I have tried searching this forum but have not had much luck yet
trying to find a decent 9v charger with capacity display/test that is not too expensive
I loved the Ansmann, except that they turn out to be junk.
After replacing the one I bought from Amazon twice because it quit working, I told them not to send me a third one, and just refund my money.
Read the reviews over there, it just doesn’t work.
Both of mine just went electronically crazy with all the lights flashing and cycling and no actual operation or charging, but they were very nice for the first few days that they worked.
yep it give me the discount but it added the UK warehouse version to my basket when there are none actually in stock
I guess I should try getting the discount on the cheaper ‘international’ version instead as there should not be any customs fees as the price is below the customs limit - obviously I will have to wait longer for delivery from HK
While figuring out if I had a PSU that I could use with it I have read that it needs a 12v power supply that can provide 5 to 6 amps so I am surprised the poster above showed a picture of a PSU that can only provide 0.6 amps !
5-6 amps is only needed when you’re charging multiple cells at full charge rate.
An example would be a RC lipo battery, which tolerates 40C discharge and 5C charge.
It’s not recommended to charge a 18650, 16340, etc. cylindrical cells above 0.5-1.0C, so I never need a 5-6A power supply.
While I was charging one of my 9v Li-ion batteries the +ve clip slipped off & very briefly created a short circuit with the -ve clip (briefly sparked !)
I restarted the charging & the charger appears OK - can I assume I have been lucky or could I have damaged something & not know about it yet ?
Does the charger have any protection built in against this ?
Any of these power supplys should work. http://www.ebay.com/sch/i.html?\_odkw=imax+b6&\_osacat=0&\_from=R40&\_trksid=p2045573.m570.l1313.TR3.TRC2.A0&\_nkw=imax+b6+power+supply&\_sacat=0
Make sure it has a 5.5mm by 2.5mm barrel type plug and 5 to 6 amps output as stated above and it should plug right in.
As far as the short, in my experience it has never effected the charger. I have let the leads connect together many times and noticed a arch many times without in ill effects. I use magnets to make connections to the cell or cells. The charger is always looking for voltages that is out of range for the selected cell or cells. When it senses a out of range voltage it will usually display a error.
