shortly. I sent one of my Efest IMR10440 cells to test it with as that’s what I’ll be using in the light. That should be there Friday.
Getting close! Smile
DB Custom
DB Custom's picture
Fred has shared the last of the pics he’s taken, they’re added onto the end of post #3. The light is in the mail and I’ll be taking some pics of my own in a few days! Can’t wait! Enjoy!
Chicago X
Chicago X's picture
Last seen: 8 years 2 months ago
It's been a long journey; I bet you will be happy to finally have your wee gem in-hand.
I know it's been said already, but PF is a craftsman.  I hope to someday acquire a fraction of his skills...
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
DB Custom
DB Custom's picture
My Texas Poker is finally home, and a sweet little jewel it is!
Please pardon the quick photo grabs, had a photo shoot today and have been swamped so just grabbed some hasty snapshots.
DBC_April 29, 2013_170636
DBC_April 29, 2013_171431
DBC_April 29, 2013_171521
DBC_April 29, 2013_171558
DBC_April 29, 2013_171619
And how about a beam shot from 25 yds away:
DBC_April 29, 2013_220103
DB Custom
DB Custom's picture
And for the record, I first contacted Fred 3 Months ago almost to the day. Waiting for the custom driver or probably could have had it a month ago. Oh well. It’s sweet, works beautifully…even surprisingly so and it’s perfectly executed. Win Win Win! Smile
Bort
Bort's picture
Last seen: 39 min 34 sec ago
Very nice looking light, are you sure you want to carry it around and scuff it up?
Whats the black flashlight in the first photo?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
DB Custom
DB Custom's picture
Thanks Bort, yeah I’ll be wearing it on a ti curb chain around my neck, don’t think my chest hairs will scratch it up too bad! Wink It’ll get lots of use, already has in fact. And that beam is impressive in the dark, shines like a much bigger light! Yep, I’m a happy camper! :bigsmile:
The black light is an L2P with EDC+ Triple Nichia 219 pulling 2A between em.
The gold L2P is waiting for Matt’s Hyperion, Triple XP-G2’s at 5+Amps total! Smile
Ledsmoke
Ledsmoke's picture
Through and through. Awesome!
Thank you for sharing this DBCstm
It is wonderful to see something so special come to fruition!
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
MRsDNF
MRsDNF's picture
Last seen: 1 month 5 days ago
Simply amazing. Fantastic light. You’ve probably mentioned it somewhere but what battery and driver are you using? I cant wait to see the pill for the HD2010 he’s making. Wink
BIGWOOD
BIGWOOD's picture
Last seen: 9 months 4 weeks ago
Saaaweeet!
Love the pics, love the light, thanks for sharing.
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 2 days ago
Wow! Wow! Wow!  What a beaut!!!  Love
DB Custom
DB Custom's picture
The battery is an Efest IMR 10440 easily capable of 3A or more. This I know because I accidentally shorted it for a split second and it burned a blister on my finger! Dang thing is potent!
The driver is a mini FluPIC (10mm diameter!) with preset Lo, selectable Med (1 of 10 levels selectable in mode 5) and a full out Hi (which is supposed to only be 650mA but it’s very very bright on this Nichia 219 5000K) For some reason mode 4 is a blank. Mode 5 makes the selection for mode 2 (med) and it has a memory that kicks in at just under a second. Low voltage cut-off at 2.8V. No funny noises, no blinkies of any kind.
Who’s making a copper pill for a HD2010? I thought YOU were doing that for me?!? Wink
DB Custom
DB Custom's picture
My 5 year old is in love with it, thinks he should have it. (His very words) When told that it’s mine, he’s like, “Well have him make me one!”
DB Custom
DB Custom's picture
Yeah yeah I know it’s not fair, but the EDC+ is one of 2 lights I have that has been tested in a sphere at 720 OTF lumens. The TP holds it’s own pretty well, of course the EDC+ Triple has more spill so the throw comparison is kind of a leveler to split the difference on the sheer size and battery power difference, not to mention 3 emitters.
Texas Poker vs EDC+ Trip XP-G2
Same settings, pitch dark out with not even a moon. Shot with the 5DMkII and 100mm Macro 2.8L IS. Settings mimicked what I saw. Cropped into the shot for a 5×7 @300 dpi from the larger 13×19 300 dpi shot to show detail on the oil drum 50 yds out. A tiny AAA format light that throws 50 yds! Not too shabby! Smile
DB Custom
DB Custom's picture
In actuality the XP-G2 emitters in the EDC+ are very similar to the Nichia 219 5000K emitter. And they’re pulling 2A for a theoretical 700mA to each, which is just 50mA more than the mini FluPIC drives the Texas Poker. So the difference is mainly in optics vs. reflector divided by total number of emitters squared minus the ambient temperature and the weight of a Super Taco. Oops, sorry, got carried away there. But obviously the emitter comparison with the power it’s given is quite similar. Both lights have the emitters mounted on copper. Both are in copper heatsinks. One is awesome. One is black.
One light is just severely outclassed. Smile
Pulsar
Pulsar's picture
Last seen: 3 weeks 3 days ago
that came out awesome! congrats on the functional work of art. jealous.
DB Custom
DB Custom's picture
Thanks Pulsar. The large hole in the tail was intended for my Ti curb chain, but I decided to do some reshaping on a McGizmo Ti gate clip so that the end is more rounded and fit’s the Texas Poker readily and mount that on the chain instead. I took the clasp out of the chain and reattached the links so that it’s a continuous chain with no break, the Ti gate clip hangs from the chain and the light is easily removable for use. This way everything that can be is Titanium, even the spring on the gate clip.
Don’t know if it’s water proof enough to just leave on in the shower or swimming, need to ask that question. With the o-rings it has in it I would think it would be safe for 30’ or less.
Low is very nice in the night. Hi is intense. Med I can set where I want it in 10 steps from Lo to Hi, have it at 4 for the time being and it’s looking like that’s a good choice.
DB Custom
DB Custom's picture
Couple of new pics, what can I say, I’m obsessed. Smile
DBC_May 04, 2013_120302
DBC_May 04, 2013_120812
DBC_May 04, 2013_121207
DBC_May 04, 2013_121353
TP 12L
Did I mention that I LOVE this light? Smile Wink
Hikelite
Last seen: 5 months 4 weeks ago
Awesome work DBCstm !
DB Custom
DB Custom's picture
Thanks Hikelite, how about an accessory from Photon Fanatic to match the light? A battery holder for the keychain so a spare cell is always ready to go…
BBC-1
BBC-3
Looking like a very large bullet, it’s Texas Poker Ammunition. Smile
