I thought it would be interesting to see how the throw of an SC52 changed over an hour while running an Eneloop 2000 mAh battery and a Duracell alkaline (with Duralock, expiration date Dec 2022). So I set my luxmeter to record at 2 second intervals, ran the SC52 on high for an hour with each battery, dumped the data into a spreadsheet and calculated and graphed throw.
More than a simple discharge graph, this tells you what the light is able to do with the energy from each battery so you’ll know how much throw you’ll have at any given moment.
The Nitecore EA4 results surprised me. In hindsight I’m thinking it’s because there are four batteries powering one emitter and that in relative terms the SC52 squeezes a lot more out of its single battery.
The manual says the EA4 steps down from turbo to high at 3 minutes but not sure why it stepped down again at around 52 minutes with the Eneloops and not the Duracells.
I should probably add that although both curves look similar because each shows the change in output over time, Selfbuilt has said he uses lightbox readings and I’m measuring throw. Think SRK and TN31 with each method as a good example of the difference.
Nice work. Thank you for sharing. That alkaline line looks just like my experience using them. Excitement at first and then a long slow never ending downward slide of disappointment as my light would get dimmer and dimmer. Me just hoping it would die already so I could feel alright about putting new ones in.
I thought was interesting to see one graph of throw and the other of lumens, but they lined up fairly close. Also good to see someone run their own tests. I think the results show consistency with Zebralights.
The EA4 test will be interesting as well. Keep up the good work.
jmpaul320, interesting. I know the low flashes are based on voltage and on remaining battery capacity. I don’t know how they calculate remaining capacity though. I do know my li-ion 14500 works great, and you don’t lose low modes like many other lights do.
Just added EA4 results to the OP. Moral of the story: if you have alkaline AAs, don’t waste them in an SC52, use them in an EA4.
Will probably add a Romisen RC-G2 III XP-G R5 here, which is a decent AA mini-thrower I got from ShiningBeam. Maybe compare some 18650 lights after that.
It’s odd that you were able to get 50 minutes of maximum brightness out of alkalines. Selfbuilt’s graph showed only ~30 minutes before output started to drop.
Actually, I guess it’s not that strange. Selfbuilt’s graph showed higher output from alkalines which would account for the time disparity. There appear to be some driver differences between the lights you guys used. I’d be curious to see what your graph looks like beyond 60 minutes as selfbuilt’s graph also didn’t show any stepdown at 52 minutes on eneloops.
I’ve done some searching online regarding the sc52. What a light! :bigsmile: As you, I think I really need to get one of these. My favorites are the small, one-battery models - and like most on here (probably…) I am intrigued by the brightest, longest-lasting examples.
