Trying to find a charger for 2 18650’s that can be powered from the USB port in my vehicle. I have a couple things for 1 battery but can’t find anything that specifically seys that it will charge 2 at the same time. Thanks in advance.
Welcome!
You could consider the Miller ML202, except you’d have to find/build a converter from usb to the round power pin. http://www.fasttech.com/product/1283100-miller-ml202-smart-charger-for-18650-rechargeable- couple of cautions: I don’t own this, so am not sure about long batteries or independent channels
The Nitecore I2 can be bought with a regular car cigarette lighter cord, if it doesn’t absolutely have to be usb power in.
Alternately, a battery box like this: http://www.ebay.com/itm/180993274289 could be usb recharged, but the pain would be popping the batteries in and out. I think that battery box is easy to open (in other words, doesn’t screw shut like some), but don’t have direct experience with it. Plus, that item was just an example — I have no experience with that seller.
Check out some of the HKJ reviews on battery boxes if you’re interested in these… index of USB equipment
The Miller unit was exactly what I was looking for and it is on the way. Thanks again.
I believe you'll want this USB to DC 2.1mm cable as well since the ML-202 charger needs a 2.1mm power input (the USB is for output to charge other devices).
-Garry
