I'm shocked by this Shocker... (de-domed now, more info)
203 posts / 0 new
RaceR86
RaceR86's picture
Last seen: 6 years 9 months ago
Thanks, If I should ever do something similar, then I would probably just stick to some 2900mAh PD cells.. And some emitter mixing..
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Tom E
Tom E's picture
Agree - Pana PD's are a nice compromise, but even on KP 3400's, it's an incredibly powerful light that would get at least some runtime. We kind of reached the limits on this form factor of 3 LED's, 3 18650 cells. This just kind of proves what's possible, not necessarily practical.
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 4 years 3 months ago
Tom,
I think you have taken the BTU Shocker to its highest level.
RaceR86
RaceR86's picture
Well said, I think you hit the nail on the head there. When that is said, who would not like to own one and see what is possible?
DENGOH
DENGOH's picture
Last seen: 3 months 3 days ago
Tom E, will the throw number increases with longer distance?
cool i'll see you when you get there
blueb8llz
Last seen: 5 hours 13 min ago
that’s boss! i knew you had something up your sleeve tom! looks like you perfected the shocker.
now im glad that my shocker was on your queue and not one of your earlier shockers. but your earlier shockers were no slouch either, its just that put polishing touches to the already madness.
way to go bruh!
Nightbird95
Nightbird95's picture
Last seen: 2 years 9 months ago
Tom E wrote:
Updated the OP with info on latest de-domed Shocker…
Do we need to do special adjustments on focusing the dedomed emitters? Or setting the emitters it its original set-up would do just fine?
Tom E
Tom E's picture
Nightbird95 wrote:
Tom E wrote:
Updated the OP with info on latest de-domed Shocker...
I'm no expert at focusing, but it looked pretty good to me as is, with the stock plastic alignment pieces - beam pattern has the usual clover effect on the outer edges of the spill and center beam, but I see the same thing stock. I heard they needed focus adjustments but I don't see the need - no dark spots, throw and output seem appropriate, etc.
Tom E
Tom E's picture
I'm thinking yes, perhaps... I assume you mean measuring distance, and 8-15 meters would probably be better. It's scary - also the #'s would be better with Samsung 20R's - maybe test this evening...
bibihang
bibihang's picture
Last seen: 18 hours 3 min ago
Bow-down to the BTU Master!
Holy crap
Nightbird95
Tom E wrote:
I’m no expert at focusing, but it looked pretty good to me as is, with the stock plastic alignment pieces – beam pattern has the usual clover effect on the outer edges of the spill and center beam, but I see the same thing stock. I heard they needed focus adjustments but I don’t see the need – no dark spots, throw and output seem appropriate, etc.
Oh! That’s what I needed to hear! Shocked
I’m dedoming the XM-L2 T6 1Bs of my BTU tonight! J)
Thanx so much TomE! :bigsmile:
Tom E
Tom E's picture
bibihang wrote:
Bow-down to the BTU Master! Holy crap
Now grasshopper, it's all in the amps. Pump enough amps into these XM-L2's and good things happen, well things will get heated up for sure... Smile
Good thing about the Shocker is the 20mm copper stars are spread out nicely on that huge pill surface, and you got a lot of aluminum mass around, though I would like to see the pill top thicker. I think the pill top of the XinTD X3 is actually thicker.
Nightbird95
By the way TomE, which resistor in the BTU driver did you put a jumper wire on? Is it the sens resistor which connects to the negative lead wire?
Tom E
Tom E's picture
Not the BTU driver - never got the resistor mod working on that driver, gave up - PilotPtk posted it, but I couldn't reproduce his result. I'm using the IOS driver, this one: http://intl-outdoor.com/xml-multicell-circuit-board-45a-ouput-55126v-p-543.html, but the versions I have are 3.5A - Hank updated these to 4.5A by resistor mods. You can clearly identify the current limiting resistors because they are 2 joined next to each other, maybe even stacked. The 5A LCK-LED driver is identical, though I didn't try one on a Shocker yet.
Nightbird95
Tom E wrote:
Not the BTU driver – never got the resistor mod working on that driver, gave up – PilotPtk posted it, but I couldn’t reproduce his result. I’m using the IOS driver, this one: http://intl-outdoor.com/xml-multicell-circuit-board-45a-ouput-55126v-p-543.html, but the versions I have are 3.5A – Hank updated these to 4.5A by resistor mods. You can clearly identify the current limiting resistors because they are 2 joined next to each other, maybe even stacked. The 5A LCK-LED driver is identical, though I didn’t try one on a Shocker yet.
I’ll stick to the stock BTU driver then. The 3 XM-L2 T6 1Bs are now soaking in gasoline. I can’t wait to see the resulting lux readings.
Thanx again TomE! Beer
sesgum
sesgum's picture
Last seen: 5 days 13 hours ago
Those are some insane numbers, competitive to 60-85w HID in both lumen and throw. Who still want a HID NOW?
