This battery needs a 4.3 volt charger to get maximum capacity.
With a 4.3 volt starting voltage the output voltage from this battery is higher than most 4.2 volt batteries.
Test with 4.2 volt charging
Using a normal 4.2 Volt charger looses about 210mAh and some of the voltage advantage.
Conclusion
Being from Sanyo it is a very good battery. Using the battery with 4.2 volt it is close to 2600mAh batteries in voltage, but with slightly less capacity. Using a 4.3 volt charger the battery has a slight advantage over 2600mAh batteries.
Thanks HKJ! I wish you had tested the protected version as I am interested in hearing where (or if) the protection trips when trying to charge to 4.3v. Seems there is mixed feedback on what voltage it trips.
Look closer…its a test of the UR18650zt which is the 2800mAh 4.3V cell, same as the tested one in this thread….
And the standard protectioncircuit trips at 4.2V, i have this cell from cnqualitygoods. Still the FM is the way to go for sanyo cells.
Thanks for the tests HKJ!
My testing on these produces very similar results. I have purchased 20 of these and I like them for the additional run voltage, even if capacity is a little lower than rated.
Discharged at 1A:
Yes indeed the protection looks different from the one I have or the ones fasttech sells, but i guess if it has a overcharge protection it will still cut below 4.3V…
I have thought about modding my protection circuit so that it alows to charge to 4.3V, its a simple voltage divider.
I do not plan to check the protected version in the near future, but I will soon (next week) publish a review of another cell with tests up to 30A (Rather impressive cell).
As per this thread, I charged up my two protected KeepPower Panasonic 18650 3100's in my Nitecore i4 and they charged to 4.27v and 4.28v! Keeppower are supposed to have some of the best protection circuits in use. I don't intend to find out however at what voltage they do cut-off.
With protection circuits you can buy the protection chip to with different voltages, i.e. you cannot be sure that the manufacturer always uses the same chip.
I did trip one over voltage protection on a Keeppower cell, the cell was 4.35 volt, but the protection tripped at 4.34 volt.
I noticed that they simply quoted the manufacturer in the forum thread on this topic. No test was performed.
You can always try charging up to 4.3V since the cell is rated for it. If it doesn’t cutoff then you’re good. I suppose you might no want to take the chance on purchasing them just to find out.
I can’t find your stickies with summaries, but I’m thinking a ‘plausibility index’ may be useful.
This would be claimed battery capacities superimposed on a Ragone Chart. Batteries that landed farther away for the colored zones for each technology would be less plausible. This is a bit beyond my programming skills.
The ratio of claimed vs. actual measured performance may also identify battery makers who habitually make up nonsense while they troll for gullible buyers.
All of this info should probably be updated twice/year as makers adjust their strategies and production lines to meet rising or falling sales.
I meant that 4.34v was too high a cut-off level for a protection board designed/intended for a 4.2v cell. Thanks for the info on the Panasonics specs.
I may just go ahead and get the protected Sanyo 2800's "for the good of the BLF community" and report back on if/when the protection trips. What is Sanyo's safety spec for overcharge? Same as Panasonics? I guess it varies based on cell.
