Pre-order now ReyLight (TrustFire MINI-02)
120 posts / 0 new
tolight
Last seen: 7 years 6 months ago
i still haven’t received my shipping confirmation/tracking… any updates? thanks!
Smile
gords1001
gords1001's picture
Last seen: 3 years 4 months ago
got mine today, I like it, I also like that the driver would fire up and give all three modes on an aaa I had in my van, the two spare drivers will be going in aa hosts with xp-g2’s for my two boys (age 1 and 2 lol) I shall probably badger rey for more drivers as well as I know of few primary/lithium capable drivers.
This light will be my dress edc so wont see too much use but will be nice to go with my dress pocket knife. 8)
I also now need to build another 16340 light as I dont like spare cells lying about…. :bigsmile:
Don
Don's picture
Last seen: 12 months 3 days ago
It is neither lighter nor smaller than the Mini-01 to my surprise. At the time I got the 02, my 01 was attached to my car keys which were with the mechanic doing the annual roadworthiness test (MoT in the UK).
My Mini-01 (no cell) weighs 41.7g, the Mini-02 47.4g. The Mini-02 is about 4mm longer, but a hair less in head diameter. I can't find my calipers to measure how much smaller. Quick lightbox numbers on an IMR 16340 and the CR123 primary that came with the Mini-01.
Mini-01 (used) CR123. Mine is the high/low/strobe version
Low    69 lux 12lm
High   812 lux 146lm
TLF Mini-02 (used) CR123 - same cell as above. It is a neutral white version. Beamshots etc will have to wait till it gets dark.
Low 19 lux 3lm
Med 152 lux 27lm
High 671 lux 120lm
Mini-01 (Not fully charged) IMR 16340
Low 153 lux 27lm
High 1389 lux 249lm
Mini-02 (Not fully charged) IMR 16340 - same cell as above
Low 30 5lm
Med 372 67lm
High 1130 203lm
These aren't exactly lab-grade results but are indicative.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Boro
Last seen: 5 hours 4 min ago
Thanks! The 3 step spacing looks good.
Hope the tint looks as good as the Mini 01.
thanks,
tolight
I just got mine today! Charging up the 16340 as we speak… had a brain spazz when ordering though… wanted an XM-L2… ordered XM-L NW… arrgh!!!!
I don’t have the mini01 for comparison, but it sounds like this one is a step down from the original?
gords1001
gords1001's picture
I’m pleased with mine, mode choice with a twisty will take some getting used too but a little grease has helped, the tint is nice and pwm is acceptably high. It also looks classy so will suit my intended purpose, I just wish, as I do about the blf a8 driver that I had ordered ten or so drivers, they would have made an excellent basis for some Christmas gifts, I hope rey has more available.
tolight
ok… my 16340 is charged up (measured 4.18V)… popped it in… turn the light on.. low … good… med… good… high… a brief flash, then it shuts off… while screwed down/engaged….
whats going here? the light can’t handle the 16340 on high??!
help!
tolight
just tried the other 16340 i ordered (3.8V)…same thing… high doesn’t work… it just flashes and shuts off… anyone else??
thanks!
gords1001
gords1001's picture
mine is fine on high, what 16340 are you using? trustfire flame?
tolight
Same TFs offered with this deal…. Sad
radiancez567
Clean the contacts and threads and try again?
tolight
I did take the light a part to clean and grease the threads while I was waiting for the battery to charge… The only mode that does not work is high…. If it was a contact issue wouldn’t I have issues with the other modes as well?
Thanks!
fleibaka
Last seen: 8 years 4 months ago
Thanks!
The protection circuit modules from the battery is too sensitive, below 3.8V it will work.
The TF16340 I´ve got for testing with Mini-02 has worked fine.
fleibaka
tolight
fleibaka
OK…thanks! So to clarify, this is an issue with the batteries and not the driver? Would the fix to be remove the protection circuit? Are the batteries bad?
Thanks!
fleibaka
this is an issue with the batteries and not the driver!!! I´ve tested with some batteries.
to remove the protection circuit will solve the problem.
The batteries are good, but the protection circuit is too sensitive, and that is bad!
fleibaka
tolight
Thanks for the clarification.. so it is most likely i got a ‘bad’ batch of batteries with overly-sensitive protection boards….?
I’m not sure if I’m prepared to deal with non-protected batteries as I am still a newb when it comes to li-ions… crap… another suggestions for new batteries?
thanks again!
Dobanodnao
Last seen: 7 years 9 months ago
I got mine yesterday. It looks fine, no visible flaws and I grabbed the 2xTF’s with it, both read within 3.86-.87v. NW seems to be a good tint, noticeable next to my 60w warm cree bulb and U2 XML.
It does not want to switch modes if I do it slowly however when an more abrupt, rapid moment is used it is not generally an issue. High pwm, though slightly noticeable. I still have to charge them though, so I’ll report back if that changes the switching function.
ReyLight
ReyLight's picture
Last seen: 1 day 23 hours ago
it's the battery problem.  I asked TF to change the protect PCB.
some orders to US by ePacket is fast,others are on the way.