I did not fond the larger form factor of shocker. But I should think about it again……
Nightbird95
Just finished modding my BTU Shocker! :bigsmile:
I dedomed its three XM-L2 T6 1Bs then re-installed it back to the shocker. I replaced its AWG 22 silicon wires with a new set of the same wires because the silicon protection of the lead wires also dissolved in gasoline. :~
I used the same stock BTU Shocker driver which gives a tail cap reading of 3.35 Amps at 12.04 volts. I then turned the flashlight on and TomE was right – the same flowery spill with a little tighter hot spot. The only difference is that the beam is already neutral white and 3 dark spots are still eminent in the hotspot at 2 meters. Lux readings at 3 meters might not give good results. :~
I took the lux reading at 6 meters and the result was 5341 lux which is equal to 192 KCD at 1 meter, a 44% increase over the 133 KCD stock readings. Shocked
My Shocker now beats my modified T-08 in throw and I’m loving this light even more. Thank you very much for the tips TomE! Smile
Tom E
Tom E's picture
Hhmm, 3 dark spots at 2 meters. Hhmm. Didn't notice that - I'll re-check this evening. Tailcap amps remained the same? I'm thinking you should have gotten double the kcd, or close to double, because I'm thinking that's what I'm seeing, but my amps are way higher, and using U2's.
Nightbird95
Its not that dark, just not as bright as the edges. Its more like 3 doughnuts that did not converge fully yet. Smile
I did not get the tail cap readings again because I did not do anything to the BTU driver. I just assumed that its the same 3.35 Amps like when the LEDs were not yet dedomed. :~
Or am I missing something? Does dedoming the LEDs change the tail cap current? :~
bibihang
bibihang's picture
Tom actually you have one more thing that can experiment with the BTU Shocker…
Triple XP-G2 de-domed, driven at 4.5A.
With the trade-off of lumens, not sure if we can see over 600kcd from there.
blueb8llz
now we gotta add this to the mix in the throw competition against vinh’s tn31 and k40’s!
…i do have a vinh k40 and tom shocker ordered though..hehe
sesgum
sesgum's picture
Hi Tom, do you care to take some nice outdoor beamshots for the ultimate shocker? Even better if you can compare it to other throwers.
Tom E
Tom E's picture
Ummm, gotta get it shipped out, probably tonight package it up, and got softball at 6pm, and, I'm not really set up so good for outdoor shots - didn't get around to mounting lights reliably, and no decent place to go I know of, small backyard, fences everywhere - I'd shock the neighbors for sure Smile at the house.
tkmckay
I’m really wishing I would have nabbed one of those K40’s….. really starting to regret not doing it especially now that a certain someone has something they are mailing me soon…. 0:) I have a few good spots for some beam shots but nothing even remotely close for comparison other than a stock BTU….
sesgum
sesgum's picture
That is a pity…
Maybe the lucky guy who will get this light can do some beam shots.
What a waste if no shots! Flat Stare
Tom E
Tom E's picture
tkmckay wrote:
blueb8llz wrote:
now we gotta add this to the mix in the throw competition against vinh's tn31 and k40's! ...i do have a vinh k40 and tom shocker ordered though..hehe
I'm really wishing I would have nabbed one of those K40's..... really starting to regret not doing it especially now that a certain someone has something they are mailing me soon.... 0:) I have a few good spots for some beam shots but nothing even remotely close for comparison other than a stock BTU....
I'm looking at my K40 now. Can't believe it, but they broke off one of the screws to hold down the PCMCB and used epoxy to cover it up, so on one side, a screw secures it down, on the other side, epoxy was used just to cover the hole. I'm gonna pull the emitter off and reflow it - looks like it's not straight, so maybe it was a bad reflow as well, yikes... Probably will have to re-tap the hole - cleared it out by drilling out the pices, tried the other screw and it won't tighten up - I know the bit I used was smaller than the hole, but who knows - maybe they used a bigger screw and that's why it broke.
rdrfronty
Last seen: 1 year 9 months ago
Tom E wrote:
tkmckay wrote:
blueb8llz wrote:
now we gotta add this to the mix in the throw competition against vinh’s tn31 and k40’s! …i do have a vinh k40 and tom shocker ordered though..hehe
I’m looking at my K40 now. Can’t believe it, but they broke off one of the screws to hold down the PCMCB and used epoxy to cover it up, so on one side, a screw secures it down, on the other side, epoxy was used just to cover the hole. I’m gonna pull the emitter off and reflow it – looks like it’s not straight, so maybe it was a bad reflow as well, yikes… Probably will have to re-tap the hole – cleared it out by drilling out the pices, tried the other screw and it won’t tighten up – I know the bit I used was smaller than the hole, but who knows – maybe they used a bigger screw and that’s why it broke.
Dang, that’s messed up. Did you a photo of it? Might be able to get them to replace the light if you can get the screw issue worked out.
Nightbird95
Tom E wrote:
Now grasshopper…
I thought grasshopper in Malay or Indonesian is belalang. :~
tkmckay
Tom, that’s really messed up for a torch of that $$$. That is something one would expect from a cheapo brand/model but certainly not something in that range.
That is exactly what I was thinking when I read it as I have done that exact thing (not with a torch have you) a couple times and not realized it until the “oh s**t” moment. Got to love the “what do we do now?…. ahh screw it, just glue it…. not like anyone will open this thing up anyhow!”
Tom E
Tom E's picture
Yes, got photos -- ohh, got her all open now!! The heat gun did the trick. Should start another thread... Lot of pics on the tear down.
