- Extension tube to swap between 1 or 2 cell configuration.
- 2x Switches, choose from 3 modes or 1.
- Spare o-rings
- Spare switch covers
- Lanyard
Foam lined Solar Force presentation case, with SF outer cover too.
1x Solar Force Holster - perfect fit for this M8 torch!
2x Samsung ICR 18650 28a Cells.
Slightly recessed cells, work perfectly in single cell mode, however I have included a neodymium magnet to go between cells and close the gap if you want to use it with the extension tube in 2 cell mode.
1x Solar Force 2bay cell case
1x Solar Force 18650/16340 charger
US plug fitted, but I have included a UK mains adaptor.
ALL PARTS UN-USED, BRAND NEW, IN ORIGINAL PACKAGING WHERE APPLICABLE AND COMPLETELY AS-NEW!
All of the above cost me just under $100, which equates to £65.
I would prefer to sell to a UK buyer, purely due to postal charges, but depending on the offer I will decide on sending out-with the UK.
Going to put this up for auction now, so please be aware that if you want to make me an offer, it may be too late to close the auction and sell it through BLF, but try me anyway.
Just kidding. Good luck nevertheless.
But if the eBay-protection-move turned out to be a bit too much and you’re still sitting on the bloody thing and you consider selling the light only (e.g. M8, ext tube, both switches, without the surplus parts) give me a note.
so i noticed a little dink in the LED dome when it first arrived but it didn’t affect the beam or spot so i didn’t let it bother me, but it’s now gone black and is looking pretty bad.
Just wondering if you had any solution to this because i hadn’t even unscrewed the lens off until i noticed the what looks like a burnt spot.
I can assure you it wasn’t caused by me, because all I ever did with the torch was insert batteries, switch it on to make sure it operated properly, which it did, then it was packed up again to be sold on. I was coming down in torches at the time due to a temporary addiction.
I can’t offer you a solution I’m afraid. I have no spares or anything like that, and I have sold all the torches I had except my Terminator keeper, so I can’t even send a part to swap from another torch.
I hate being the one to complain but i’m sure it was there from when i received it, i thought it was just the way the light was catching the dome at first but in exactly the same place the burnt mark appeared. If you take a look at the 3rd picture you posted it’s in the position where the bottom half of the glare is just off center.
I noticed a few fibers of fluff around the plastic surrounding the led which i thought was a little strange too.
I’m not saying you’re lying but i feel right now like i payed for damaged goods and i’m not too chuffed about it.
Ideally i’d have liked to have the torch in working order as it was working great at first.
Hope something can be arranged.
Cheers.
Best pics i can get, i’ve had a quick browse of the web and haven’t found anyone who’s opened this part up without wrecking it.
Like i said i don’t really wanna cause problems but idk what to do.
