Test / Review: TrustFire 14500 900mAh (Blue) LC
Official specifications:
  • Shell material: steel
  • Rated voltage: 3.7V
  • Internal resistance: <= 100 milli ohm
  • Low voltage cut off: 2.75V
  • Over charge voltage cut off: 4.2V
  • Maximum charge current: 1.5C
  • Maximum discharge current: 1.5C
  • Diameter: 14.0 +/- 0.5mm
  • Height: 51.5 +/- 0.5mm
  • Environmental temperature (operating): 0~45'C
  • Environmental temperature (charging): -20~60'C
As expected the capacity is lower than rated.
The batteries can easily handle a 1A load, but due to capacity differences they are not suited for usage in series.
Conclusion
These batteries has better performance, than last time I tested them, but I will still rate them as acceptable for a cheap battery.
Notes and links
Battery was supplied from LightCastle for review.
I have tested this battery before, but with a different result.
Comparison to other LiIon batteries
Thanks for the test!
Thank you for the time and effort to test and report. Very good information.
Greatly appreciate all the valuable info. :slight_smile:
I wonder if they have improved any or if they tested better just because of the random nature of their quality.
Thanks a lot for the review! Frontpage’d and Sticky’d.
