What is your favorite RCR123A (16340)?
27 posts / 0 new
markito
markito's picture
Last seen: 5 days 2 hours ago
Hi to all!
So, what is your favorite as the title said RCR123A battery?
Edited by: markito on 06/15/2013 - 17:14
Pulsar
Pulsar's picture
my preferred are the lifepo4 tenergy rcr123a... but i cant say i have tried a lot of them
tallboybass
tallboybass's picture
Last seen: 2 years 7 months ago
Do you mean batteries or flashlights?
markito
markito's picture
I would like to buy some batteries for flashlight.
Thanks!
AlexGT
AlexGT's picture
Last seen: 57 min 5 sec ago
Good question, I too want to hear what others are using, I had bad luck with trustfire and ultrafire brands
Pulsar
Pulsar's picture
the only rcr123a i have used was tenergy and ultracell (lifepo4) and some unknown regulated li-ion 3v cell. the ultracell and regulated cells worked good for a couple months, but the tenergy lasted a year or more of consistent results.
these cells were all used in a prodigy v3.1 ecig, stacked. tenergys consistently lasted more than a full day, while the other cells regularly needed to to be changed out mid day.
im sure you are looking for 3.7v cells, so this may not be of any help.
LSX
LSX's picture
Last seen: 3 days 22 hours ago
I have a Yezl 880mAh 16340 which seems to be pretty good. Have also just ordered a Nitecore RCR123 650mAh after hearing a lot of positive comments about them.
Both 3.7v and protected.
Nightbird95
Nightbird95's picture
I’ve tried protected TrustFire & UltraFire 16340s/RCR123As and they just can’t handle high current drains like that of the Mini-02 or UF-K21.
I’ve tried NiteCore RCR1234As and they’re great. They can provide the current requirement needed and their claimed capacity is real.
iron potato
Last seen: 9 months 4 weeks ago
Yet another +1 to NiteCore RCR123
A NiteCore NL166 inside an Olight S10 Baton, one of my trusty backup edc :bigsmile:
bdiddle
Last seen: 2 months 4 weeks ago
Efest. Delivers 3 amps just fine
Newb
tallboybass
I’m still using those cheap “1000mAh” UltraFires…they give my EC1, S-10 and Mini ML-X all the juice they can handle, so far.
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 3 days ago
I've had great luck with genuine Trustfire Flames in that size.  No issues running any of my lights at 3A when needed.
blueb8llz
Last seen: 4 hours 5 min ago
i use extremebeam 1000 mah and aw imr 550 mah
moderator007
moderator007's picture
Last seen: 6 days 16 hours ago
I have ultrafire gray, trustires black w/red flames and nitecore NL166. The nitecore NL166 has the best capacity of the bunch.
mkett39
mkett39's picture
Last seen: 1 week 5 days ago
I use the Xtar and the Soshine. Have had good results with both.
sixfink
Last seen: 2 years 6 months ago
I’m quite happy with me Solarforce 700mA ones.
leaftye
Last seen: 10 months 4 days ago
sixfink wrote:
I'm quite happy with me Solarforce 700mA ones.
I saw a nice review for Solarforce when I was looking for a better alternative to Nitecore. I'll get one sometime.  I don't think there's there's much difference in the best 16340 cells, not that they're that great.
The low mode should be lower.
oRAirwolf
oRAirwolf's picture
Solarforce protected 880mAh 16340 blue/white cell
$3.50 each + $2 shipping. Using my Thunder AC680 hobby charger, their capacity is around 720 mAh at the industry standard .2C (used .2A) when discharged down to 3 volts from a full charge. They are the highest capacity 16340’s I could find and they are cheap. The only downside is that they are pretty wide, so they will not fit in all lights.
I am discharge testing my Trustfire 880 mAh 16340’s I got from Tmart as I type this. I will post the results in here once it is done.
