6 2900mah 18650's for $16.50
86 posts / 0 new
ImA4Wheelr
The following battery pack should have 6 2900mah cells. Seller is fairly new, but in the US. I took a chance and bought one. They have 8 left.
http://www.ebay.com/itm/New-Genuine-Acer-10-8V-5800mAh-White-Laptop-Batt...
I think it says “cells made in Japan”, but it is hard to tell. Top line on far right of label.
Edited by: ImA4Wheelr on 04/18/2013 - 12:22
dthrckt
dthrckt's picture
Last seen: 1 week 6 days ago
link looks incomplete
ImA4Wheelr
Fixed. Thank you.
Ubehebe
Last seen: 7 years 1 month ago
One site lists this battery as having ***12*** cells, which would make the cell output very small.
http://www.global-laptop-batteries.com/acer-laptop-battery/acer-UM08B52-...
I don’t think I have ever seen a laptop pack with 12 cells (10 is the most I have seen), so the description of 12 cells is very suspect.
Still, $16.50 is a great price if there is something good in there.
I must resist. I have 200+ pack pulls already. I must not buy.
Ubehebe
Resistance lasted about 20 seconds. I’m in for one.
I think I better start looking for the nearest chapter of batteries anonymous.
ImA4Wheelr
Wow. Sounds like you are set up for the upcoming zoombie apocalypse. I’m still working on it.
Ubehebe
At first I thought it was harmless. Just an outgrowth of my semi-hoarding collecting nature. I like to collect stuff and then get rid of that stuff and collect something else.
But the problem with li-ion batteries is that I’m strating to be concerned about the risk, sort of like rock-and-rollers being concerned about flying. They fly so much that it raises the chances of them being in a plane crash, consdiering many are forced to take small planes in dubious weather. Many great pop stars have died in plane wrecks.
Same thing with li-ion batteries: The more I get, the bigger the chance that I’ll get a bad one that will self-immolate, setting off 200 others, which will make for quite a fire from what I’ve seen of scary li-ion vids. I try to keep ‘em stored away from each other but I only have so much room here. Plus I’m in the desert and high temps are bad for ‘em so I can’t just leave ‘em in an outbuilding because of the heat.
I’m sure that I’m being paranoid, but I do think about the fire danger. I really do need to get rid of some, give more away. One hundred was manageable, but 200 (or more at this point) is just too much. Time to thin the herd. Just need to find some time to put up some giveaways on BLF.
ImA4Wheelr
I have about 30 new (counting the 6 on the way in this pack) and probably double that in used pack pulls. The ones not in flashlights are kept in the refrigerator. I figure lower temperature mean less activity in the cells, but I’m not worried either way. It seems like the risk is low if you get rid of the ones that don’t hold charges or have been taken too low more than once. There are who knows how many millions of people and businesses with Li-ion batteries in their laptops, cells, etc. Increasing your risk from 1 in some billions too 200 in some billions doesn’t seem like an increase in risk.
The hording is another thing. I, my friend, am trying to tackle that issue myself.
ohaya
Last seen: 3 years 7 months ago
Hi,
I think that the Acers have a standard battery, and, typically, an extended battery. That might explain why some might have 6 cells, while others might have 12 cells?
PyTech
PyTech's picture
Last seen: 2 weeks 2 days ago
Is there any difference in performance & charging methods considering these are 3.6 volt and not the usual 3.7?
-Sean
ImA4Wheelr
Not that I’m aware of. Most laptop packs I have encountered have 3.6 cells.
ImA4Wheelr
Battery arrived. Good news. The pack appears to have never been used and is in what appeared to be factory static bag. It contains 6 of 2900mah Panasonic NCR18650’s. The cells have date code “9511”. So they were manufactured on the first day of the first week of May 2009. The cells are at 1.9v. Looks like these may be a lucky find. I would not have found them if it wasn’t for ohaya’s find in the following thread:
http://budgetlightforum.com/node/20812
First pick is a tip on how to open these packs.
