INTL-OUTDOOR Direct-Thermal Copper MCPCB Review
86 posts / 0 new
PilotPTK
Last seen: 7 years 8 months ago
About the time that everyone caught wind of the International Outdoor Copper MCPCB for XM-L and XP-E/G, Hank from International Outdoor got in touch with me and asked if he could send me a couple of them to review. I agreed.
These are pre-production versions, and I understand that that silk-screen markings on them will be changing, but otherwise they’re the same as what one would expect to be able to buy later this month.
These were sent to me at no cost by Hank – just for full disclosure.
So, Here’s the MCPCB. Direct Thermal Attach with no insulator between the base material and the thermal pad on the LED. Copper is very lightly gold plated to prevent tarnishing. Surprisingly, the bottom side of the PCB is also gold plated which is great!
The top of the electrical pads is perfectly planar with the top of the center slug – as should be expected.
On one of the samples I received, I cut away the insulation layer to expose the base copper. This shows quite nicely how the center thermal slug is solid copper rising out of the base.
On some MCPCBs, the insulating layer is not very well attached to the base copper, and it can detach itself during the extreme heat of reflow. I heated the whole MCPCB up to 250 degrees C and used a sharp blade to try and separate the layers of the PCB. I was unsuccessful. The layers of the PCB are very well joined together.
The footprint for the XM-L is perfect with the proper solder mask openings to allow excess solder to escape – this helps to assure that all three connections are made without the emitter floating too high off of the MCPCB.
The samples I received are 15.93MM in diameter, the base copper material is 1.25MM and the overall thickness is 1.5MM. The back side of the MCPCB that would attach to the pill or heatsink is very flat with only very minor burring around the edge. 30 seconds with sandpaper or a file would leave you with a very good thermal junction.
Here’s a video showing the MCPCB at different angles.
The primary competitor to this board will be the SinkPAD board available from several members. As surprised as I am, these boards are better in one important way. The back side is completely flat and does not have a punched out center slug. This means that the (most important) area directly below the emitter is making contact with the pill/heatsink. This is quite a benefit!
I was curious how much difference the extra contact area would make, so I ran a thermal simulation on two identical MCPCBs – One with the punched out slug and one without. These numbers should only be used as a comparison between the two styles of MCPCB – not as an expectation of what absolute temperature an emitter will run at. I used an ‘infinite’ heat-sink as I only wanted to see the difference in temperature rise through the board with no attention paid to the type of heatsink or host.
SinkPAD style Punched Thermal Pad:
INTL-OUTDOOR Style Flat Bottom
As I expected – There is a measurable difference! Having direct contact with the heat-sink right under the emitter makes a difference.
I’m very pleased with these boards from Intl-Outdoor, and I thank Hank for giving me the opportunity to see them in advance of their public availability. I’ll be buying more of these as soon as they are available.
If I was forced to come up with one complaint, it would be the wire connection pads. I wish they were just a little bit larger. Not a big complaint, but for those less skilled at soldering, it makes for a small connection point.
PPtk
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
moderator007
moderator007's picture
Last seen: 1 week 4 days ago
Thanks for doing the test and review PilotPTK. Very valuable information.
Seems like the process of making copper MCPCB’s is improving.
I’am sure it wouldn’t be long before will see them at all our favorite go to stores.
Thanks again!
relic38
relic38's picture
Last seen: 3 years 9 months ago
Thanks for the review PPtk! One question. Can you look closely to see how the slug is attached to the base material? Is it one piece, soldered, pressed in somehow?
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
Bort
Bort's picture
Last seen: 7 hours 15 min ago
This thread has reminded me to hold off on my intl outdoor purchase till these become available
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
moderator007
I always wondered why SinkPad pressed it from the bottom. Looks like they would have pressed it from the top like president Lincoln on a penny.
PilotPTK
It really appears to be a single piece. I’m not entirely certain how they do it, but it’s a great design.
PPtk
relic38
relic38's picture
Cool! I’ll be snagging a few to try out.
Welcome the night.
texaspyro
Last seen: 2 years 3 months ago
Milling? Kung Fu magic? Optical illusion? Demon worship? I’d put my money on option 1 or 4.
Bort
Bort's picture
how does the gold bottom affect thermal transfer?
Also have you tried removing it to see if it has the depression like the sinkpad?
texaspyro
Gold has 3/4 the thermal conductivity of copper… on these things it is not thick enough to matter.
FlashPilot
FlashPilot's picture
Last seen: 3 hours 47 min ago
Thanks for such a great review. Lets hope the actual production samples (solid slug design) dont change.
whokilledJR
Last seen: 17 hours 56 min ago
Thanks PilotPTK, these will really sell like hot pancakes and I hope Hank orders enough for everyone, the first batch sold really quick. Great to hear it’s of a good design and function.
RaceR86
RaceR86's picture
Last seen: 5 years 8 months ago
Thanks for review..
