Sense resistor mod to KD Super Output P7 Driver
27 posts / 0 new
AlexGT
AlexGT's picture
Last seen: 37 min 34 sec ago
Question for the forum Gurus and Experts!
I have this Kaidomain driver that I use with 2 × 18650’s (8.4v) and gives around 3A to the led
I am wondering if it would be safe to solder one additional R120 resistor on top of the existing R200’s that the board currently has (3 o’clock position in the pic) and if I will get an increase in current to the led by doing this, can anyone estimate what the new current to the led would be by adding one R120 resistor?
Thanks in advance for your help!
AlexGT
Edited by: AlexGT on 03/12/2013 - 22:37
AlexGT
AlexGT's picture
Well, I just went ahead and did it and current did increase a bit, now using 2 18650’s is pulling 2.3a from a stock 1.8a, now my custom 2 1/4C Mag With Throwmaster reflector rivals my modded TN-31.
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 2 weeks ago
Nice work If you edit your post to include the name of the driver, then searches for this mod will find yours. I.e. Sense resistor mod to KD Super Output P7 Driver.
Scott
AlexGT
AlexGT's picture
Agreed, will change it for future reference
FlashPilot
FlashPilot's picture
Last seen: 1 day 2 hours ago
Nice mod Alex. I have this driver. Were your measurements from the tailcap or at the emitter? Also, have you ever experienced the thermal cut-off feature this driver was noted for? What about low voltage warning?
Rufusbduck
I’ve used this driver for a few different mods, 2 bike lights and one handheld. 7x nimh for the bike lights and 6x nimh for the handheld. Both features functioned as described in Kd’s specs. A different blink for each and shift to low mode. I think lowV is two blinks and over temp is 3 blinks.
Scott
AlexGT
AlexGT's picture
Current Measurements at tailcap
gords1001
gords1001's picture
Last seen: 3 years 5 months ago
I can see me trying this, I have a couple of these drivers and like them a lot, boosting the current output is very pleasing to me.
gords1001
gords1001's picture
Ok, I see this being used in an upcoming build, it seems 4.5a drivers are few and far between.
Just need to track down some R120 smd resistors now because a pot won’t work here Flat Stare
Flomotion
Flomotion's picture
Last seen: 6 months 6 days ago
Fasttech carries smd resistors:
http://www.fasttech.com/category/1002/resistors/?smd%20resistors
http://www.fasttech.com/products/1002/10003143/1234403-0805-012r-smd-pre...
Flomotion
gords1001
gords1001's picture
Cheers flow, just what I needed buddy 8)
benz
benz's picture
Last seen: 5 days 7 hours ago
Does anyone know if fitting another R120 resistor will increase the output current further?
bdiddle
Last seen: 1 week 2 days ago
I forget what resistors I added to mine, but it pulls ~3 amps at the tail
Newb
photon1k
photon1k's picture
Last seen: 4 years 8 months ago
Adding another R120 will lower the total sense resistance, and very likely increase the output current, but the driver may or may not be able to handle it.
Edit: Has KD missed a decimal place? This thing cannot possibly cost $43.99.
bdiddle
That is for 5 pcs
Newb
photon1k
photon1k's picture
Thanks. Didn’t notice that… :8)
photon1k
photon1k's picture
Lightmalls has a better price.
bdiddle
Wow thanks for showing that, of all the high output drivers I have used that one has been the least troublesome.
Now I can get it cheap…..
Newb
benz
benz's picture
Thanks bdiddle, at least I know 3A at the tail is possible.
Rufusbduck
Anybody try this driver with an mt-g2 off 2 cells?
Scott
richnpc
Last seen: 1 week 2 hours ago
Is that the driver that Match used his 4M mod?
http://budgetlightforum.com/comment/reply/16168?quote=1#comment-form
Rufusbduck
I think so.
Scott
Rufusbduck
Bump, anyone get emitter current after the sense resistor mod and is the driver still working?
Scott
A380
A380's picture
Last seen: 3 months 1 day ago
I have tried to make the resistor mod also.
Original output to the emitter 3A.
Adding 1xR200 3.98A.
2xR200: low 0.49A, mid 1.5A, high 4.97A.
Found really difficult soldering this tiny things and have to figure out how to add heatsinking mass to it.
crz6662
crz6662's picture
Last seen: 2 weeks 2 days ago
Both the links to this driver are dead. Anyone have a good link please?
Rufusbduck
Scott
crz6662
crz6662's picture
Thanks Rufusbduck……
