night riding
14 posts / 0 new
scoobybright
Last seen: 8 years 5 months ago
night riding
Here in the UK the nights are getting lighter, but there is still a couple of hours left to carry on mountain biking at night. What do others use as their light source.....remember its a budget light forum.
I use :ssc P7 c bin, Manafont Ultrafire XM-L C8 on the bars
and a trustfire 801 on the hat
I might use a C1 on the bars as a backup
XM-L is my new one with awesome light source
Don
Don's picture
Last seen: 11 months 4 weeks ago
Ultrafire C 303 on your hat might be good and not too expensive. It gets darker earlier in Lancashire than it does in Aberdeenshire so you'll need a bit more light in summer than I do. The C303 will give you a LOT more light than the TR-801.
A lot of things giv more light than a P7 these days - get an XM-L dropin for the C1 and life will get a lot brighter.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
33696933
33696933's picture
Last seen: 6 years 10 months ago
I use 4 KD C8 XML modified to use a 1S4P battery pack. More than enough light to do most of my moutainbiking.
jacktheclipper
jacktheclipper's picture
Last seen: 18 hours 37 min ago
I use a Solarforce L2 with the UltraFire 3 mode Xml in a Twofish lockblock . On medium . Before that it was an iTP SA2 .
What I do
ledoman
Last seen: 1 week 19 hours ago
I use not quite budget but still in range MagicShine MJ-808 headlight on helmet and a few zoomies (not all at once Wink) on bar.
Last time I've tried MF XM-L dropin in a UF504d host. Good and shiny, but sometimes battery has to loose contact or there is something wrong with the switch. Under heavy vibrations it changed modes by itself. I've used protected flame 18650 which is long enough I think. Anyone has idea how to prevent self changing modes?
Budgeteer
Budgeteer's picture
Last seen: 8 years 2 weeks ago
Single mode driver? XD
Tried to fiddle with the switch and springs yet?
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
NiBi
Last seen: 7 years 7 months ago
I use 504B xpg r5 with extension and high voltage 3 mode driver on high, half of the lens painted with silver colour as dipped headlight on the bar second light mountSmile  whatever i want mostly Skyray r5  or 504 xml as upper beam.  Helm lamp is tr 801 or for throw Skyray 1JC8.
AAA: Black Cat   AA: SkyRay S-A1,  Uf 501c (2AA Q3),   18650: Uf 501b (Xenon),Uf 504b (R5), SkyRay S-R5 , TR801, SkyRay 1JC8
ledoman
Don't have single mode driver nor I want to instantly drain my battery during downhill ride Surprised.
I didn't look into spring and switch yet. Probably I'll try some other host first. Well in fact I've recall this problem because of Night riding topic.
Budgeteer
Budgeteer's picture
You want to stiffen somehow the springs perhaps by adding more springs on top of the already present ones. It would probably do the trick.
pounder
pounder's picture
I run my solarforce masterpiece on my bike..I did it once for fun and now I can't go to anything else..2 hours on high and proper heatsinking makes it a joy to use..I still remember the one guy I blinded on the bikepath who had no light..he looked like a train was coming at him or something lol..only problem is you need a heavier bike mount because of the added size of the light..the one plastic one at DX works great for this size of light..
jacktheclipper
I've had no problems with mode changing with my L2 but I always wrap the batt with masking tape so that it fits snugly .
What I do
ledoman
I'll take a look about spring. It could be even worse if I would use KD 8*AMC driver. I'll try to add some 12mm magnets at the battery tail, but have to check if there is any lose of current. That would be even easier than spring trick Wink.
Budgeteer
Budgeteer's picture
If you value yout teeth use unprotected batteries or time accordingly the battery swaps before the pcb kicks in and you get "kicked" a few seconds later.
ledoman
That's why I'm using at least two lights at same time. It's very unlikely two copmletly separated one would fail in the same moment.