As far as I can see from where Im sitting. The 16mm Sinkpads are the only copper MCPCBs that can be made into 10mm. The ones from intl-outdoor could be turned into 14 it looks.
But the ones from intl-outdoor will offer quite more bang for the buck. Flat underside and that there are space for access soldier to go away from the center is just icing on the cake!
Looks to be a winner! Cant wait to get mine…
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
MRsDNF
MRsDNF's picture
Thanks PilotPTK for the review. Also a big rap to IOS in allowing PilotPTK to review this MCPCB before release.
ryansoh3
ryansoh3's picture
Last seen: 8 months 3 weeks ago
Interesting, thanks for the review.
Will you do direct lumen comparison tests against the SinkPad?
Cheers!
BLF ≠ B-grade Flashlight Forum
JamesB
Last seen: 5 days 15 hours ago
Good to know that the MPCB bond to the copper substrate is solid, the MPCB on the copper stars i got from ledtech.de were VERY delicate.
Thx PilotPTK.
djozz
djozz's picture
Last seen: 10 hours 9 min ago
Thanks for the thorough review. And for the great piece of video art, loved that B-) .
garrybunk
garrybunk's picture
Last seen: 2 weeks 3 days ago
Wow! This sounds very good! Looking forward to these being available! Just hope Hank doesn't underestimate the demand for these! Thanks PilotPTK!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
Slim Pickens
Slim Pickens's picture
Last seen: 19 hours 40 min ago
Thanks for the in-depth review, PPTk! These look to be a great value. Hopefully Hank has a lot of these in stock…
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 13 hours ago
PilotPtk great review. On your thermal test did you compare with the thicker Sinkpad design or were both models set at 1.5mm?
Scott
PilotPTK
I kept them both at 1.5mm because I wanted to compare apples-apples. I used 20 degrees C as the ambient temperature and put the stars on an ‘infinite’ copper heat-sink. That means that it conducts the heat away at the rate of copper, but it never heats up. I set the thermal generation rate to 8W on the top of the thermal slug.
As you can see, the temperature rise is a little over 7 Degrees C in the SinkPAD Style board and a little over 5 Degrees C in the INTL-OUTDOOR Style Board. Not a massive difference, but not completely insignificant either. It would be more and more pronounced as the number of heat watts went up.
PPtk
Hopback
Hopback's picture
Last seen: 4 years 11 months ago
Thanks for the tests PPtk, I’m really surprised that that tiny stamp mark on the Sinkpad makes a measurable difference!
Rufusbduck
It’s not a stamp mark but the line between two separate pieces of metal. My guess as to how they make it would be they machine the top surface leaving the pad high then add the dielectric, and traces, maybe machine the pad again to match, then solder mask, silkscreen and plating. Nice boards but I like PilotPtk’s design better.
Scott
PilotPTK
What isn’t a stamp mark? The SinkPAD ‘hole’ on the back side? I can assure you that it is – the whole thing is a single piece of metal (copper) that is punched to raise up the thermal pad in the center. This is why there is a matching ‘hole’ in the back side – the copper is displaced so that the SinkPAD Raises up from the top side of the board.
PPtk
Rufusbduck
Silly me. I thought they pressed a thicker piece of copper in but it’s still continuous with the rest of the base metal?
Scott
texaspyro
Did you account for filling the dimple with thermal compound? I suspect that in the real world the differences will be minimal.
Tom E
Tom E's picture
Last seen: 2 hours 58 min ago
Wow, these sound excellent, and under $2 each. I was unaware of round 1 on these.
Oh boy, I think your (PPtk) design is superior on the 16 mm SinkPADs, but still, these are about half the cost and I do like the flat bottoms... I ran out of the 20 mm SinkPAD's from the first group buy, so ordered a lot more of the 16's. Hank has been pretty good in keeping up for the most part, so glad to see he's leading the way.
I'm not sure how you are feeling about this, but it was bound to happen, just a matter of time. If only we could get low cost, low profile boost drivers now for single cell XM-L2/copper lights, we'd be set. I think we are still lacking timed testing though on the XM-L2/copper single cells across a variety of amps and batteries. One informal test I did comparing a U3/SinkPAD vs XM-L2/SinkPAD, both at 3.85A C8's, showed the XM-L2 started 100 lumens ahead at start, stayed ahead for the first 15 minutes on a Pana PD, but then started falling behind the U3. Also I find you got to do everything to reduce resistance on XM-L2/SinkPAD builds, because every drop matters, more so than with alum stars.
PilotPTK
Yes, I did. I filled the void with a material that has similar thermal properties to thermal paste. Ceramic, to be specific, with a thermal conductivity of 3.1W/M*K
I suspect the same – but minimal isn’t zero.
PPtk
ryansoh3
ryansoh3's picture
Any estimate on pricing?
Tom E
Tom E's picture
Price is posted on the IOS site, think it's $3.68 for qty 2 - good deal.
ryansoh3
ryansoh3's picture