relic38
relic38's picture
Last seen: 3 years 11 months ago
Hmm, 1.9V is really low. They may have been uncharged for about four years. They may not have been below 2.5V for more than the last month or so. Better charge them slow to start with, then capacity test them if you can.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
ImA4Wheelr
We went through all of this in the above linked thread. I’ll still be cautious, but they will probably still have full capacity, low resistance and relatively high discharge rate capability.
moderator007
moderator007's picture
Last seen: 1 month 4 weeks ago
I purchased one of the packs from the other thread. I charged and discharged the batteries one cycle. Charged the battery up again to full capacity and discharged at a rate of 3 amps. I got a little over 2700mah’s at a rate of 3 amps, discharged down to 2.7v. For some reason the batteries just seem to be a sleep. From my test and others on the other thread they seem perfectly and happily healthy. As if they where just made, even though the cells I got where 3 1/2 years old.
Ubehebe
Well, good news on the 2900s! Adds up to one of the luckiest weekends ever! Yesterday scored a brand-new string-trimmer power pack from the home depot recycle bin that contained not five, not 10, not 15 BUT 20 (!!!) Samsung 18650 13q high-demands, all charged to 4.10 volts. Power pack goes for $120 new. I have no idea why someone tossed this away, but it was still in half of the clamshell display box. Never opened.
Then I walked out in the parking lot and saw a green piece of paper blow by in a wind gust. Took a couple steps and grabbed a 20-dollar bill. Thing looks like it has been blowing around the desert for 10 years, but it’s still usable.
THEN my wife and bought our usual 2 lottery tickets and won $35 between the two of us.
So, news of 6 nice 2900s on the way for $16.50 really tops the whole wekend off.
As a side note, I thought that recent home depot power pack I posted about a month ago was hard to open …. This one was worse. Well, it was actually easier to open but this was the hairiest cage I ever worked on. No 12 volts here. Ten batteries on each side putting out 40 volts per side! Had to pull the welded tabs off BEFORE I could get each battery out. About 1 inch to work in or sparks would fly (twice).
Not high mah like the 2900s, but these are pretty cool cells.
http://budgetlightforum.com/node/18537
And i got 20 of em for free!
PyTech
PyTech's picture
Well with my limited experience I’ve noticed about half the packs I come across are rated at 11.1 volts. Mostly newer stuff though like netbooks etc. Anyways good to know there isn’t much difference.
-Sean
Boaz
Boaz's picture
Last seen: 2 days 52 min ago
Ubehebe wrote:
Well, good news on the 2900s! Adds up to one of the luckiest weekends ever! Yesterday scored a brand-new string-trimmer power pack from the home depot recycle bin that contained not five, not 10, not 15 BUT 20 (!!!) Samsung 18650 13q high-demands, all charged to 4.10 volts. Power pack goes for $120 new. I have no idea why someone tossed this away, but it was still in half of the clamshell display box. Never opened. Then I walked out in the parking lot and saw a green piece of paper blow by in a wind gust. Took a couple steps and grabbed a 20-dollar bill. Thing looks like it has been blowing around the desert for 10 years, but it's still usable. THEN my wife and bought our usual 2 lottery tickets and won $35 between the two of us. So, news of 6 nice 2900s on the way for $16.50 really tops the whole wekend off. As a side note, I thought that recent home depot power pack I posted about a month ago was hard to open .... This one was worse. Well, it was actually easier to open but this was the hairiest cage I ever worked on. No 12 volts here. Ten batteries on each side putting out 40 volts per side! Had to pull the welded tabs off BEFORE I could get each battery out. About 1 inch to work in or sparks would fly (twice). Not high mah like the 2900s, but these are pretty cool cells. http://budgetlightforum.com/node/18537 And i got 20 of em for free!
I've considered like edcplus that the best use of those batteries is probably left as an already built pack ...tearing them apart makes sense if you NEED batteries which clearly not many of us do ..An assembled tough pack is starting to make much much more sense ,Maybe a dedicated bike light with a battery pack that snaps in under your seat .
 When tearing these packs apart it gives one pause for thought about overall quality of it's construction ..about 7000 times tougher than a laptop pack
ImA4Wheelr
Ubehebe, you’re going to laugh when/if you break down this pack. It was even easier than ohaya’s find.
