I am looking for a P60 host with a really thin bezel for bike riding. My skyray cuts off the edges in a hexagon pattern which is unfortunate because it seems like wasted light. maybe a knockoff L2? I dont mind grinding/sandpapering down a little
I found this post by old4570 interesting
old4570:
Now lets get back to output .. Output is blocked by the flashlight body , all those nice looking bezels that people like to use block spill .. The larger the bezel - deeper , the more spill is lost , so output is lost ..
If you were to test a standard L2 , Actually I will ...
With bezel in place [ standard L2 Defencive Bezel ] 266OTF Lumens
Now lets remove the bezel [ Only ] and see how we go = 330OTF Lumens
So simply removing the bezel increases outout [ Spill ] and gains us 64Lumens
So if you chose a host body that blocks less spill , your output should increase ...
Lights with brighter spill / wider spill / such as XP-G and XM-L will be more affected by blockage from the bezel , and you will see greater gains , from removing said blockage ..
Hope this helps ...
srfreddy
(srfreddy)
April 19, 2011, 11:16pm
2
yeah, my manafont dropin's spill is unbelievably narrow, even with the high profile flat SS bezel, in my L2. The small bezel ring would cut less off.
old4570
(old4570)
April 20, 2011, 1:17am
3
You could simply take a stock bezel , and grind it down ..
If I ever get a lathe I will simply macine them down till they are as small as possible ...
The only thing a want from the bezel is to hold the lens in place ...
srfreddy
(srfreddy)
April 20, 2011, 3:01am
4
I've actually just put the lens in, stabilized it with some foil, and stuck the funny shaped oring over the lens, and it doesn't fall out, no matter how hard I shake.
old4570
(old4570)
April 20, 2011, 3:16am
5
I have a SST 50 , and with the Ultrafire L2 , with bezel it puts out about 520 , when I remove the bezel , its 620 , 100Lumen lost from the bezel ..
So like I said , the more spill the emitter has , the more output is lost . Im going to minimize the bezel and see what happens .
Still I would need a lathe to bevel the inside cleanly . But I will see what I can do .
Budgeteer
(Budgeteer)
April 20, 2011, 5:15am
6
Or make a clone from a genuine Foyzel TM.
Piers
(Piers)
April 20, 2011, 6:51am
7
The cheaper flat bezel might be even better as it is shorter and only $2.50 (plus $2 p&p)
http://www.solarforce-sales.com/product_detail.php?t=FA&s=15&id=51
Kokopelli
(Kokopelli)
April 20, 2011, 7:00am
8
I have a SkyRay P60 host I use with my XM-L build and it seems to have a better opening than a SF standard bezel. The bezel is shiny metal and may even contribute to the reflections. This is the one I recommend.