Werner
Werner's picture
Last seen: 2 years 3 weeks ago
Is the driver software redesigned or the same crappy bugs in it?
tolight
WWEFANS wrote:
it’s the battery problem.  I asked TF to change the protect PCB.
confirmed on my end… battery works only at 3.8V, or less… :~
thanks to fleibaka for the suggestion/diagnosis
JohnnyMac
JohnnyMac's picture
Last seen: 2 weeks 5 days ago
This is a real good question.  I sure hope someone *cough* Rey *cough* took the time to have Trustfire clean up their code and remove that preflash when going into low.  I really hate that in my original BLF Mini.
tolight
still there… :(, but intermittent… i am finding the threads a bit rough compared to my other lights… perhaps because its ss? or maybe rear spring is too big (too much pressure)?
dusty99
Last seen: 3 weeks 2 days ago
Got mine yesterday. Fired right up and looks pretty good. Nice tint, good heat dissipation (toasty!), great size. The threads are a bit rough (you can see the machining issues between the threads) but some Nyogel has it feeling pretty smooth. BUT, I am also having the mode hiccup, at first when the light got hot running the TF “880s” right out of the box (but I found that if I cycled through a few times I could still get to “high”), but with the first TF run down, recharged and hot off the charger, I couldn’t get to “high” mode at all (just a bright flash), so it was a 2-mode light. Once the battery ran down a bit (to about 3.85v) I got all three modes. And when the light is hot and turned off, then on, I only get “low” mode, until it cools down a bit. Doesn’t that last problem sound like a driver problem and not a battery issue? The modes cycle flawlessly with a 3v CR123 but I bought this light for output, and @ 3v it’s not much different that my 1XAA lights.
And one more thing: a 47s-branded CR123 doesn’t fit but a regular Panasonic USA model does (and I thought Panasonic made the 47s 123s…)
Rey: If the problem lies with these batteries can we get them replaced?
gords1001
gords1001's picture
givwn the price I paid for the cells, I wont be worrying,I’ll likely just source some others at some point, I intend to build a couple of 16340 lights now anyway and I dont intend to drive them hard.
out of interest, what are people reading on high at 4.1v?
Don
Don's picture
IMR 16340 (Not all that many cycles on it (I think)).
4.06V since I got bored waiting for the charger
40mA low
630mA med
2140mA high
Since that’s about 2.5C on high for an RCR123 I’d seriously consider using IMR cells as anything above 2C is out of my comfort zone for cheap LiCo cells. But it may be that the internal resistance of cheap LiCo cells is enough to limit the current.
Mine is an NW version by the way.
I’ll fully charge the cell and try again at 4.2V. Results in a bit.
I can do the same for my CW Mini-01 if you want.
gords1001
gords1001's picture
no thats fine thanks Don, my meter got very very wet and needs calibrating/replacing, its a bit high for my confort on such little cells as well tbh, I’ll probably hunt down some inr’s at some point.
for my builds I was only planning on a max of 1.5a so hopefully the cells will be fine at that.
Don
Don's picture
Take a look on eBay for ex-MoD Fluke 15s. They’ll be out of calibration but it shouldn’t cost all that much to get them recalibrated – and they tend to cost around 20 quid delivered. The MoD has recently (In the last couple of years – last time I looked on the Bay I found hundreds of them) disposed of an awful lot of them.
I got a Fluke 77 Series 3 which cost me about 30 quid to get recalibrated and the fuses replaced – and about 15 quid to buy.
Where I work, they bin the Fluke or Tektronix meters when the calibration certificate expires. I can check when the next lot’s certs expire and arrange that the bin is where I can get to them. (Just occasionally, working for the Man has its uses)
No guarantees when that will be though.
And the first Tektronix is mine!
Werner
Werner's picture
I use a yezl and a nitecore in my mini 01… No problem so far with the serious current. I also have used the BLF mini driver in another host with an nitecore 14500 for longer run times without problem and one time a trustfire 14500 but the undervoltage protection tripped fast.
@Tolite: The minis need some lube to operate smooth one drop of oil s should be enough, some reported that after one week with battery inside the spring was a bit more compressed so that this made it smoother too…not sure about that.
How are the lights compared, is the 02 much better or about similiar? How is the feel?
I am fine with the original mini01(i have it on my keys and use it every day) as I want to start in high(brighter is better)
The BLF mini01 driver has another issue beside the pre flash, sometimes there is a 4th mode with 0% duty cycle, which means its switched on but no light comes out…I wrote this in the BLF mini 01 thread after finding it out but no one answered…
I searched eBay for the meters but couldn’t find any fluke in budget range. Can you provide a link?
Don
Don's picture
My pet annoyance about the Mini-02 is that it doesn’t “close” properly. Pics to follow. the Mini-01 (Mine has flashy modes) does this better.
gords1001
gords1001's picture
keep us informed on the meters don, mines a megger I’ve had a long time, I’m hoping the calibration firm can repair it to be honest, I’ll have a look on the bay as well though.
