Best fit for XML-T6 driver?
7 posts / 0 new
e10sno
HI All...I'm new here. Today just browse to Lck-Led.com saw interest deal for XML-t6@6 Dollas (http://www.lck-led.com/p853/Cree-XLamp-XM-L-Cool-White-LEDs-w/16mm-Board-T6-Group,1000Lm@3A/product_info.html)...Should I buy for my P60 body? If yes, what is the best driver to suit this one? Or I should consider to buy Drop-in XML T6 or U2 from KD/Manafont?
Also, wondering which website is the best to buy 18650? ( I may need 4-5).....Thank guys...
brted
brted's picture
Last seen: 2 weeks 4 hours ago
Welcome to BLF, e10sno! I like the Manafont drop-in, but it is ordered H-M-L and has PWM on lower modes, which I'm not crazy about. But mine at least is very bright on High.
If you want to build your own, I think a 16mm board is the biggest that will fit in a P60. The 8x7135 2.8A driver is a good one if you want modes:
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10995
For hosts, it is hard to beat Solarforce, though you can sometimes find cheaper alternatives. For 18650 batteries, most people like the Trustfire flame 2400mAh batteries from DealExtreme:
http://www.dealextreme.com/p/trustfire-protected-18650-3-7v-true-2400mah-rechargeable-lithium-batteries-2-pack-20392
e10sno
Thanks guys..more options?  Smile
jacktheclipper
jacktheclipper's picture
Last seen: 16 hours 38 min ago
Be-Seen Triker wrote:
 ...And welcome to the new home of BLF (DOT COMMMMMMMMMMM) Cool
Holy Sh!t , I just noticed ... Cool !
brted
brted's picture
Another thing you could do is go to DealExtreme and choose the P60 XM-L flashlight you want for around $22 and then swap the KD drivers into them.
If you don't mind spending a little more you could go all Solarforce: host and drop-in, though I don't think the Solarforce drop-ins are quite as bright as the KD and Manafont ones.
Piers
Welcome to BLF!
The driver brted linked at KD is a good one, you get to choose from a selection of modes...so you can get rid of the strobe for instance.
The other option a lot of peopel here would recomend would be the T6 dropin from Manafont
arcaneinsomniac
Last seen: 9 years 5 months ago
Does anyone know the PWM frequency the KD driver linked earlier, this one
I wish the low mode could be even lower than 6%...
The Manafont dropin, though nice on high, has a PWM frequency well under 200Hz and drives me nuts.
