OEM D11 More of an introducton than review
9 posts / 0 new
Itinifni
Itinifni's picture
Last seen: 2 days 10 hours ago
I haven’t the skill or patience to attempt a review but since I haven’t seen mention of this light I thought I’d throw this out for anyone interested.
I’ve been gradually changing my P60s over to XM-L2s and XP-G2s, mostly in warmer tints. That’s great but I’m left with
XM-Ls on 16mm mcpcbs and I can’t stand seeing them just sitting there. I came across the D11 1×18650 HAIII Flashlight host Kit For CREE XM-L/XP-G LED while browsing CNQG and ordered it. I’m not sure why but for some reason I like the looks of it.
It arrived today wrapped in about a pound of bubble wrap. When I finally got it open I realized what they meant by “Kit”
I assumed it was going to be an assembled light, just add a driver, LED and battery, so much for that plan. Even the switch had to be assembled.
That said, the quality of the components seems pretty good. The ano is free of any chips or blemishes, the OP reflector looked fine, threads dry but clean and smooth. Even the pill is heavier than I expected. The kit includes isolation disks for both XP-Gs and XM-Ls, it even includes an allen wrench for the pocked clip screws.
I decided to start with the switch. Other than swapping some P60 switches and modding a few D Mag switches I haven’t had to solder any of these small switches so I did what I usually do…failed miserably on my first attempt. After putzing around getting the switch perfectly centered on the board I found it wouldn’t click anymore. I guess a little too much heat for too much time, the same thing I did when I started playing with drivers.
Lucky for me I had two spare SolarForce reverse clickies in the parts bin. The SF switch is almost as large as the D11 switch board but with a little work it fit just fine.
I used a CW XM-L along with a KD V2 8*7135 driver, this is one with the moonlight low mode.
The final product.
I choose not to install the pocket clip.
Basement beamshot, just to give you an idea of the beam profile, camera settings on full automatic. It’s about what you would expect from a small reflector XM-L. In the picture the light is only about 3 feet from the door, at any distance the beam appears perfectly smooth with almost no hot spot.
As soon as I swap one of my NW XM-Ls out of a P60 I’ll move it into this light.
I should also mention that an AW protected 18650 fits but is very snug, both in length and diameter.
I think I’m going to like this light!
I remember a time, when I searched for lights to fit my needs. Now I search for needs to fit my lights.
Edited by: Itinifni on 03/25/2013 - 22:27
AlexGT
AlexGT's picture
Last seen: 8 hours 32 min ago
I like it!!! :bigsmile:
apt323
apt323's picture
Nice build sweet light
JohnnyMac
JohnnyMac's picture
Last seen: 2 weeks 6 days ago
Nice light!
Slim Pickens
Slim Pickens's picture
Last seen: 1 day 11 hours ago
I like it! Looks cool.
djozz
djozz's picture
Last seen: 4 hours 51 min ago
Cool light!
Chicago X
Chicago X's picture
Last seen: 8 years 3 months ago
I've always liked the look of that kit; glad to hear it is of decent quality.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
RaceR86
RaceR86's picture
Last seen: 5 years 8 months ago
A nice review if you ask me! Smile
Thanks for taking the time and sharing! Looks like a sweet light..
Is it waterproof on the same level as a typical light?
How would you say the heatsinking is compared to a standard looking light of this format?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Itinifni
Itinifni's picture
I don’t think I’d take it swimming but wouldn’t hesitate to use it in driving rain. It has double “O” rings at the head and tailcap but only a single on each end of the reflector. The rings could be better quality but easy enough to change.
As far as heatsinking it’s the only light of this type I have so I have nothing to compare to. The entire body gets hot very quickly on high, not bad as long as I hold onto it but don’t set it down.
The vast majoriaty of the time the 1A medium is more than enough light for my needs and far less heat.