I have a pack I have not broke down yet. I think I’m going to take Boaz’s advice and wait on breaking it down. All I would need to figure out is which terminals to connect to and I would have a 10.8v protected battery with self contained charger.
Ubehebe
Valid points on the pack, but I don’t have the charger and what would i do with a pack putting out 40 volts? I was thinking of selling it on fleabay but I don’t really know if the thing works or had some kind of defect.
And from reading the link I posted, these are some interesting batteries. For example, I ran one for 30 minutes in my test flashlight and got 4.01 volts after 30 minutes. I have BRAND-NEW Panasonics and Samsungs that don’t do that well, so these things are worth further investigation.
No, I definitely do noT need the abtteries, hoo hahahahha. I haven’t needed another battery since like last October. I definitely have a battery problem and might have to check into battery rehab shortly. Wink
Asking me to not open a pack is like placing a pound of heroin in front of a junkie and telling him not to touch it.
I have a li-ion monkey on my back. :-0
Ubehebe
Well, consider yourself lucky for getting 2900s. I got not-so-great light-green samsung 18650-22F cells, which are 2200 mah. I mean they are okay, but I have enough 2200 cells to choke two horses.
Oh well, easy come easy go. Was hoping for samsung purples or panasonic grays.
More to add to the BLF giveaway pile … Then again, I have never had NEW 2200s. They’re only 15% less theoretically than a 2600-mah cell. Who knows. I’ll give ‘em a try. (At least they were all exactly 3.46 volts!) Still wish they were 2900s! :-0
But for others thinking of buying these packs, be aware that 2900 batteries are NOT guaranteed.
Urggggh.
ImA4Wheelr
Can I see a picture of the battery case? Sounds like he sent you the wrong thing and you need to complain to the vendor. If he doesn’t send you the right replacement, file an ebay claim.
texaspyro
Last seen: 2 years 5 months ago
I got one of these in today. Easy to open since it is held together by snap tabs and not glued/welded. All cells were grey Panasonic NCR1850/2900 mAh and were above 2.0V Four are on the charger now…
scaru
scaru's picture
Last seen: 4 years 11 months ago
Just bought the last two, hopefully I get 2900 mah cells and not 2200 ones. If I get 2200 mah cells I'm returning it...
ImA4Wheelr
I with you scaru. It would be a clear case because 2200 cells can’t even be arranged to get 5600mah. Everytime I have been sent the wrong thing, ebay has got the vendor to refund me without having to return the item shipped to me.
texaspyro
Another listing for these for $20.69 shipped. He has 49 left:
http://www.ebay.com/itm/New-Genuine-Acer-A110-1295-63Wh-White-Laptop-Bat...
Ubehebe
I stupidly ripped it apart before looking at the label.
When I cracked it and saw the unmistakable green of Samsung 2200s, THEN I looked at the label:
um08b72 4400 mah.
So look at your label before cracking the case open.
I suppose i could try and argue with the guy, but if I was him I wouldn’t take a pack back in a bucnh of little white plastic pieces. Mine was NOT easy to open. Built like a plastic tank.
It’s only money. I’ll check the label next time.
ALTHOUGH, I have cracked mucho packs at this point and the labels are not all that accurate. I probably would have cracked the case even if I saw the 4400 on the label. I have opened quite a few packs that had a higher mah than advertised mah li-ion battery inside. Never lower, but sometimes higher. So the labels are an indicator of what you MIGHT get, but they’re not always accurate. Same goes for country of origin on the cells. I have opened quite a few that said Japanese cells but were samsungs or LGs. Maybe 10% if I had to guess.
Good luck and check the label.
Betcha everyone gets 2900s except for me. Story of my life. I knew my weekend lucky streak wouldn’t hold!
ImA4Wheelr
I would still send him a message. If I were him, I would feel bad about it and just send you the proper pack or issue a refund.
PyTech
PyTech's picture
Thanks was expecting price jump.. Hoping he still has some left on payday.
-Sean
ImA4Wheelr
Plus shipping. Starting to get to a point where I would consider buying new, new from FT at $11+ for a pair.
PyTech
PyTech's picture
Plus shipping? still says “fast n free” shipping
-Sean