Edit: 702 mAh on the Trustfire’s from Tmart. I am genuinely suprised by that. I thought they were going to be in the 500 mAh range…
leaftye
oRAirwolf wrote:
"Solarforce protected 880mAh 16340 blue/white cell":http://www.solarforceflashlight-sales.com/product_detail.php?t=BC&s=23&i... $3.50 each + $2 shipping. Using my Thunder AC680 hobby charger, their capacity is around 720 mAh at the industry standard .2C (used .2A) when discharged down to 3 volts from a full charge. They are the highest capacity 16340's I could find and they are cheap. The only downside is that they are pretty wide, so they will not fit in all lights. I am discharge testing my "Trustfire 880 mAh 16340's":http://www.tmart.com/2pcs-3.7V-880mAh-16340-Lithium-Rechargeable-Batteri... I got from Tmart as I type this. I will post the results in here once it is done.
Does it fit in your oLight S10?
Your list of lights is helpful this way.  I may borrow your idea.
blueb8llz
no one else uses imr AW’s besides me?
Chicken Drumstick
Last seen: 7 months 6 days ago
I have AW ICR 16340’s. No complaints so far and they easily out perform my Trusfire 14500’s.
I also have some AW IMR 18350’s, which again I have no complaints with.
leaftye
Volume of a 14500 should be 7700 mm^2.
Volume of a 16340 should be 6839 mm^2.
I've been curious about that for a while.
HKJ
HKJ's picture
Last seen: 3 days 23 hours ago
Chicken Drumstick wrote:
I have AW ICR 16340's. No complaints so far and they easily out perform my Trusfire 14500's. I also have some AW IMR 18350's, which again I have no complaints with.
The blue Trustfire has low capacity, the flame Trustfire is much better.
Generally 14500 will outperform 16340 batteries.
On 16340 there is usual no reason to believe the marked mAh, on 14500 they are sometimes correct.
Uldzha
Uldzha's picture
Last seen: 5 years 2 months ago
Nitecore NL166
oRAirwolf
oRAirwolf's picture
leaftye wrote:
oRAirwolf wrote:
Solarforce protected 880mAh 16340 blue/white cell $3.50 each + $2 shipping. Using my Thunder AC680 hobby charger, their capacity is around 720 mAh at the industry standard .2C (used .2A) when discharged down to 3 volts from a full charge. They are the highest capacity 16340’s I could find and they are cheap. The only downside is that they are pretty wide, so they will not fit in all lights. I am discharge testing my Trustfire 880 mAh 16340’s I got from Tmart as I type this. I will post the results in here once it is done.
They don’t fit in my olight s10 or my Sunwayman R10R. They do fit in my JETbeam RRT01 and Crelant V31A though.
As I put in my previous post, I got 702 mAh @ .2A to 3V out of my protected Trustfire Flames. Not bad at all…
Johm
My favorite 16340 is the AW ICR.
They have performed really well for me over the years.
I also have white, gray and flame trustfire 16340’s.
(a portion of these are dying off after a few years of light use)
Also a protected AW is about the same size as an unprotected Trustfire, so protected TF’s do not fit all 16340 lights.
Windsurf
Windsurf's picture
My favorite 16340 is a 18350. Seriously, most of my flashlights are Solarforce L2’s which will take an 18350 as a replacement for the 16340. So I use Xtar IMR 18350 850 mAh which are really great. But I recently bought a couple of Trustfire L2M’s and to my surprise their walls are not bored for an 18 size battery so I had to pull out some 16’s. I have some Xtar protected cell 16340 600 mAh which also world great. But in with the Trustfire L2M’s they included a small charger and an Ultrafire protected 1000 mAh. I’ve read these Ultrafire’s don’t do well over time so I have been charging them then using them to about 3.6v and then another recharge. So far I have done 4 recycles in 2 days. I’ll do a few more and see if they start to deteriorate. I’m surprised that these Ultrafire 1000’s hold any charge at all but so far they have been good.
