TrustFire tr-j12 problem.
I bought a TrustFire Tr-J12 on Manafont.com Friday 17 August, 2012 …. so far so good.
Now appeared a problem, the light is stuck on maximum power, no sos or strobe, medium or low light.
Someone can help me in resolving this issue, and what i need to buy to solve this stress, i need this flashlight to work!
Thanks!!
Nobody? :_(
No clues ?
Nothing ??
Probably the driver is toasted / shorted and works as direct drive.
You may want to buy a new good driver, for example this one from KD (5-mode, no blinky modes, high PWM)
Thanks for the reply, this store is reliable? :expressionless:
I always thought it could be the board …… but!
Ok … so now is order and solder the wires correct?
Thanks !
Yes, KD is reliable.
Changing the driver to TR-J12 should be quite straightforward. Some people say that they needed to sand the new driver a bit for it to fit, but others say it's direct fit. YMMV, I guess.. ;)
Strange thing happened yesterday, after having the flashlight two minutes with the maximum power…. suddenly she did a reset and I got the light at minimum and started to work right again :open_mouth: , everything works fine now. :bigsmile:
Well I think I will buy the bord, just for safety.
Thanks for all the help! :beer:
