edit: SOLD
I’m doing this a little different, I hope that doesn’t bother anyone or break any forum rules…
If you’re interested in owning this light, please make an offer by Private Message
Buyer will pay the cost of shipping in addition to their offer.
FYI, my cost for components = $90 (host, driver, emitter, sinkpad, screws, insulator, driver spring, epoxy/alumina, so that’s the ‘reserve’ price…
Previous build thread - Torchlite SVD7, De-domed MT-G2, 9A driver
CHANGES:
>removed dielectric layer from sinkpad mtg2 pcb (to prevent screws from shorting to contacts).
>filed bottom edge of sinkpad until the recess was gone, then lapped to 2500 grit
>changed leads (from where they exit the potting) to 20ga(+) and 24ga(-) teflon insulated wire
>soldered leads directly to emitter
>changed screws to steel, 4x40, ultra low profile head
Here are some pictures…
First, two scratches in the anodizing (this is how I received the host) :_( . Other than these, the finish and machining are very good.
updated pill photos
The insulator had to be cut to fit, so the hole isn’t perfectly symmetrical - but the emitter is very well centered.
driver potting….note I change from silicon to teflon wires - simply because they are stiffer and easier to solder to emitter
*Potted top board of driver (devcon 2 ton epoxy and alumina)
*potted bottom board of driver
*applied release agent to inside of pill and potted entire driver inside it
*soldered driver to pill
size comparison with Crelant 7g5v2.
The neoprene holster is included - the Crelant is NOT
Latest beamshots (a fair bit dimmer than what my eyes see…I still need to figure out my camera)
High (strike a pose, Ozzy)
Medium
Low
High
Update - measurements
cells - 2xMNKE IMR 26650, 4.21V
Current - High, Medium, Low
I have not measured at the emitter with this driver. I would guess driver efficiency at 80. I doubt it is any higher, but I wouldn’t be surprised if it is lower. 80 would = 38 watts to emitter…so it is getting 5 to 6 amps at turn on.
As the light heats up, and the emitter Vf goes down, current settles in at ~5.8A on high.
Lux - the range on the meter is set to x100 and the lens is 1 meter from the sensor (+/- 2cm).
These measurements are when the light is first turned on (the hotspot looks off center on the sensor, but it is an illusion due to camera angle)
High = 37300 lux
Medium = 16900 lux
Low = 5300 lux
I ran the light for 3 minutes on high, with it bezel down on a table (nothing touching the light body) to check tail current and see if the temperature protection would kick in (it did not).
At that point, wrapping your hand around where the pill is and holding it becomes uncomfortable after several seconds.
Immediately after the 3 minute run, I replaced the tailcap and took these lux measurements.
High = 31300 lux
Medium = 14200 lux
Low = 4300 lux
Starting from room temperature, and holding the light by the battery tube, I can run it for 5 minutes before I get concerned - the battery tube is warm but not at all uncomfortable to hold. The heatsink and head are pretty hot.
I run a modded Trustfire D1 w/ xml at 4.3A until it gets much hotter…but I don’t feel like pushing my luck any further w/ this expensive emitter lol
Imagine what this light would do w/ a copper pcb J)
