Test / Review: Efest IMR14430 V1 600mAh (Red)
Official specifications:
  • Specification:14430
  • Nominal Voltage: 3.7V
  • Material: Li-Mn
  • Positive pole: Flat top
  • Size: 43.63(L)*14.14(D)mm
The size of this battery is not very common, the diameter is like a AA battery, but the length is only like a AAA.
The batteries has more than rated capacity.
The battery is not super at high current, probably because the design has focused more on capacity.
There is a slight capacity difference between the batteries.
Conclusion
The battery has an acceptable performance.
Notes and links
Comparison to other LiIon batteries
THanks for the review HKJ. I confess I’ve never heard of this size battery before. Any idea what it might be used in?
No. The advantage is, of course, that it is shorter than a AA battery and has more capacity than a AAA, but I have no idea where you uses that type of battery.
Thanks a lot for the review! Frontpage’d and Sticky’d.
