“this flashlight have a chip inside?” :quest:
Got this messagel from a customer. what does he mean?
if it means PCB, then every flashlight must have one.
anyone please can help me out there?
You probably need to provide more information/context, but if I had to guess, I think that he means what you said, i.e., he’s asking if the flashlight (whichever one he was talking about) has a driver chip, like an MCU. He may be thinking that some flashlights could be direct-driven from the battery, so he may be wondering if that’s the case with whatever light you both are talking about.
Ahh. Ok. Since that is single mode (on/off), the person may be wondering if it has a driver/MCU as I mentioned above. Since it is one mode only, it might not need a driver, but I’m guessing that it probably does have one, at least for something like power regulation, but you’d need to either know or check on it :)…
Yes, I know how to answer this. this is about what’s happening between the LED and battery. Driver - Flashlight Wiki and referred flashlight wiki.
it says “Only by correctly combining the power supply, driver, and LED will a LED function properly.”
this is broadky speaking.
what’s really at disscussion is the system function between LED and battery.
if I answer him yes or no, that would be an easy and not very good answer.
thanks, ohaya.
