Test / Review: Sanyo UR18650ZTA 3000mAh (Magenta)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 5 days ago
DSC_2219
Official specifications:
  • Nominal Capacity: 3000mAh (0.2C, 2.75V discharge)
  • Minimum Capacity: 2900mAh(0.2C, 2.75V discharge)
  • Charging Voltage: 4.35 ±0.05 V
  • Nominal Voltage: 3.7V
  • Charging Method CC-CV (constant voltage with limited current)
  • Standard charge: 1450mA
  • Rapid charge: 2900mA
  • Standard charge: 3hours
  • Rapid charge: 2.5hours
  • Max. Charge Current: 2900mA(ambient temperature 25°C)
  • Max. Discharge Current: 5800mA(ambient temperature 25°C)
  • Discharge Cut-off Voltage: 2.75V
  • Cell Weight: 48.0g max
  • Cell Dimension: Height: 65.00mm max, Diameter: 18.25mm max,
  • Operating Temperature: Charge : 0 to 45°C, Discharge: -20 to 60°C
  • Storage Temperature: 1 year: -20~25°C, 3 months: 20~45°C, 1 month : -20~60°C
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.35V-info
This battery is designed for 4.35 volt and need a special charger to get the full capacity.
DSC_2218
DSC_2220 DSC_2221
DSC_2222
DSC_2223
DSC_2224
DSC_2227
Looking very careful on the shrink wrap, it is possible to see the battery type.
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.35V-Capacity
I am not very impressed with the capacity, but the voltage is high compared to 4.2 volt batteries.
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.35V-CapacityTimeHours
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.35V-Energy
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.35V-PowerLoadTime
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.35V-TripCurrent
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.35V-Charge
Test at 4.3 volt charge
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.3V-info
Reducing the charge voltage to 4.3 volt, looses about 120mAh in capacity.
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.3V-Capacity
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.3V-CapacityTimeHours
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.3V-Energy
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.3V-PowerLoadTime
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.3V-TripCurrent
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)%204.3V-Charge
Test at 4.2 volt charge
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)-info
At 4.2 volt, the capacity is down with about 360mAh and the voltage advantage is gone.
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)-Capacity
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)-CapacityTimeHours
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)-Energy
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)-PowerLoadTime
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)-TripCurrent
Sanyo%20UR18650ZTA%203000mAh%20(Magenta)-Charge
Conclusion
Being a Sanyo battery it is very good, but I wonder about the low capacity, it might be due to age (If I read the datacode correct the battery is from 2010).
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
relic38
relic38's picture
Last seen: 3 years 11 months ago
Thanks for the review HKJ. I was curious about these cells.
I like the UR18650ZT cells. These ZTAs offer no capacity advantage and the voltage advantage is already there in the ZT.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
Slewflash
Slewflash's picture
Last seen: 4 months 4 days ago
The capacity surprised me, but if it really is from 2010 then I guess it’s expected.
Haven’t seen a 4.35 volt cell before so thanks, this was interesting!
Slewflash
sb56637
sb56637's picture
Last seen: 11 hours 50 min ago
Thanks a lot for the review! Frontpage’d and Sticky’d.
Milan
Last seen: 2 days 4 hours ago
I just finished testing 1 year old laptop battery with cells also 1 year old:
2456mAh from 4,2V
Result is obvious: These batteries are overrated.
HKJ
HKJ's picture
Milan wrote:
I just finished testing 1 year old laptop battery with cells also 1 year old: 2456mAh from 4,2V Result is obvious: These batteries are overrated.
Not bad, you got more capacity than I got in this test.
